    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 04-07-2013, 04:01 PM   #6091
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Sounds like gear mesh to me
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 04-07-2013, 05:01 PM   #6092
Trader Rating: 50 (100%+)
Originally Posted by Chris11692 View Post
i have a very clean loaded rb6 for sale if anyone wants it. thanks Chris
Chris where did u get the chassis protector
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 04-07-2013, 06:21 PM   #6093
Hey guys I have question. Does the RB6 out of the box drive and handle as well as the RB5 fully hopped up? I'm getting back into 2wd buggy and want the best to start back. After buying the kit and electronics I want to be where I left off, or better than the RB5 I had. Ill just be broke after. No hop ups for a while...What do you guys think??
slashdog is offline   Reply With Quote
Old 04-07-2013, 06:34 PM   #6094
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Anybody use JC mono wheels on their buggy? Just wondering what fitment and how close the offset is.
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 04-07-2013, 06:58 PM   #6095
Life_livin's Avatar
Trader Rating: 16 (100%+)
The fronts will rub on the spindle but rears will work fine with serrated wheel nuts but they are 1mm narrower making the whole rear end 2mm narrower. Unless you have stock on jconcepts monos just use Kyosho wheels, they are far better quality and not much more expensive.
Life_livin is offline   Reply With Quote
Old 04-07-2013, 08:14 PM   #6096
K_King's Avatar
Yes it does, and you can make it drive how you want with various setups. RB5 got pretty figured out, and Im sure the RB6 will also, but out of the box its good.
Old 04-08-2013, 06:14 AM   #6097
MikeXray's Avatar
Trader Rating: 73 (100%+)
I've used a few of my old sets, typically they barely rub and after one pack, then spin free. Rears are no problem at all. The AKA rears need a low profile nut as well, they don't leave many threads to use.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 04-08-2013, 09:21 AM   #6098
eper's Avatar
Trader Rating: 14 (100%+)
the rb6 is a better car then the 5 as imo.. great right out of the box.. the only hop up that i would get asap is the front wide suspension hanger in aluminum.. and personally thats it. the rear arms that come stock alot of guys switch out but the car is better on the gullwing(6) arms I have a basic setup on the petitrc forum which is a great easy to drive starting point.. you will not be disappointed with this car
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 04-08-2013, 09:27 AM   #6099
gelshocker's Avatar
How are the Proline Velocity wheels holding up? 2wd buggy fronts and buggy rears? Thx
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 04-08-2013, 09:32 AM   #6100
It's all I run and they hold up fine.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 04-08-2013, 10:56 AM   #6101
aloksatoor's Avatar
Trader Rating: 42 (100%+)
I have 8 sets of the rears and around 2-3 of the fronts. Best wheels for me. They scratch up less than the factory ones and are the same offset. The rears need a low pro or a serrated lock nut but they don't come off easily and hold glue really well with that small lip on the outer sides.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 04-08-2013, 10:58 AM   #6102
Old 04-08-2013, 11:00 AM   #6103
Thanks man..
Old 04-08-2013, 11:02 AM   #6104
Thanks, preciatecha
Old 04-08-2013, 12:20 PM   #6105
carbons2k's Avatar
Trader Rating: 21 (92%+)
does anyone know.. in a pinch, would a losi 22 diff work in an rb6? I dont know what my problem is but I keep breaking off the ears in the diff nut when tightening, and I dont even tighten it that much!
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
