    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-20-2013, 03:49 PM   #5776
silvalis's Avatar
Trader Rating: 29 (100%+)
It's like running the straight arms with the NCG dropdowns. All it does is lower the shock mount
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 03-20-2013, 03:56 PM   #5777
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by silvalis View Post
+1
Yes.. but also changes the "angle" of the mounting holes in relation to the angle of the arm, which lets you change holes without changing droop. On the RB5 arms, changing holes lowers or raises your droop. Inner hole more droop, outer hole less droop.
When changing between these arms guys, make sure you set the car up with the SAME droop.. otherwise the what you feel on the track isn't coming from having a different arm (whether it be mechanical grip, or a geometry change), but rather increasing or decreasing droop. (which you can do all on your own without changing arms)
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-20-2013, 06:01 PM   #5778
Originally Posted by kyle3333 View Post
I am interested in switching to the 521 rear arms. A page or so back, someone mentioned that you need to change to medium shock ends to achieve the proper droop. Does anyone know what the part number is for medium shock ends?
Tebo uses the small ones!
shark2288 is offline   Reply With Quote
Old 03-20-2013, 06:26 PM   #5779
The rb5 arms also bring the wheelbase forward 1mm when running in the middle hub position, compared to the rb6 arms in middle position.
Tom87 is offline   Reply With Quote
Old 03-20-2013, 06:38 PM   #5780
Super Moderator
I think just1more measured this and found them to be identical. But if this is the case, then once again, here is one more thing that will lead you to believe the arms themselves give you more rear traction, when it fact it's just a shorter wheelbase from the rear (which gives more rear traction), which you can achieve without changing arms.
Can anybody confirm?
- RCSpecialties -
Old 03-20-2013, 09:01 PM   #5781
Capt. What does the spacer under the front suspension mount do? I know it changes the roll center, but does adding the spacer give more or less steering?
Dale.0 is offline   Reply With Quote
Old 03-20-2013, 10:36 PM   #5782
Super Moderator
Iv tried with the .5, and with 0, and I can't feel a difference. Technically, the more shim you run, the more mid corner steering you should gain as the roll center will be slightly lower. I am planning on trying the 1.0 this week.
- RCSpecialties -
Old 03-21-2013, 12:02 AM   #5783
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Capt are you still running 30 deg front caster? Im running 25/0 but am a little twitchy, trying to smooth that out.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 03-21-2013, 04:02 AM   #5784
MrHistory's Avatar
come on guys. draw a picture if you need to but the arm pins are in the same place for the two rear arms. point a to point b. the arm could be shaped like a pretzel but if the hinge pins are the same distance apart, there is no way for the hub position to change.
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 03-21-2013, 07:20 AM   #5785
1fastdude's Avatar
Trader Rating: 15 (100%+)
Default body
I've read about 100 pages and didn't see what body is everyone using? The stock Kyosho or JConcepts Finisher or Proline Bulldog?
Team Horizon-Team Spektrum-Tekno-Kyosho*B-FAST R/C Performance*TQ Racing Wire Products-TNT-FX.COM-Avid RC-Dynamite-*AKA*92Zero Design*
1fastdude is offline   Reply With Quote
Old 03-21-2013, 07:53 AM   #5786
Finisher for me
Old 03-21-2013, 07:59 AM   #5787
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Stock body. Just got another to have painted.
Jcon is cool but thin plastic and the Proline looks like an el camino, just ugly to me
ryanpatrickgore is offline   Reply With Quote
Old 03-21-2013, 08:48 AM   #5788
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Does anyone know who makes a droop gauge for these things? Similar to what the sedan guys use.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-21-2013, 08:56 AM   #5789
MikeXray's Avatar
Trader Rating: 73 (100%+)
I do it the long way since you're not really adjusting it very often, check ride height, then sit the car on a stand, and keep raising it until the tires are barely touching, and re-measure.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-21-2013, 09:10 AM   #5790
Trader Rating: 48 (100%+)
this is going to sound strange but how do you adjust the droop, since there is no screws in the arms that would touch the chassis?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Tommy R
