    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-29-2013, 07:13 AM   #5941
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by wild gopher View Post
WTF is a whip?
Usually not as fast unless your really good at it, then it can help set you up for the next corner or, in this case, keep you on your wheels.
+ YouTube Video
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-29-2013, 07:31 AM   #5942
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
Originally Posted by Todd Putnam View Post
Killer whip.
WTF is a whip?
+ YouTube Video
God, I feel old. In this case, a "whip" is referring to the car itself and not the mid-air front tire flick. To call a car a "whip", is an old term from a couple of decades ago. I didn't think anyone used that term anymore.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 03-29-2013, 07:57 AM   #5943
asc6000's Avatar
Trader Rating: 15 (100%+)
Until Jeremy McGrath put a name on it I didn't know the thing I was doing in 70's was a " nac nac " Definitely don't remember ever whipping an rc in the old days but now the control especially on a 4w buggy is unbelievable. Airing it out and saving it is one thing but seeing the same "whip" lap after lap is a true joy.
Now, back to the RB6. Anyone using the AKA wheels ? What do you think ?
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 03-29-2013, 08:02 AM   #5944
Super Moderator
Trader Rating: 17 (100%+)
WTF is a whip?
http://www.speedtv.com/programs/unique-whips
Whip = car
popularized mid 2000's in hip hop. This show was crazy.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 03-29-2013, 08:04 AM   #5945
MikeXray's Avatar
Trader Rating: 73 (100%+)
Whip = car
Was a term long before that stupid show, and its actually WIP - work in progress
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-29-2013, 08:06 AM   #5946
Super Moderator
if ya really wanna get technical, whip came from whip the horses on your buggy.....
and I liked that show... they did some crazy stuff to cars LOL
Old 03-29-2013, 08:29 AM   #5947
jkirkwood's Avatar
They are a more flexible than most other wheels on the market. With the optional wheel insert they are comparable in flex to others. The softer more flexible wheel gives a bit more traction and by adding the rear wheel insert it will free the car up a bit. A very nice tuning aid.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 03-29-2013, 10:15 AM   #5948
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Originally Posted by gelshocker View Post
5x13x4
Thank you
ryanpatrickgore is offline   Reply With Quote
Old 03-29-2013, 10:28 AM   #5949
Trader Rating: 84 (100%+)
Will using the mid motor config change the gear ratio with the having the 4th gear? Also does anyone have a good starting point for 17.5 gearing in mid motor config?
mike_d is offline   Reply With Quote
Old 03-29-2013, 01:22 PM   #5950
Try tebos setup if you have saddles, or hara's If you have shorty packs
Mine worked well when I used it, I just went stock base setup and made changed from there.
Old 03-29-2013, 01:23 PM   #5951
Super Moderator
It does not change the gear ratio because those two gears are the same size.
Old 03-29-2013, 03:25 PM   #5952
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
yep.. doesn't change the ratio, just changes the direction.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-29-2013, 03:46 PM   #5953
Todd Putnam's Avatar
Whip = car
Correct - whip = car.
Idler gears (regardless of how many) no affect on the transmission ratio no will it affect your rollout.
Try a 30/69 for 17.5.
www.rcspeedshop.com
"Where The Fast guys Shop"
Putnam Propulsion Competition Motors and Accessories
Todd Putnam is offline   Reply With Quote
Old 03-29-2013, 07:47 PM   #5954
wild gopher's Avatar
Trader Rating: 39 (100%+)
I was getting ready to go full Devo before it was explained to me. I think I did gain some new street cred.
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 03-29-2013, 08:58 PM   #5955
gelshocker's Avatar
Hey guys which portable shock stand do you use? Since the Ks are built bottom up when at rest. Thx,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
sho yoshida
