    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-27-2013, 09:14 PM   #5926
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by lbckevin View Post
The dent in the chassis does not affect the car at all.
It affects the aesthetics
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-27-2013, 09:45 PM   #5927
gelshocker's Avatar
Exactly I might as well paint my car in puke.
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 03-28-2013, 07:43 AM   #5928
Trader Rating: 38 (100%+)
Originally Posted by Todd Putnam View Post
Here is the RC Speedshop.com's RB6 "House Car."
First Kyosho Kit I have ever assembled - extremely impressed with the quality, fit and finish. The shocks reputation has been confirmed in my opinion - they are money!
Can't wait to get it dirty...
Hey Todd, will u be getting this mostly dirty up at Ferris or Catbox?
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 03-28-2013, 07:50 AM   #5929
Thanks - I will keep it in mind...
I raced at rcmadness last week. Did have an issue with my transponder on chassis. moved to top of servo. no more issues
Old 03-28-2013, 08:25 AM   #5930
Trader Rating: 66 (100%+)
Default Setup
Does anyone have a good baseline setup for the kit stock car or point me in the right direction? Will be running on a high bite indoor clay track and will be the first outing with the Rb6.
Thanks guys.
dr_gonzo is offline   Reply With Quote
Old 03-28-2013, 09:27 AM   #5931
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Built the stock kit setup first. It's pretty dang good right outta the box! Then minor changes will most likely get you where u need to be.
Last night I played with the front hinge pin block, changing from 25 to 30* with a .5 shim on and off as well. 30* block with no shim reigned supreme at the track for me. As I felt this car has been slow mid and exit cornering. 30* gave me a tighter faster radius mid and exit. Initi corner entry really I felt no difference between the few options I tried. There is a little write up about this on petitrc in the rb6 setup shee area. Next I will play with the castor inserts. I am at 2* right now. So I believe I was at 32* total? Felt good
ryanpatrickgore is offline   Reply With Quote
Old 03-28-2013, 09:30 AM   #5932
Super Moderator
Thanks guys.
Yep.. start with the kit setup and you will be just fine. The car is ridiculous right out of the box. The only thing missing, is shock oil. With the stock 5 hole pistons i would start with 37.5F 32.5R and tune from there.
- RCSpecialties -
Old 03-28-2013, 10:22 AM   #5933
Excellent. Thank you guys!
Old 03-28-2013, 11:43 AM   #5934
I noticed that in mid config Tebo ran the RB5 wishbones the opposite way round. Does this shorten the wheel base?
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 03-28-2013, 09:45 PM   #5935
umm winning's Avatar
This is probably a really stupid question, how could I tell which degree of caster am I running...? Thanks
umm winning is offline   Reply With Quote
Old 03-28-2013, 10:25 PM   #5936
Super Moderator
There are two ways to change your caster... with your front suspension hanger, and inserts that go into the caster blocks. Look under the bumper at the bottom of the front suspension hanger, and you will see 25/30 underneith, whichever is facing forward is how much kickup caster you are running. Then you can run 0, 2, or 4 degree inserts in the caster blocks themselves for different combonations of caster (i.e. 27, 29, etc)
- RCSpecialties -
Old 03-28-2013, 11:39 PM   #5937
Anybody know a part number or the size of the larger bearings in the aluminum 0* hubs?
Old 03-29-2013, 01:18 AM   #5938
gelshocker's Avatar
5x13x4
Kyosho RT5 | RB6
Old 03-29-2013, 05:22 AM   #5939
Todd Putnam's Avatar
Not sure if I will run it outside - may just keep it as an indoor clay track whip. I love both tracks - my attendance will depend on Sydney's softball schedule.
I ran it for the first time Wednesday night @ Redneck. I raced on the wrong tires, but borrowed a set after the races and ran some practice packs and it was a different car - so impressed with this car. Killer whip.
www.rcspeedshop.com
"Where The Fast guys Shop"
Putnam Propulsion Competition Motors and Accessories
Todd Putnam is offline   Reply With Quote
Old 03-29-2013, 06:44 AM   #5940
wild gopher's Avatar
Trader Rating: 39 (100%+)
WTF is a whip?
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
