    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 04-09-2013, 03:12 PM   #6121
Smile
Originally Posted by aloksatoor View Post
Yeah I did. Just think the exotek aluminums a lot harder than the kyosho so ordered the kyoshos in aluminum.
I use( Mooslick) from COW/RC on all my friction areas. Stuff works great... Just tryin to help.
slashdog is offline   Reply With Quote
Old 04-09-2013, 03:21 PM   #6122
Where does the aluminum rack need to be shimmed?
Dale.0 is offline   Reply With Quote
Old 04-09-2013, 03:45 PM   #6123
aloksatoor's Avatar
Trader Rating: 42 (100%+)
The exotek needed some thin 4mm shim on the flanged side of the flange. It came on a small slip of paper with the rack. Not sure the kyosho is the same way.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 04-09-2013, 03:47 PM   #6124
aloksatoor's Avatar
Haha that site is a blast btw but they are OOS on lube. I just use dry film crc silicone or graphite powder or my road bike stuff whatever is nearby and not empty.
Old 04-09-2013, 03:57 PM   #6125
My exotic rack didn't come with any shims
Old 04-09-2013, 04:05 PM   #6126
aloksatoor's Avatar
Mine did not its just a recommendation.
Old 04-09-2013, 04:37 PM   #6127
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
KYOUMW519GM or KYOUM720B ? both are listed as upgrades to the stock piece for the RB6 on amain... but not sure which fit? Also, how about the ST piece SPTSTUM131GM ?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 04-09-2013, 04:53 PM   #6128
I ordered the KYOUM720B and it fit. Two races on it so far, and is still straight.
Old 04-09-2013, 05:17 PM   #6129
aloksatoor's Avatar
the 720 is the right part. The others for older rb5 width. The front bulkhead also is listed wrongly (Ghead brass for RB6).
Old 04-09-2013, 07:28 PM   #6130
Super Moderator
thanks guys, appreiate it.. my stock one is so bent it looks like a crazy straw.
- RCSpecialties -
Old 04-09-2013, 07:33 PM   #6131
gelshocker's Avatar
IMHO it was surprising and disappointing the steering could not use a metal bearing. One more area to unnecessarily maintain. My RB5 is that more streetwise and I always fall back to it.
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 04-09-2013, 09:16 PM   #6132
eper's Avatar
Trader Rating: 14 (100%+)
to put a bearing into the rack would automatically add the slop you guys are trying to avoid.. in order for a bearing to work there are tolerances which means play.. ita just the way it is. the only bearing you would be able to put in there and have limited slop would be some type of tapered needle bearing and that would just be over kill.. i qould also love to remove the play from my car but it is what it is. If you wanted to limit the slop and use a bearing you could tap a hole in the side of the ackerman bar and put a set screw in there to stabilize the bearings out diameter. but you will still have some play between the screw and the inner diameter and then of coarse the tolerances between the balls and races.. I all honesty in offoad racing the front of that car is vibrating and bouncing all the time i doubt there would be any huge advantage to getting it slop free.. on road may be and advantage but not really here.. JUST MY OPINION not trying to piss anyone off
and atleast its not as bad of a mess as that losi rack that actually starts to bind up from heat if your a super aggresive driver
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 04-09-2013, 09:32 PM   #6133
Trader Rating: 54 (100%+)
I'm having an issue on corner entry, the car seems to push. I'm running the stock setup with a shorty batterie with barcodes. Which is tire of choice! Ny help
Speedychris22 is offline   Reply With Quote
Old 04-09-2013, 09:57 PM   #6134
gelshocker's Avatar
My limited rc knowledge and engineering aside, I can't see how adding a bearing would add slop. The bearing only moves/rotates in one dimension, put in a high torque servo and your steering is rock solid.
It is by using moving friction parts that causes slop eventually. Delrin would be the best alternative as it minimizes friction and thus wear and tear. My 2 cents, not trying to start an arguement! Cheers,
Kyosho RT5 | RB6
Old 04-09-2013, 10:14 PM   #6135
silvalis's Avatar
Trader Rating: 29 (100%+)
You're forgetting that this is the real world and real bearings don't perfectly operate in one dimension, especially in applications like this where there would be a significant periodic axial load (when you land)
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22979 Yesterday 10:09 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
