    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 03-23-2013, 08:36 PM   #5836
B00t13g's Avatar
What should the order of parts be to use the associated slipper setup on the rb6 and what all is needed from the b4?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-23-2013, 09:46 PM   #5837
New editable setup sheet available.
Feel free for feedback
Arn0 is offline   Reply With Quote
Old 03-23-2013, 10:27 PM   #5838
B00t13g's Avatar
Looks good!
Mackenzie Meyercord
Old 03-24-2013, 12:04 AM   #5839
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
What's the mod setup many are using? Im looking to try something new with more of a planted rear end vs my standard Tebo style setup.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 03-24-2013, 01:38 AM   #5840
steam's Avatar
B4 Pads and Spur
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 03-24-2013, 09:09 AM   #5841
Trader Rating: 84 (100%+)
Is it necessary to run a servo saver on the RB6? Or does the standard plastic servo horn hold up just fine?
mike_d is offline   Reply With Quote
Old 03-24-2013, 09:46 AM   #5842
Trader Rating: 31 (97%+)
My plastic holds up just fine
Nate
NastyPerformance.com [email protected] 847-458-4858
Time Warp race track Hobbytown LITH, IL Bodies by Sasquatch
Kyosho RB6, Kyosho ZX6, Losi SCTE 2.0
Losi XXcr Kinwald, Losi XX4 Old School
Nasty N8 is offline   Reply With Quote
Old 03-24-2013, 10:07 AM   #5843
jwood7's Avatar
Originally Posted by MikeXray View Post
Ok, so someone was saying the avid/VTS combo fits, what backing plate are you using? the one from my B4 spaces it so far out, there is no way you can thread the nut/spring combo on. I could just dremel off the lip, but I'm curious if there is another plate that is being used. I ended up using the standard b4 setup for now.
I used a kyosho back plate. Then I had to grid off the area on the vts plate were the ae spring sits and goes around so I could use the kyosho spring. the k spring is shorter and allows u to get the nut on all the way to the nylon. Don't have my car here or I would post up some pics.
jwood7 is offline   Reply With Quote
Old 03-24-2013, 11:41 AM   #5844
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by steam View Post
B4 Pads and Spur
So im not so sure about this anymore. I have been running this combo since day 1, but now the more I look at it, I think the AE pads might be a bit too THIN actually, causing the Kyosho slipper disks to actually sit on top of the PLASTIC of the gear, and not the pads. (overlaps just a bit on each side of the octagon). (Maybe I have sanded my pads down too far?)I went back to the Kyosho spur gear / pads, and it's night and day better... BUT, I can't gear properly for 17.5 as the smallest spur I can find is a 76, and I can only fit a 30 pinion. (way under-geared)
So to get my car geared right for my last race of my points series last night, I decided to CA glue two sets of AE pads together and run them double thick. Seems to work just fine... but still doesn't feel as smooth as the kyosho slipper. (note, this makes the cost of pads twice as expensive, and you have to shim your dust cover out 1mm )
So I bought an avid.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-24-2013, 11:47 AM   #5845
Super Moderator
Last night was the last race of our winter points series. 7 races with 1 drop. I had SC wrapped up going into the last night, but buggy came down to finish spots in it's last race. The RB6 just didn't have any flaws! Red army representing in a sea of B4s!
- RCSpecialties -
Old 03-24-2013, 11:54 AM   #5846
I said this many times and no one listened.
Gitsum is offline   Reply With Quote
Old 03-24-2013, 12:21 PM   #5847
Trader Rating: 101 (99%+)
GITSUM is correct and this spur gear/slipper pad info should be added to the first post if you can do so Brandon...
If you want to run 17.5 stock with the Kyosho slipper assembly, the Losi (70t) spur & slipper pads are the only ones that allow you to use the stock Kyosho slipper disks, which rest on the pads entirely. The AE slipper pads wear down and the Kyosho slipper plates end up resting on the spur gear. I have tried all different types of Mfg's spur/slipper combos over the years with my K cars and the Losi spur/pads are the only the fit CORRECTLY
The AVID Slipper is a great upgrade if your budget allows and gives you the option of 66, 69 & 72t spurs if you run stock and need to reach a low FDR.
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 03-24-2013, 12:47 PM   #5848
Trader Rating: 22 (100%+)
Default please HELP!
Just purchased new RB6... I have not raced 1/10 for a while??? Any advice, tips, must do's and dont's, consensus on mid engine and rear engine? I will be running initially outdoor med. track, moderate traction... transitioning to indoor clay in a few months....
Thanks,
Matt
barton872 is offline   Reply With Quote
Old 03-24-2013, 12:48 PM   #5849
Trader Rating: 55 (100%+)
Great job Brandon!!!
Speedychris22 is offline   Reply With Quote
Old 03-24-2013, 01:02 PM   #5850
Thanks,
Matt
Hey Matt,
If you haven't already, definitely read the 1st page of this thread as it has a lot of useful info posted. You would most likely benefit from building your 6 rear motor if its going to be run on dirt/clay or anything less than (extremely!) high grip traction (think Astroturf, carpet or most recently, SRS-Cactus). Several goods setups on KyoshoAmerica.com and Petitrc.com, along with pages of info here in this thread!
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
