    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 04-11-2013, 09:14 AM   #6166
Originally Posted by Cpt.America View Post
Did you come from an RB5?
Losi
Dale.0 is offline   Reply With Quote
Old 04-11-2013, 09:32 AM   #6167
Got my rear gold springs from eBay today! Can't wait to do some testing with these bad boys!
Jetboat_Jake is offline   Reply With Quote
Old 04-11-2013, 10:48 AM   #6168
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by toyota 2jz View Post
someone please correct me if im wrong! the wide rear end will make the car more unstable? and the narrow rear end will make the car hook up in the rear?his is weird because in my rb5 wc the wide rear end was where its at! that thing was locked with the right rear camber link position! so with all that being said..is this car worth the money? i do not want to hear biased opinions because you have one! need to know if i will regret it later on!
No bias here. Buy it if you want to no ones pushing you. The rb5 is still potent anyways.
I still own two cougars, two dex210, 1 rb5 wc and the rb6. Nothing gets driven except the rb6. That reminds me I need to do a spring cleanup sale
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 04-11-2013, 10:56 AM   #6169
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by photopro View Post
Thanks again for everyone's help. I can't post the setup, but I will as soon as I can. To answer some of your questions.
Track is indoor hard packed, dry clay with clean surface (we sweep it between heats)
I'm running .5 rear hubs
White rear springs, 27.5wt, 3rd hole on tower from outside
Front is wide track, 25+4 and no shim under nose. Minimal rear anti squat.
Front shocks with 35 wt, stock spring and position.
Shorty all the way back. Orion r10 pro in rear bulkhead.
Shorty servo
Rear camber links have 2mm shim outer, 1mm inner
Front camber links are short and have 1mm under inner stud and 1mm out.
2mm under outer steering link for bump steer. None inner.
As I said before, closed cell foams made the car undriveable. Running suburbs. Changing to open cell helped a lot, but honestly, I'm shocked at how difficult it is to keep under control. By far, the most difficult car to drive out of my lot.
Brushless Mugen MBX6t
Losi 5ive on 12s
X-ray t3 2012
Tekno sct410
So every other car is 4wd and your 2wd feels out of control? welcome to 2wd You didn't mention what motor you are running, but chances are you could be better suited with a 17.5 to start, get the feel for throttle control and learning when you can and can't use it.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 04-11-2013, 11:13 AM   #6170
t8rtot's Avatar
Trader Rating: 14 (94%+)
+100 what motor do you have hanging off the back?
i'm not sure if you've driven much 2wd in the past but its gonna be a ton harder to drive then 4wd. and you certainly can't smash on the throttle coming out of a corner.
throttle control
Sfida
t8rtot is offline   Reply With Quote
Old 04-11-2013, 12:15 PM   #6171
Trader Rating: 20 (100%+)
Thumbs up
lol thanks man
toyota 2jz is offline   Reply With Quote
Old 04-11-2013, 12:39 PM   #6172
Trader Rating: 27 (100%+)
I am in desperate need of a front set of Clay compound AKA handlebars. If your LHS has some please pick me up a set and PM me. Thanks
Kyosho, Lunsford Racing, Express Motorsports, Dibrino Designs.
C_Money is offline   Reply With Quote
Old 04-12-2013, 09:32 AM   #6173
Yeah, everything else is 4wd, but the first 15 years in r/c were all 2wd. Honestly, I grew up on indoor clay, running Associated RC10's, all carbon fiber, stealth tranny, both buggy and truck, and held more AMain wins and tack records than I can count. Used to run reedy 13 or 14 turn motors, and never had to baby my cars like I need to with this. Years later I ran 2wd nitro rc10GT.
I'm going to stiffen the front, move the battery back, and add some weight and see what happens.
I'm running two motors. 17.5 and 7.5.
photopro is offline   Reply With Quote
Old 04-12-2013, 09:34 AM   #6174
t8rtot's Avatar
do you have the same issues with the 17.5 as the 7.5 ?
Sfida
Old 04-12-2013, 09:43 AM   #6175
Check losi parts house
Old 04-12-2013, 09:56 AM   #6176
Yeah, no different. I run the punch control on the Orion r10 pro at 2 or 3 on the 7.5 to reduce power. It's pretty docile and still all over the place. Even on asphalt or carpet. It's starting to tick me off.
Old 04-12-2013, 09:57 AM   #6177
If narrow rear hangers make it push, than that's what I'm going to try.
Old 04-12-2013, 11:38 AM   #6178
gelshocker's Avatar
Hey guys do you know what body this is?
http://eos.redrc.net/wp-content/gall...i-krappact.jpg
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 04-12-2013, 11:40 AM   #6179
Kellen Guthrie's Avatar
Wide hangers are better on high bite. Narrow hangers on low bite. Try going to a softer rear spring, lay the rear shocks down (on the tower), go to the inside hole on the rear arm, or lower the rear roll center.
LRP America
Kellen Guthrie is offline   Reply With Quote
Old 04-12-2013, 12:06 PM   #6180
eper's Avatar
Trader Rating: 14 (100%+)
maybe u have a bent hinge pin or something they do bend easy on the 6.. i would go through the car it seems like you have something besides set up issue that are effecting you.. how tight is your diff.. i find this car likes a snug diff
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22943 Today 07:07 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Jeff Werner
