    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree18Likes
Old 03-19-2013, 05:21 PM   #5761
Originally Posted by t0p_sh0tta View Post
Am I the only one that feels the opposite is true? The V2 has far more side bite, but less forward bite. The V1 can really put the power down, but really free the rear up when cornering.
At my track, everyone who ran barcodes, used v1. I'm pretty sure it was because it had better side bite.
shark2288 is offline   Reply With Quote
Old 03-19-2013, 07:19 PM   #5762
Trader Rating: 50 (100%+)
finally finished the build here are a couple of pics
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 03-19-2013, 07:52 PM   #5763
B00t13g's Avatar
What dictates how you decide on what compound to run up front? I mean you could go super soft to get more steering, but why not make up for it with setup? Looking for how everyone decides on their front compound for 2wd?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-19-2013, 09:23 PM   #5764
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
On our track the V1 provides FAR better side bite, equal forward bite. You run the V2s if you want the rear end to free up.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-19-2013, 11:21 PM   #5765
Just1More's Avatar
Here is the RB6 vs. RB5 521 arms, both are the exact same length hinge pin to hinge pin.
Mark Clark
RB6
B44.1
TC6.1
Just1More is offline   Reply With Quote
Old 03-20-2013, 12:35 AM   #5766
silvalis's Avatar
Trader Rating: 29 (100%+)
Wouldn't it make more sense to measure in a direct line from pin to pin for the RB6 arm?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 03-20-2013, 02:22 AM   #5767
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
+1
Still not sure what the 521-1 arms offer in terms of performance. I have a set I could try, but I like the way my rear is feelinng with v1Barcodes and don't get much time to test on race day.
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 03-20-2013, 05:26 AM   #5768
Johnn27's Avatar
Trader Rating: 71 (100%+)
Thumbs up
Originally Posted by kwiksi View Post
+1
I built and raced my car for the first 3 or 4 race days with gull wing arms and it was ok but the rear ride height was really low when you tried to get the rear drive shafts to level out as I adjusted the ride height.
I then changed over to the 521 arms and I noticed a difference in just ride height right away. It seemed to me anyway that the gull arms brought the rear of the car down too much and I think ride height on these cars, especially in the rear is critical to handling.
other than that I hear the 521's calm the car down and give you better roll center speed. More testing this weekend.
Johnn27 is offline   Reply With Quote
Old 03-20-2013, 05:58 AM   #5769
kyle3333's Avatar
I am interested in switching to the 521 rear arms. A page or so back, someone mentioned that you need to change to medium shock ends to achieve the proper droop. Does anyone know what the part number is for medium shock ends?
JConcepts UpGrade RC
kyle3333 is offline   Reply With Quote
Old 03-20-2013, 09:56 AM   #5770
Super Moderator
post #1
- RCSpecialties -
Old 03-20-2013, 09:56 AM   #5771
Does anyone have a boosted 13.5 setup for the Orion Esc? Just need to get in the ballpark and I can workout the rest. Thanks!
Gitsum is offline   Reply With Quote
Old 03-20-2013, 09:58 AM   #5772
Super Moderator
The only difference between the 521s, and the gullwing arms, are how much/easily they flex/twist (and the fact that droop doesn't change on the gullwing arms when you change your lower shock mounting position). If you didn't change your shock collar placement and your shock ends to match droop from one type of arm to the other type of arm, that is what change you saw. The arm has nothing to do with ride height otherwise.
- RCSpecialties -
Old 03-20-2013, 11:25 AM   #5773
MikeXray's Avatar
Trader Rating: 73 (100%+)
I believe he is right because of the big difference in hub height on the gullwing and since he is referencing ride height by being bones level. If he set ride height by the chassis, the bones will be angled differently with the 2 arms.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-20-2013, 12:35 PM   #5774
eper's Avatar
Trader Rating: 14 (100%+)
if you guys are using the tebo set up with the 521 arms you should actually be running the short shock ends. do to the way the setup sheet is layed out i have seen quite a few people look at the sheet wrong and not use the correct shock end
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 03-20-2013, 01:43 PM   #5775
Super Moderator
The hub isn't higher with the gullwing, the shock mounting is just lower.. which is why you need longer shock ends. You can line up the hingepin holes in both arms, and everything lines up the exact same (geometry wise), except for how low the mounting holes are on the gullwing... which is why you run long shock ends with one arm, and shorts with the other. The angled section of the gullwing arm is so that droop doesn't change when you change mounting hole.
So when you switch to the rb5 arms, you run shorter ends, and move the shock collar up the same amount. Ride height doesn't change.
- RCSpecialties -
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22972 Yesterday 04:13 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
