    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-21-2013, 09:16 AM   #5791
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Speedychris22 View Post
this is going to sound strange but how do you adjust the droop, since there is no screws in the arms that would touch the chassis?
Adding or removing internal limiters in the shocks.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 03-21-2013, 09:27 AM   #5792
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
for those of you who is running 17.5, are you guys running mid motor? If so, how do u like it compared to rear motor?
To run mid-motor, do all you need is the extra gear? Or more?
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 03-21-2013, 10:33 AM   #5793
1fastdude's Avatar
Trader Rating: 15 (100%+)
Default Anti-squat
Here is another question, maybe dumb-maybe not.
How is Anti-squat adjusted on the RB6?
Team Horizon-Team Spektrum-Tekno-Kyosho*B-FAST R/C Performance*TQ Racing Wire Products-TNT-FX.COM-Avid RC-Dynamite-*AKA*92Zero Design*
1fastdude is offline   Reply With Quote
Old 03-21-2013, 11:30 AM   #5794
With adding/removing shims under the rear suspension mounts. However, i've only seen setup sheets that take away anti-squat by adding .5mm under the RR block. Doesn't adding shim under RF aid in rear traction when the car is under power ie beginning of the straightaway? Something I've wanted to mess with.
Another question, what is the result of a setup with a higher roll center in the rear but a lower rollcenter on the front? Seen lots of setups like that. My theory with this setup is that the car is going to roll less with high speed turns and roll more during low speed turns.
HalfManHalfGod is offline   Reply With Quote
Old 03-21-2013, 01:40 PM   #5795
Trader Rating: 38 (100%+)
Help please. Spur and pinion size. Running a race with my 9.5 motor. Any suggestion/starting point for spur/pinion size? thanks.
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 03-21-2013, 01:51 PM   #5796
Shock ends too. The rb6 comes 3 different sizes.
shark2288 is offline   Reply With Quote
Old 03-21-2013, 02:08 PM   #5797
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
And how far down you thread the shock ends. You don't want them too loose where they can strip out, but you do have 3 or so turns on or off the shaft to fine tune your droop. Quicker and easier than using/removing small limiters. In other words, use limiters and shock end sizes to get you to your "middle" setting or "ballpark" droop.. then screw in or screw out your shock end to find tune.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-21-2013, 02:49 PM   #5798
racer x 1's Avatar
Trader Rating: 27 (100%+)
few run this car mid motor even in stock. I just flipped my car to mid as its being set up for stock and plan on MAKING it work. played with it out in the street and have to say that I dont think ill have too many issues once on the track.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 03-21-2013, 03:58 PM   #5799
fullsyzz's Avatar
Trader Rating: 102 (100%+)
I'm looking into buiding a complete extra tranny. The manual shows the motor centering piece (parts callout bubble 54, Pg. 20, step 20 in the manual) as part um508c. But, parts tree um508c does not have this piece on it, along with the four plastic spacers (parts callout bubble 55) that go on the 3x35 screws for the trans. From what I can tell, those pieces are actually part um523. What's the deal with this? I'm sure I'm overlooking something.
fullsyzz is offline   Reply With Quote
Old 03-21-2013, 04:28 PM   #5800
RShockley's Avatar
The shim is added under the RR block. If you were to add one under the RF block you would add anti-squat which would increase forward traction. I don't know if you are even able to add one there though.
Richard Shockley
Kyosho RB6 / Kyosho RT5
Mike's Hobby Shop......Carrollton, TX
Kalgard / Epic Cameras / SMX Optics / Heavenly Hobbies
RShockley is offline   Reply With Quote
Old 03-21-2013, 05:30 PM   #5801
gelshocker's Avatar
Originally Posted by MikeXray View Post
I do it the long way since you're not really adjusting it very often, check ride height, then sit the car on a stand, and keep raising it until the tires are barely touching, and re-measure.
I hold up my hand and admit I haven't the foggiest what you're on about. Barely touching what? Low car stand? High car stand?
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 03-21-2013, 07:03 PM   #5803
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
I know that on my shortcourse truck I lowered the rear roll center.. This gave m truck less rear traction allowing it to slide around corners and traction roll less in the sweeper and very high grip sections. So... I would expect the opposite to take place here. Locking in the rear more and giving more grip. Last night the track was slick and I was sliding around and swapping ends so I lowered the rear link, which raised the roll center and gave me a bit more grip = less sliding out and more side bite and grip
Question: are the ghea 1.3 x4hole pistons similar to the 4 hole 55's? Besides the taper?
ryanpatrickgore is offline   Reply With Quote
Old 03-21-2013, 07:26 PM   #5804
MikeXray's Avatar
Trader Rating: 73 (100%+)
You want to measure the difference between ride height and chassis height at full droop. So i set the car on the stand, and then put something under the middle of the chassis until the tires are barely touching. Now measure under the chassis to get max height and calculate the difference. This is called the droop over ride height method, if you find blocks that work, your numbers will be different.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-21-2013, 08:15 PM   #5805
Found the answer to my question:
All things being equal, decreasing the front roll stiffness will decrease understeer/increase oversteer. Increasing front roll stiffness will increase understeer/decrease oversteer.
The opposite is true at the back. Increasing roll stiffness will increase oversteer/decrease understeer while decreasing roll stiffness will increase understeer/decrease oversteer.
______________
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
