    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 04-02-2013, 09:02 AM   #6016
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Originally Posted by Wildcat1971 View Post
yeah, now that you mention it, I have heard of the rear block breaking. Didnt really hear of broken rear hubs. Is the material just to thin around the hinge pin? My 8 year old would be driving this car probably also....So it need to be able to eat pipes and role over crash, lol.
Haven't broken anything yet. Just warped the front 30* block a bit and the stock front pin retainer bends after a while. Losi xxx is cheaper and never bends.
I wouldn't waste this car on an 8yr old. Give her the b4 or te 22. no parts needed other than stock. Amazing huh?
ryanpatrickgore is offline   Reply With Quote
Old 04-02-2013, 09:08 AM   #6017
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Originally Posted by gelshocker View Post
The kit front hinge pin holder will bend. You will need the upgraded KYOUM720B Kyosho High Strength SP Front Suspension Plate (Type-B).
It bends too...don't ask me how I know. It takes a while but it will bend as well.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 04-02-2013, 10:21 AM   #6018
BIGTIME's Avatar
Trader Rating: 82 (99%+)
Need a little help here.
Just finished the build and was wondering how tight should the diff nut be? When I spin the tires in different directions at the same time (one going forward the other going backwards) the tires rotate 1.5 turns before stoping.
Is this tight enough before I start the diff break in?
BIGTIME is offline   Reply With Quote
Old 04-02-2013, 10:45 AM   #6019
Trader Rating: 31 (97%+)
http://www.rccaraction.com/blog/2011...ed-tebo-video/
Nate
NastyPerformance.com Nate@NastyPerformance.com 847-458-4858
Time Warp race track Hobbytown LITH, IL Bodies by Sasquatch
Kyosho RB6, Kyosho ZX6, Losi SCTE 2.0
Losi XXcr Kinwald, Losi XX4 Old School
Nasty N8 is offline   Reply With Quote
Old 04-02-2013, 01:04 PM   #6020
Default RB6 Setup
I know mid motor is super hot right now, but I've been working on a setup for the rear motor RB6 that uses ALL RB6 PARTS. I'm tired of buying old gen car parts to put on my new car so I came up with this with the help of my buddy Shaun.
I don't feel that the 521-1 are faster than the RB6 arms...maybe they feel easier to drive, but slower on the clock for the most part.
Try the whole setup and let me know what you guys think. Adjust ballstud washers accordingly to your tire and grip level. Rear shock length is off the top of my head, but basically all the way up with the longest shock bottom.
Feel free to ask questions if you have em.
Thomas
sir_thomas is offline   Reply With Quote
Old 04-02-2013, 01:48 PM   #6021
deleted I will rephrase the question
Dale.0 is offline   Reply With Quote
Old 04-02-2013, 01:53 PM   #6022
kyle3333's Avatar
What are the part numbers for the mid motor config aluminum arm carriers?
JConcepts UpGrade RC
kyle3333 is offline   Reply With Quote
Old 04-02-2013, 02:25 PM   #6023
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Dale.0 View Post
Is there a reason to use the RF2 rear suspension holders instead of the aluminum ones?
Those aren't mutually exclusive. There are RF2 (Rear Front) plastic and aluminum hangers . Check out post #1
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 04-02-2013, 02:38 PM   #6024
Super Moderator
I start my break in with the diff at it's LOOSEST setting. The second the diff is tight enough to give diff action (two outdrives spinning opposite directions with the diff gear held). I break it in over and over, as I tighten the diff 1/2 turn at a time.
Break in
1/2 turn
Break in
1/2 turn
etc... etc.. until the diff is where you want it. Once it's set (tight enough so it doesn't slip). Run the car for a half pack or so, and recheck... usually needs another 1/16th turn or so after driving the car. (if memory serves)
YMMV
- RCSpecialties -
Old 04-02-2013, 02:43 PM   #6025
Thomas
Is there a reason to run the plastic rear suspension holders, instead of the aluminum ones?
Old 04-02-2013, 02:57 PM   #6026
mkorn's Avatar
After trying multiple ways of building ball diffs the best way I've found by far is:
Use 220 grit sandpaper wet with WD-40 on drive rings. Polish them until perfectly smooth and even. They will appear scratched but this is what you want. Use a piece of glass to keep sandpaper flat.
Build diff with plenty of grease.
Tighten diff beyond what you would want for ideal driving setting by half a turn or so with the slipper a little loose
Run half a battery then loosen diff to normal race setting and tighten slipper to appropriate setting
Using this method I have had my ball diffs last for months of use and they stay silky smooth. I've even taken them apart just to add grease and reassemble without new parts because they lasted so long.
Marty Korn
USA Team Manager
A Main Hobbies
ProTek R/C
SWORKz USA
mkorn is offline   Reply With Quote
Old 04-02-2013, 03:10 PM   #6027
silvalis's Avatar
Trader Rating: 29 (100%+)
I reckon the plastic hangers plus metal bushings are slightly more free than the metal hangers and white delrin bushings...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 04-02-2013, 03:59 PM   #6028
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
They're included with the kit. If you don't care about the fancy matching gunmetal parts, get the STRC blocks, but they're only available in the narrow configuration. I don't think anybody but Kyo$ho makes the alloy wider blocks.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 04-02-2013, 04:33 PM   #6029
There is no performance gain...just bling'd parts that is always on back order. The only slight gain is durability...however, I've seen people wreck the alum. rf2 block as well.....just bend the corner enough to pop the hinge pin out.
The plastic part is fine as long as you use the plastic inserts. The metal inserts wear out the plastic susp holders really fast and within a few packs you get a-arm slop.
Old 04-02-2013, 06:04 PM   #6030
Thomas,
I switched to a similar setup last week.(Dunlap helped me out) Anyway its about 95% the same as your current setup. This setup is better (for me) than the one using rb5 arms, I feel its more consistant.
So if any of you want to try Trans setup... I would. 3 of us at our local track have switched to it from the TEBO variation and pefer it.
Some asked about the plastic sus holders, They are suppose to provide more flex than the alum. I switced to those about month ago with no issues of breaking. I will switch to plastic inserts though.
Anyway T if you get a chance come down to NW and run with us!! Hit up Shawn he has been down quite a bit.
Rocky
Thomas
Sponsers: Schumacher, Santiam Hobbies, Fantom Racing, Racing-cars.com, Flawless RC, Discountrcstore.com
Theroc is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22939 Today 01:36 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
