    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 04-15-2013, 09:27 PM   #6226
joeymdz's Avatar
Send a message via MSN to joeymdz
Originally Posted by Slimsh8t View Post
Just thought I would post up that I'm looking for one.
Thx,
Kevin
Look at the previous page.. There's a link
joeymdz is offline   Reply With Quote
Old 04-15-2013, 10:23 PM   #6227
gelshocker's Avatar
Originally Posted by jkirkwood View Post
Are the plastic rear wide suspension hangers available without buying a transmission case for rear motor configuration? Thanks.
There's this carbon composite set KYOUMW505B
http://www.amainhobbies.com/product_...ssis-Plate-RB5
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 04-15-2013, 11:06 PM   #6228
gelshocker's Avatar
Hey guys other than this setup, is there any other starting setup for MM on low traction? It's something I wish to try out, our local track is not too technical (i.e. no start-stops, 180s etc.), I think I can carry enough speed and momentum around it. Thanks,
http://www.petitrc.com/setup/kyosho/...kaska20121103/
Kyosho RT5 | RB6
Old 04-16-2013, 07:33 AM   #6229
Originally Posted by joeymdz View Post
Thomas trans setup
http://www.rctech.net/forum/electric...l#post12001505
med/high traction.. Depends.. Lol
motor im using is a vst 8.5 geared at 22/76 with an r10 punch at 3
This is close to what I run (22/76 with an r10 punch at 2), but had to change to Associated pads/spur. The white Kyosho pads grip too much to get rid of low end wheel spin. Anyone else have some ideas on smoothing out the low end on a 8.5 for the RB6. Already have -100% expo on throttle thru radio.
Turbo911 is offline   Reply With Quote
Old 04-16-2013, 07:45 AM   #6230
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
subbed. I just bought one off a member on these forums.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-16-2013, 07:52 AM   #6231
asc6000's Avatar
Trader Rating: 15 (100%+)
set your radio to straight linear and adjust down the esc punch. Gear down watch temps. Or just go to a 10.5
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 04-16-2013, 08:07 AM   #6232
linear throttle makes the throttle too hard to drive and I can only go down 1 on the punch on the esc as it is only at 2. A local guy told me to add teeth to the pinion to make the buggy lazier on the low end, haven't tried that yet.
Old 04-16-2013, 08:36 AM   #6233
ok, I have a lot of catching up to do here.
- What springs come on the car? I looked at petitrc and tried to search this thread, but cant fine the info. I think one pair is red, but unsure.
- I was looking on petit rc for an outdoor wet and low/med traction setup and didnt really see a lot. Is the box setup pretty good for that? Not WAY off. I would like to keep costs lowish until I get a better feeling for the car. I have tires and springs from my b4 that I can reuse for now. I am sure the K springs are cheaper, but at $20 a pair, I will need to hold off for now.
Old 04-16-2013, 08:54 AM   #6234
B00t13g's Avatar
Pink front red rear
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 04-16-2013, 09:02 AM   #6235
MikeXray's Avatar
Trader Rating: 73 (100%+)
I felt the need to try a different front spring yet, but even from white - gold - red rears, they are not huge jumps in feel. If you have reds, get a pair of whites to try.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 04-16-2013, 10:07 AM   #6236
Do the narrow rear hangers come with the ky0um508c tree?
http://www.amainhobbies.com/product_...ar-Box-Set-RB6
Old 04-16-2013, 10:16 AM   #6237
Trader Rating: 48 (100%+)
Hi Mike have ran at the barn in Chester? If so u got a setup that works?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 04-16-2013, 11:05 AM   #6238
MikeXray's Avatar
I have not been up there yet, planning too this summer. I've heard the indoor track should be close enough to ours, just use the tires everyone else does. The settings I would change first if you were to feel the car was too loose or edgy would be, .5dg rear hubs, white rear spring, move battery from mid to rear position.
Old 04-16-2013, 11:09 AM   #6239
Thanks Mike will try tonight
My Credit Card
Old 04-16-2013, 01:25 PM   #6240
Originally Posted by t0p_sh0tta View Post
They're included with the kit. If you don't care about the fancy matching gunmetal parts, get the STRC blocks, but they're only available in the narrow configuration. I don't think anybody but Kyo$ho makes the alloy wider blocks.
do you have a part number for the strc narrow hangers?
Anyone running the solar 770 in the rb6? any fit issues?
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22939 Today 01:36 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
