    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 04-08-2013, 12:44 PM   #6106
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by carbons2k View Post
does anyone know.. in a pinch, would a losi 22 diff work in an rb6? I dont know what my problem is but I keep breaking off the ears in the diff nut when tightening, and I dont even tighten it that much!
The best fix, is to use the Exotek alu diff nut! I have them in all my K cars, and it is money well spent. Youll need blue loctite to go with it.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 04-08-2013, 01:06 PM   #6107
Trader Rating: 91 (100%+)
Not sure about the tlr one but the Tamiya diff nut is a perfect fit, they make a nice alloy one.
Just leave him alone, he knows what he's doing!
Eric Tomczyk is offline   Reply With Quote
Old 04-08-2013, 06:50 PM   #6108
eper's Avatar
Trader Rating: 14 (100%+)
Originally Posted by slashdog View Post
Thanks man..
dont thank me thank kyosho, they made a great kit
thats weird carbon2k i never had any issue like that. did you squeeze the spring with pliers to make sure it doesnt bind.. and is everything seating properly. the only problem i had with that white piece is you will never remove it and reuse it. i have since gone with the exotek one and couldnt be happier. i wouldnt use a losi diff part in anything their new diff isnt very good. i have actually helped some tlr guys figure out a way to use the entire ae diff in the losi cars, except the gear. that tlr screw and thrust plates are really a problem
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 04-08-2013, 08:08 PM   #6109
Trader Rating: 20 (100%+)
Originally Posted by Chris11692 View Post
i have a very clean loaded rb6 for sale if anyone wants it. thanks Chris
pm'ed
toyota 2jz is offline   Reply With Quote
Old 04-08-2013, 08:18 PM   #6110
can the rb6 use saddle packs from the lazer sp in rear motor config? been hearing yes and no all weekend long lol gettin ready to order mine in a few days! totally stoked about the car
Old 04-08-2013, 08:26 PM   #6111
Z00M's Avatar
Trader Rating: 15 (100%+)
Yes you can. I run mine with saddles.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 04-08-2013, 09:29 PM   #6112
Thumbs up
thank you very much!
Old 04-09-2013, 03:00 AM   #6113
1fastdude's Avatar
What size is the outer bearing in the aluminum rear hubs?
Team Horizon-Team Spektrum-Tekno-Kyosho*B-FAST R/C Performance*TQ Racing Wire Products-TNT-FX.COM-Avid RC-Dynamite-*AKA*92Zero Design*
1fastdude is offline   Reply With Quote
Old 04-09-2013, 07:12 AM   #6114
DeanV's Avatar
5x13x4mm
Dean
ARC R11
XRAY T4 VTA
XRAY X12 2016
DeanV is offline   Reply With Quote
Old 04-09-2013, 10:10 AM   #6115
1fastdude's Avatar
Old 04-09-2013, 10:28 AM   #6116
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Well I did my pre season tear down of the buggy. My steering rack has become very sloppy. I have the all aluminum exotek red in there. I think the flange has worn out in the rack itself. I have since ordered the kyosho aluminum crank arms and the kyosho aluminum rack and the LA256 part and a whole new front end (arms hubs spindles).
Question is do you shim it like the exotek one as well? Also anyone else notice this with their exotek racks? If the kyosho also gets sloppy I will go back to plastic I think. Does anyone get any slop elsewhere in the front. The rears as it should be btw. Think kyosho messed up by not putting a ball bearing in there like the 1/8 scale. There is too much metal on metal friction so will use royal purple I think.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 04-09-2013, 10:35 AM   #6117
MikeXray's Avatar
Trader Rating: 73 (100%+)
Steel inserts are going to wear out the alum rack, I'm going to put some dry lube to see if it helps, I hate putting grease on them when there is so much dirt to get crammed in there.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 04-09-2013, 11:19 AM   #6118
aloksatoor's Avatar
Your right grease could make it worse I suppose. Funny thing is the alum rack still has all anodizing left the kyosho flange is the one which is worn out . Put a M4 screw in the rack and cannot tell any slop. So the exo part is solid.
If someone could just make a teflon flange that would rock. Or ball bearings. Exotek are you listening just widen the two 4mm holes so a flanged bearing will fit!
Old 04-09-2013, 12:13 PM   #6119
MikeXray's Avatar
Hmm ok so the steel bushings wore out, why would you replace the rack then? just get new bushings and screws
Old 04-09-2013, 01:39 PM   #6120
aloksatoor's Avatar
Yeah I did. Just think the exotek aluminums a lot harder than the kyosho so ordered the kyoshos in aluminum.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
