    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-24-2013, 12:09 PM   #5851
I am running mid motor with 2s short...would like to gain a little more rear weight bias...I'm considering mounting battery transverse...the physical space is there with some midification...has anyone tried this yet...??? Will it take the cg out of bounds...?
brwn bggr is offline   Reply With Quote
Old 03-24-2013, 12:35 PM   #5852
Trader Rating: 22 (100%+)
Originally Posted by desertracerdad View Post
Hey Matt,
If you haven't already, definitely read the 1st page of this thread as it has a lot of useful info posted. You would most likely benefit from building your 6 rear motor if its going to be run on dirt/clay or anything less than (extremely!) high grip traction (think Astroturf, carpet or most recently, SRS-Cactus). Several goods setups on KyoshoAmerica.com and Petitrc.com, along with pages of info here in this thread!
Sounds good... I did read the first page and it was very helpful. Thank you...
barton872 is offline   Reply With Quote
Old 03-24-2013, 12:42 PM   #5853
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Hara ran his 6 MM with a shorty mounted transverse at WC. Car looked good.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-24-2013, 12:56 PM   #5854
Thanks Cpt...sounds like a plan...
Old 03-24-2013, 05:30 PM   #5855
1fastdude's Avatar
Trader Rating: 15 (100%+)
Default Questions
Is the purpose of using UM506 and LAW30 front axle and hex to widen the front end?
What is the part number for the white front springs please?
Has anyone modified or used other parts to fit TLR wheels on the car? I would like to try the car and unfortunately have lots of mounted wheels on TLR rims.
Team Horizon-Team Spektrum-Tekno-Kyosho*B-FAST R/C Performance*TQ Racing Wire Products-TNT-FX.COM-Avid RC-Dynamite-*AKA*92Zero Design*
1fastdude is offline   Reply With Quote
Old 03-24-2013, 05:34 PM   #5856
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
The problem with using 22 front wheels is that it is a 9mm (i think) hex. Every other car that uses hexes (rb5-6, b4) uses a 12mm hex front and rear. You would have to somehow use the hex of the 22 in order to use 22 wheels....and even then im not too sure about the offset differences.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-24-2013, 05:46 PM   #5857
Super Moderator
Is the purpose of using UM506 and LAW30 front axle and hex to widen the front end?.
im not sure, but in looking at Tebos car, he used the wider rb5 axles, but then used the narrow setting with his caster blocks to counter the width change. So im not sure what the point is.
- RCSpecialties -
Old 03-24-2013, 05:50 PM   #5858
silvalis's Avatar
Trader Rating: 29 (100%+)
not sure what the AKA wheels are like, but i'm guessing to clear any binding on the hub?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 03-24-2013, 07:01 PM   #5859
caguilar4's Avatar
Hi everyone, a new kyosho owner to be here...
I am ordering my RB6 tomorrow, and want to order a bunch of spare parts for it. I am looking online for Kyosho springs, but I do not find them online. Anyone one of a hobby shop that does carry them? (ive been told their springs' rate and overall "feel" is best than any other spring out there... ur thoughts?)
Thanks!
RB6 | XB4 | SC10.2 | MBX6 | RC8.2e
caguilar4 is offline   Reply With Quote
Old 03-24-2013, 07:02 PM   #5860
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by jwood7 View Post
I used a kyosho back plate. Then I had to grid off the area on the vts plate were the ae spring sits and goes around so I could use the kyosho spring. the k spring is shorter and allows u to get the nut on all the way to the nylon. Don't have my car here or I would post up some pics.
I wouldn't use the K plate, there is way too much play on the topshaft and bet both are getting chewed up.
I ground down the B4 plate and used the Kyosho spring, I think the B4 spring would have been fine as well.
Kyosho Ultima RB6 & RB6.6 Car Thread-b4plate.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-2013-03-24-20.02.29.jpg
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-24-2013, 07:39 PM   #5861
Thanks!
Speedtechrc.com sells them. However, they are not listed under rb6 parts, look under rb5. Amazon also sells them but are a bit more expensive.
HalfManHalfGod is offline   Reply With Quote
Old 03-24-2013, 07:44 PM   #5862
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
I have an extra set of gold rears if you need them.....
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 03-24-2013, 07:44 PM   #5863
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
For mid motor, can u go mid motor or is it saddle pack only?
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 03-24-2013, 07:49 PM   #5864
Originally Posted by barton872 View Post
Just purchased new RB6... I have not raced 1/10 for a while??? Any advice, tips, must do's and dont's, consensus on mid engine and rear engine? I will be running initially outdoor med. track, moderate traction... transitioning to indoor clay in a few months....
Thanks,
Matt
I'd probably start with the Japan all around setup. Its a good balance of forward/side bite and cornering ability for low to medium traction tracks.
http://www.petitrc.com/setup/kyosho/...SetupSheet.pdf
Old 03-24-2013, 07:51 PM   #5865
Moderator
Posvar's Avatar
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22943 Today 07:07 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
