    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 09-12-2012, 09:22 AM   #601
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Run a pack through your gearbox first and see if it breaks in (it should). And I would never use grease in your gearbox as it will only add drag. I use a couple drops of light bearing oil on the gears and it works great, with no added drag.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 09-12-2012, 09:25 AM   #602
gelshocker's Avatar
Originally Posted by lewis4x4 View Post
Does anyone else have this same issue? When I put my transmission together, it does not seem to be as free as other makes (Losi, Team Associated, etc..) I've backed the screws out as far as I can without coming out of the backplate, so I know it's not that they are too tight... Just seems that when you turn the outdrives, the spur does not want to spin real free... Thoughts and suggestions would be greatly appreciated...
You going rear motor or mid? Rear motor should be the same as rb5. I followed the sticky on this offroad forum and used a little shock oil. No problems first time round and every time. Cheers,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 09-12-2012, 09:31 AM   #603
eper's Avatar
Trader Rating: 14 (100%+)
Check and makesure all your bearings are pressed in all the way sometimes they dont seat all the way also check each bearing seprately also check that the top shaft bearings are in the proper location some guys accidently put the output side bearing in the transmission housing when in fact it goes in the spacer
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 09-12-2012, 10:19 AM   #604
Derry's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Jamison R View Post
+1 doesnt make me too confident when buying the most expensive 2 wheel buggy on the market.
I feel the same way... arms, alum wide brace, front axels and hex's, no alum steering rack like the pics, no vented slipper, .5 alum hubs.... I wish Tebo would just release a setup that is using all the parts that come with the car.
Associated B64D
Associated B6D
Derry is offline   Reply With Quote
Old 09-12-2012, 10:29 AM   #605
lewis4x4's Avatar
Yea, I like to use a little bearing oil instead of grease but they always seem to have drag. I'm going rear motor so it's just like the SC and RB5. This one doesn't feel any different than a RB5 does its just that I don't like how they feel. they just are not as free as I would think they should be.
Brian "B-Daddy" Lewis
XRay, Proline, Absolute Hobbyz, RC America, Airtronics, Murnan Modified Motors, Team Trinity, Kustom RC Graphics, Schelle Racing, MIP, LFR, StickIt1 Racing, Team Lewis Racing
lewis4x4 is offline   Reply With Quote
Old 09-12-2012, 10:38 AM   #606
eper's Avatar
Ive built tons of them and mine are all very free.
new milford ct,
Old 09-12-2012, 10:47 AM   #607
pli
Got my RB6 today! Also got the Orion VST 7.5/R10 Pro motor/ESC combo.
Build commence!
pli is offline   Reply With Quote
Old 09-12-2012, 10:52 AM   #608
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
The car comes with narrow and wide rear pivots. They are just plastic. The AL are just a durability options.
I think the rear arm change and the front hex are more for his personal preference on the feel of the car and not for performance.
As for the hubs, that is just a standard tuning option. The .5 hubs might work for your track and they might not. He needed more toe for that track that weekend so he put those hubs on.
Now, as for the steering rack, the rack was said to be a prototype and not with the kit on the day it was announced. I know we would all like to see an AL rack, but I don't want to see the price go any higher. Someone will make an optional AL rack sooner or later.
The vented slipper does seem to be an odd omission. I will admit that.
We all have to remember he is going to change the car however he sees fit to get it to be fast and drive the way he wants. We also have to remember that setups for our local tracks will probably be different from what he runs. I know on my RB5 I run different shock oils(front and rear), rear links and rear anti-squat than he did at the time. It was all to get the car to feel how I want it to feel and work on my local tracks while running the tires I wanted to run(also different from what he runs on similar surfaces).
Factory setups should only be used as a guide unless you drive on the same exact track he did at the time he made the setup.Even then it may change depending on the grip the track has that day.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 09-12-2012, 11:03 AM   #609
Derry's Avatar
Yeah, I realize that... I should have been more specific. I meant I wish he would release a base setup using all the parts that come with the car, kinda like Ryan C did with his "all clay tracks" setup.
Associated B64D
Associated B6D
Old 09-12-2012, 11:03 AM   #610
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
I have had a bad case before. If I remember correctly, it was burrs around the bores for the top shaft or the actual gear on the top shaft was rubbing. Check all those bores thoroughly and hit em with an xacto.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 09-12-2012, 11:12 AM   #611
Rfury's Avatar
It is alright. That really wasn't directed specifically at you.
If you build the kit and put everything as it is in the manual, you have the base starting setup for any Kyosho car. They just don't post or produce a setup sheet based on those settings.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Old 09-12-2012, 11:26 AM   #612
Anyone hear of a US release date yet?
Bluehills315 is offline   Reply With Quote
Old 09-12-2012, 11:31 AM   #613
Rfury's Avatar
Late this month or early next month. If you don't have a pre-order in now, I doubt you can get one till sometime in October.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Old 09-12-2012, 11:51 AM   #614
Trader Rating: 91 (100%+)
I think Tebo's Supernats setup might have some compromises in the setup due to the tires used, IMO suburbs aren't the best tire for WCRC, so he may have ran the .5 hubs to compensate.
Eric Tomczyk is offline   Reply With Quote
Old 09-12-2012, 11:53 AM   #615
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Did you clean out your bearings? I know on my wc kit my bearings were packed with grease and once I cleaned them out it got better. Then followed with a break-in, like Captain said it got even better.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Yesterday 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
