Kyosho Ultima RB6 & RB6.6 Car Thread
#5957
Hey guys. New RB6 owner here. Curious on what gearing you stock guys are using? Will be doing blinky 17.5. Thank you in advance. Love the buggy!
#5959
http://rcspeedshop.com/product_info....roducts_id=461
#5960
#5962
Super Moderator
If your pinion gear rubs on the gear cover do this. Take a silver sharpie and color the cover where the pinion gear is then install it on the car. Run the motor for a couple of throttle blips. Remove the cover and see where the silver sharpie was worn. Then take a dremel sanding drum to that area. Color that area again and repeat the process until you don't hear that noise anymore.
#5963
Shocks
Has anyone replaced the plastic shock pivot balls on the bottom shock eyelet with metal ones? If so which ones did you use?
#5964
I found going for the metal balls on shock ends was about the same as far as play goes, maybe worst so I kept the plastic ones on the 6, watching carefully not to over tighten them.
However, I found the metal ones sold with the NGC kit for the Lazer with a flat side that rest well on a wishbone were a good solution for the rear.
Can't remember the part number for them.
#5966
Thank you B00t13g.
Kraig, great suggestion.
Great information guys, thank you.
#5969
I was running some laps on a test track here in battle creek Michigan...very loose track,with light gravel and dirt mix...buggy was wonderful...then that alarm sounding noise...a small piece of debris had found its way into the slipper gear housing and several prices of very small stone were impregnated into both...spur and opinion...I'm running an aluminium pinion...I think the garbage got in through the motor bolt hole...is there a gasket or seal to correct this issue...
