    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-24-2013, 07:58 PM   #5866
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by teeforb View Post
For mid motor, can u go mid motor ?
Very interesting question. Let me think that over... Actually, now that I think about it.. i think you kinda HAVE to.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-24-2013, 08:03 PM   #5867
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Haha! That's what I get for doing two things at once.
Let me rephrase my question. Running mid motor, can you use shorty or do you have to use saddle pack?
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 03-24-2013, 08:42 PM   #5868
silvalis's Avatar
Trader Rating: 29 (100%+)
Yep. I think you can actually shoehorn a full sized lipo in mid motor, with a short servo.
Not sure about ESC clearance behind the servo with a shorty though.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 03-24-2013, 10:02 PM   #5869
teeforb's Avatar
I see. If someone has, please post a pic
Thx
Old 03-24-2013, 10:07 PM   #5870
teeforb's Avatar
Another question.
In my rb6, I had to cut a lot of plastic out of the cover above the servo to get full steering throw left and right. Its like the top tray. Without cutting or grinding down the inner top tray, the servo horn would hit the top tray before full steering. Is this normal?
Old 03-24-2013, 11:25 PM   #5871
Another question.
Yeah it seems to happen with some servos but not with all of them...same thing here when using low profile Sanwa BLS but prefered to dremel doen the top of the hon instead
nitroargi is offline   Reply With Quote
Old 03-24-2013, 11:39 PM   #5872
gelshocker's Avatar
I too bought a Sanwa BL servo and wouldn't fit. The KO one10 fits perfectly and built against the (revised) manual/Japan team setup, the steering trim is dead on zero!
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 03-24-2013, 11:53 PM   #5873
snowmiu19's Avatar
Originally Posted by Speedychris22 View Post
this is going to sound strange but how do you adjust the droop, since there is no screws in the arms that would touch the chassis?
lol, come to think of it you are right.......wonder how too....
snowmiu19 is offline   Reply With Quote
Old 03-25-2013, 12:44 AM   #5874
silvalis's Avatar
Originally Posted by desertracerdad View Post
GITSUM is correct and this spur gear/slipper pad info should be added to the first post if you can do so Brandon...
If you want to run 17.5 stock with the Kyosho slipper assembly, the Losi (70t) spur & slipper pads are the only ones that allow you to use the stock Kyosho slipper disks, which rest on the pads entirely. The AE slipper pads wear down and the Kyosho slipper plates end up resting on the spur gear. I have tried all different types of Mfg's spur/slipper combos over the years with my K cars and the Losi spur/pads are the only the fit CORRECTLY
The AVID Slipper is a great upgrade if your budget allows and gives you the option of 66, 69 & 72t spurs if you run stock and need to reach a low FDR.
I used a knife to shave down the flat parts of the octagon on my kimborough spurs so it wouldn't sit there... then went to avids anyway.
Old 03-25-2013, 03:15 AM   #5875
1fastdude's Avatar
Trader Rating: 15 (100%+)
Will RB5 front wheels fit the RB6? What Associated front wheels fit the RB6?
Team Horizon-Team Spektrum-Tekno-Kyosho*B-FAST R/C Performance*TQ Racing Wire Products-TNT-FX.COM-Avid RC-Dynamite-*AKA*92Zero Design*
1fastdude is offline   Reply With Quote
Old 03-25-2013, 05:14 AM   #5876
corky_rc's Avatar
Can anyone send me the link on how to properly built the shocks. I came across a video guide a while ago and can't seem to find it again.
Any help would be great.
Cheers guys.
corky_rc is offline   Reply With Quote
Old 03-25-2013, 05:17 AM   #5877
Moderator
Posvar's Avatar
Trader Rating: 461 (100%+)
http://youtu.be/GE73s4Sv5SY
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 03-25-2013, 05:47 AM   #5878
eper's Avatar
Trader Rating: 14 (100%+)
couple things.. when using the ae spur gear and pads the plates DO HIT the spur.. i tuned my kyosho slipper plates with a drill and file,and a old top shaft and made them have a smaller outside diameter..free fix
second i asked about the droop issue about 5 pages back and someone said measuring the shocks doesnt do it. so are you telling me that all the 8th scale buggy setup sheets that tell you what length to set you shocks at to get proper droop are wrong.. i dont really thing so its all about what you start with and are using as a reference. its not wrong its just not the way you do it and as for my block technique you must have misunderstood what i was saying because it has nothing to do with up travel.. if you put your car on blocks at the chassis and measure chassis height then measure from the table to your say axles then subtract the difference that is a form of droop measurement. if you look at a rb 6 setup sheet the measurement most guys post for the distance from the shock eyelit to the cartridge is actually how you are setting droop but isnt a measurement of actuall droop
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 03-25-2013, 07:03 AM   #5879
Super Moderator
Yes, measuring shock length doesn't tell you droop at all. If you are hearing that term used, im sorry, but it's incorrect. It tells you one thing, and that is "shock length". If you all follow the same settings on your sheets, then you will get a consistent setup, but you are using the wrong term. I will have time to explain/type it out later, can't right now. Or PM me and I can give you my phone #, and id be happy to talk to you on lunch break today or something.
- RCSpecialties -
Old 03-25-2013, 07:28 AM   #5880
MikeXray's Avatar
Trader Rating: 73 (100%+)
Shock length is only valid if you are running identical ride height and shock positions. I believe 1/8th tend to reference total droop, where as onroad tends to use droop over ride height.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
