    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 04-02-2013, 07:29 PM   #6031
gelshocker's Avatar
Originally Posted by ryanpatrickgore View Post
Haven't broken anything yet. Just warped the front 30* block a bit and the stock front pin retainer bends after a while. Losi xxx is cheaper and never bends.
I wouldn't waste this car on an 8yr old. Give her the b4 or te 22. no parts needed other than stock. Amazing huh?
Would you have the Losi xxx part number? I assume it is the same width as the stock retainer. Thx,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 04-03-2013, 12:49 AM   #6032
Originally Posted by Theroc View Post
Thomas,
I switched to a similar setup last week.(Dunlap helped me out) Anyway its about 95% the same as your current setup. This setup is better (for me) than the one using rb5 arms, I feel its more consistant.
So if any of you want to try Trans setup... I would. 3 of us at our local track have switched to it from the TEBO variation and pefer it.
Yah the biggest thing was getting the RB6 arms to work and this was an idea I had using the inside hole on the arm instead of middle or outside like we're so accustomed to using with the old RB5 platform. Since Tebo uses the rb5 arms...he abandoned the RB6 arms and unfortunately so did everyone else. I don't think I will ever go back to the 521-1 arms as I feel there is no need as this setup has more corner speed than the rb5 flat arms, but yet easy to drive.
Dunlap is absolutely flying with this setup and its just a matter of time he wins a big race with it and will be posted on the Kyosho website. So far, everyone that has tried this setup feels that its better than the Tebo setup...plus you get to use RB6 parts. I hate the idea of buying the new car and putting on the old parts. It's just a band aid.
Let me know if your lap times improve. I'd love to hear feedback as this is just a base setup. It can always get better.
Rocky, I would love to come down....but usually working on weekends since the new job started back in Dec.
sir_thomas is offline   Reply With Quote
Old 04-03-2013, 04:13 AM   #6033
David Home's Avatar
Can anyone help me out with the correct part number for the battery brace in this picture???
David Home is offline   Reply With Quote
Old 04-03-2013, 12:26 PM   #6034
As far as I know that was a prototype part and was never offered for retail.
HalfManHalfGod is offline   Reply With Quote
Old 04-03-2013, 12:31 PM   #6035
pekow91's Avatar
Trader Rating: 45 (100%+)
I have to rebuild my thrust bearing and I lost my grease that came with the kit. A new container of 3 grams of Kyosho Drive Joint Grease sells on Amain for about $15. I wanted to know if there was a better alternative or should I just get the Kyosho stuff.
Kyosho RB6 | Kyosho MP9 TKI3E | Xray XB4
pekow91 is offline   Reply With Quote
Old 04-03-2013, 12:32 PM   #6036
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I'd just grab the AE black thrust grease... works perfect, and inexpensive. Iv never had an issue with it.
(http://www.amainhobbies.com/product_...ack-Grease-4cc)
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 04-03-2013, 12:45 PM   #6037
pekow91's Avatar
Thanks for the recommendation. I will pick some up.
Old 04-03-2013, 12:47 PM   #6038
MikeXray's Avatar
Trader Rating: 73 (100%+)
+1 The K clear grease is actually really nice, but I could never tell the difference between AE and it once the diff is built. I use AE black on every thrust in any car
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 04-03-2013, 04:05 PM   #6039
David Home's Avatar
Thank you
Old 04-03-2013, 04:54 PM   #6040
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Honestly I can't find a number, all I can find is a graphite version at amain. Next time I go to my shop I will see if I can get a part number. It is worth trying if you have been bending braces, mine is rock solid now
ryanpatrickgore is offline   Reply With Quote
Old 04-03-2013, 08:02 PM   #6041
I went to my first race in twenty years tonight...I repeat...I "went" to my first race tonight...I was running some practice laps at AMS in Flint,Michigan...nice clay track...I am running my rb6 mid motor...and I had really good traction,font and back...but a problem occurred with one set of jumps..a triple...its not hard to clear it but...on the fourth or fifth lap,I decided to clear the triple and the next turn without touching the ground...Ooooops! While in the air,I had a lot of time to think,I could tell by my excessive speed that I was going to clear that entire side of the track...maybe 7 or 8 hundred feet...maybe more...I knew my only hope was to slow my "air" speed down...so I started shaking the radio in my hands which in turn caused the car start cartwheeling...this of course brought the buggy to stall speed and it started to fall to the track as planned...but wouldn't you know,there were two other buggy's right in my intended landing zone...my only choice was to land sideways on one wheel...I chose to land on one of the rear wheels so as not to disturb my steering settings...I have performed this landing before...(I am a professional stunt driver)...anyways,wouldn't ya know it...the dang rear suspension holder broke...(plastic)...the pro shop at AMS had the parts to fix rm,but not for mm and I didn't have enough time before qualifying to turn everything around,I just packed up...so in closing,if you want a buggy that's easy to drive,nicely balanced,fast and smooth...the rb6 might be a good choice...too bad it can't take a little betty one point landing...
brwn bggr is offline   Reply With Quote
Old 04-03-2013, 08:20 PM   #6042
silvalis's Avatar
Trader Rating: 29 (100%+)
I'm not entirely sure what you just said. You did a 7 or 800 foot jump?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 04-03-2013, 08:23 PM   #6043
Super Moderator
hes kidding
Yeah.. not the best buggy for novice drivers over driving the track. Traxxas slash might be a better place to start.
- RCSpecialties -
Old 04-03-2013, 08:27 PM   #6044
silvalis's Avatar
Has anyone tried those new AKA 3ribs? Vs JConcepts Rips?
Old 04-03-2013, 08:38 PM   #6045
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
I am going through my car after running the Psycho Nitro Blast a couple of weeks ago. All I will say is... Say NO to wood jumps. My front arms, front skid plate/bumper, rear arms and rear bumper/motor guard are all trashed. The front arms nearly wore through to the hinge pins on the inner pivot.
I have replaced everything but the rear arms. I just don't have any more 521 rear arms. It might be time to experiment with the RB6 rear arms...
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
