    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 04-04-2013, 05:18 PM   #6061
gelshocker's Avatar
Originally Posted by ryanpatrickgore View Post
Lost front inner hinge pin brace for xxx part no
Losa4137
Thanks will give it a try. Cheers,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 04-04-2013, 09:22 PM   #6062
Kellen Guthrie's Avatar
Originally Posted by Jetboat_Jake View Post
first day out with k car, had about 4 minutes of run time, then had to wait for my first qualifier. car feels solid off the bat, was having trouble when the car bottomed out on clay the metal chassis just wanted to stick causing the car to rapidly slow down. put on a chassis protector and that helped a little but still gotta get used to it. Local kid that runs for kyosho Collin helped me out with set up and showed me some tips that really helped a lot, still about a second slower lap times then my b4.2 but i cant complain with a second in the main tonight in intermediate stock. I have stock 5 hole pistons and he told me to go down to "tlr 55" pistons so we will try that and see how it goes.
Collin at West Coast? You should get kyosho blanks and drill them out to 55s they're better. And if the chassis is sticking that badly you can always apply shock oil to the aluminium chassis before each run to reduce friction.
LRP America
Kellen Guthrie is offline   Reply With Quote
Old 04-05-2013, 02:28 AM   #6063
Having a little bit of trouble with my kyosho wanting to slide at the end of
The corners.... Any suggestions? Comes in fine but then looses traction big Time.
Jetboat_Jake is offline   Reply With Quote
Old 04-05-2013, 04:21 AM   #6064
gelshocker's Avatar
I just received my Exotek alum diff nut. It says apply blue threadlock on the diff screw. My question is, how do I tighten/adjust the diff later on if the alum nut is glued to the diff screw? Thanks,
Kyosho RT5 | RB6
Old 04-05-2013, 05:45 AM   #6065
J-Fraz203's Avatar
Use just a dab... It's thread lock not glue you should be fine. Just use a dab!
FRAZ
!!!!!!WEDNESDAY WORLDS!!!!!! RCHR !!!!!!!!
MAMBA MONSTER 2200kv 1/8 Summit 600$
spektrum receivers 25-65 $ depending 4-sr300 2sr3300t
J-Fraz203 is offline   Reply With Quote
Old 04-05-2013, 06:47 AM   #6066
t8rtot's Avatar
Trader Rating: 14 (94%+)
It will stop the nut from vibrating lose. More or less to gunk-up the threads.
Sfida
t8rtot is offline   Reply With Quote
Old 04-05-2013, 08:45 AM   #6067
gelshocker's Avatar
Thx I use the following Xceed thread lock, is it comparitable to blue thread lock? Thanks,
http://www.xceedrc.com/product/103238
Kyosho RT5 | RB6
Old 04-05-2013, 08:59 AM   #6068
jackcarter3's Avatar
Perfect description. That's why you can let it dry on the screw before installing it.
jackcarter3 is offline   Reply With Quote
Old 04-05-2013, 09:12 AM   #6069
eper's Avatar
Trader Rating: 14 (100%+)
also apply the thread lock directly to the nut not the screw so you dont push it through the diff,, it is cleaner and gets the thread lock where u want it
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 04-05-2013, 09:25 AM   #6070
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Here is a tip for you guys... NEVER let thread lock get ANYWHERE NEAR, black thrust grease. If they come together, it turns into impregnable cement. Ask me how I know
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 04-05-2013, 10:31 AM   #6071
aloksatoor's Avatar
Trader Rating: 42 (100%+)
haha good to know. why does the exo nut need loctite though? the thing doesnt come with a nyloc end?
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 04-05-2013, 11:36 AM   #6072
Super Moderator
Correct.. no lock nut, just regular nut. I used a tiny dab of blue locktite on mine, and seems to work just as good, if not better, than a lock nut.
- RCSpecialties -
Old 04-05-2013, 12:07 PM   #6073
aloksatoor's Avatar
Also for loctite, I always use this guy http://www.amazon.com/Loctite-37643-...=loctite+stick
One stick lasted me a whole year of racing finally onto a new one now. Just dip the screw a tiny bit. Never drips. Also cures a lot faster.
Old 04-05-2013, 12:15 PM   #6074
You could try going to narrow rear suspension holders if you haven't already. This will cause other issues though. One being decreased steering.
Barcodes_v1 also give good side bite. Also a lower rear roll center will give you more traction gain through the corner.
HalfManHalfGod is offline   Reply With Quote
Old 04-05-2013, 09:46 PM   #6075
Are you still using the stock springs? If so try Gold rear...
nitroargi is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
