    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 03-30-2013, 10:54 PM   #5971
Originally Posted by MikeGonzo View Post
Ahahah well that's why you got second...if you would have geared higher you would have abviously won...!!!
Gearing was more than enough for the layout and going against Micheal Losi is no easy task the kid was on fire all week.
Gitsum is offline   Reply With Quote
Old 03-31-2013, 07:46 AM   #5972
Default Junk in the tranny cover
Originally Posted by brwn bggr View Post
I was running some laps on a test track here in battle creek Michigan...very loose track,with light gravel and dirt mix...buggy was wonderful...then that alarm sounding noise...a small piece of debris had found its way into the slipper gear housing and several prices of very small stone were impregnated into both...spur and opinion...I'm running an aluminium pinion...I think the garbage got in through the motor bolt hole...is there a gasket or seal to correct this issue...
I use aluminum tape for sealing up ducting. I use a hole punch that I punch vent holes in tires to put a hole in the middle. Then slip that hole over the output shaft of the motor and trim the outside to the motor profile with an exacto. Clear the two taps that you are going to mount the motor with and that will keep dirt and small rocks from getting in. Basically a homemade gasket.
Turbo
Turbo911 is offline   Reply With Quote
Old 03-31-2013, 08:54 AM   #5973
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Installed and ran the AVID slipper clutch last night. Incredibly tunable, super easy to set, great feel, 100% consistent through the entire run. I would say better than the kyosho slipper. A tad pricy, but worth it for me. AND you get get 66, 69, and 72 spurs for you 17.5 drivers.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-31-2013, 09:01 AM   #5974
Trader Rating: 101 (99%+)
Originally Posted by IRM616 View Post
do they make allunminum RF2 or do they come in RF only for rear inner hinge pin holders for rear? Do they even make the RF2? so confused. im new to kyo. maybe a link or whatever u guys can help thanks
The very first post for this thread has all the info & specific part numbers for the Alum Rear hangers... It's worth the read if this is your first K car
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 03-31-2013, 09:52 AM   #5975
Thanks turbo....for the input on a fix for the slipper box seal...being both pinion and spur have gone south,and I need to order the spur,might as well upgrade...so a triad shaft and slipper are on the way...maybe not a bad day after all...grin!
brwn bggr is offline   Reply With Quote
Old 03-31-2013, 10:01 AM   #5976
I switched to the Kyosho steel pinions, cause the aluminum gall too easily. I think the Kyosho spur/pinion set is the smoothest and quietest of anything I have run. Interesting idea about the Triad slipper, might have to try that one. Not sure, but don't you have to change the output shaft as well with the triad?
Old 03-31-2013, 10:57 AM   #5977
^^^ If you want to upgrade to the Avid Triad slipper, you do need to purchase their Kyosho specific top shaft. While the Kyosho stock slipper is really good, the Triad (in my opinion!), an awesome upgrade. The consistency, ability to put the power down w/o wheelspin and spur selection are 2nd to none!
Old 03-31-2013, 11:49 AM   #5978
Sounds like something good to try for stock class. What about mod or scr? Around here people been having trouble burning them up in mod or sc
Old 03-31-2013, 12:56 PM   #5979
Trader Rating: 50 (100%+)
Anyone try the wide aluminum wheel hubs?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 03-31-2013, 01:13 PM   #5980
How would people compare the stock slipper Vs the WC vented slipper Vs the avid?
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 03-31-2013, 01:27 PM   #5981
IRM616's Avatar
Trader Rating: 29 (100%+)
Send a message via Yahoo to IRM616
SikLidz Custom Rc Painting-Coyote RC Raceway-BSR-Kyosho
IRM616 is offline   Reply With Quote
Old 03-31-2013, 03:32 PM   #5982
B00t13g's Avatar
Stock slipper pads are junk. I only ran the avid for their 69 tooth spur gear. Now that I'm no longer running stock I'm using the vented plates red pads and 78 t Kyosho spur.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-31-2013, 04:14 PM   #5983
silvalis's Avatar
good better best?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 03-31-2013, 04:23 PM   #5984
Default Part Numbers
I am looking for the part numbers for the plastic washer spacers on the four bolts that hold the tranny case to the motor plate. Exploded view shown um508c which is wrong, cause the have the um508c in front of me and there are not on that.
Also the motor centering spacer is also listed as um508c and that is not on it as well. Wanted to put together a emergency complete transmission for the spare parts box.
Turbo
Old 03-31-2013, 04:57 PM   #5985
eper's Avatar
Trader Rating: 14 (100%+)
ny 2mm shim will work as long as it sits flush on the tranny case. u can use plastic ones and trim thod so it sits flush. or shorten your tranny screws
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
bonzo915
