    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-18-2013, 07:24 PM   #5731
Originally Posted by Losiho View Post
How do they get their cars to turn so consistently through the sweeper? How are they getting their cars to turn so sharp through the 180 without going completely off throttle? My car is so hard to hard to drive through the sweeper i'm always either understeering or oversteering and then pushes like a dumptruck on power.
HalfManHalfGod is offline   Reply With Quote
Old 03-18-2013, 07:36 PM   #5732
Tebo ran mid motor, so did the rest of the Kyosho team, my son Brandon tried it but didn't have saddle packs so it didn't handle well. He ran rear motor with Tebos WCRC setup, and made A main 13.5 after 3months with the RB6
akiyama77 is offline   Reply With Quote
Old 03-18-2013, 07:45 PM   #5733
gelshocker's Avatar
One must be part-deity to drive like that.
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 03-18-2013, 08:16 PM   #5734
joeymdz's Avatar
Send a message via MSN to joeymdz
Tires are huge along with set up.. Sounds like you need to post what set up you have and what type of surface you're on
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 03-18-2013, 09:09 PM   #5735
Running Brandon's latest with 30kickup 0 caster. Surface is indoor clay. The track is the only clay surface I've ever run on so I don't have anything to compare it to.
Tires I have
Front: all softest compounds the brands offer. Using the open cell that came with tire.
M4 Suburbs
Hotbodies Pink Fullslot<------haven't tried these yet
Jconcepts Green Barcodes
Suburbs and Barcodes felt about the same didn't really like 1 over the other
Rear: both with AKA red insert
Jconcepts Green Barcodes v1<------easily the best
Hotbodies Pink Beams
Rear traction I have for days. Could probably use a touch more forward bite on launch in straightway. Can tend to fishtail a bit. Side bite is retarded good.
Here's my track for reference: http://www.youtube.com/watch?v=TZvgZStURA8 the features seem much bigger in real life.
Old 03-18-2013, 09:18 PM   #5736
Trader Rating: 48 (100%+)
I have an issue with front wheels. With the stock rb6 wheels there is no binding. With avid wheels I have serious binding. After inspection I noticed that the avid wheels have a different offset on the inside of the wheel. Is there a way to fix this problem so I can run these wheels?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 03-18-2013, 09:22 PM   #5737
I run PL wheels that have a larger offset I just shimmed the hex out with the 1m plastic washer. LHS was out of Kyosho wheels
Tebo I think runs aka wheels and he runs parts UM506/LAW30GM to compensate for the larger offset
Can see a good picture of it here: http://www.petitrc.com/setup/kyosho/...ace2013012427/
3rd from the top.
Old 03-18-2013, 09:29 PM   #5738
Trader Rating: 101 (99%+)
I run the AVID wheels with the RB5 axles and hexes... UM506 & LAW30GM. Car steers much more consistently thru corners (both ON & OFF power), with this axle setup too with the slight addition of unsprung weight.
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 03-18-2013, 09:52 PM   #5739
Thanks guys just ordered the axles
My Credit Card
Old 03-18-2013, 10:16 PM   #5740
silvalis's Avatar
Trader Rating: 29 (100%+)
Tires I have
M4 Suburbs
Keep in mind that Brandon's setup is for 17.5 blinky. If you are running mod you will get more weight transfer
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 03-18-2013, 10:36 PM   #5741
kdub's Avatar
The offset is right, but you need to make the hex less shallow on the wheel to run the thin axle setup on the RB6. You can try the RB5 setup as mentioned without modifying the wheel.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 03-19-2013, 05:55 AM   #5742
eper's Avatar
Trader Rating: 14 (100%+)
i just take a dremel to the back of the wheel and run the stock 6 axle
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 03-19-2013, 05:58 AM   #5743
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Keep in mind the traction level at the cactus was unreal. It was like driving on sandpaper. Not your normal club race type of track prep for sure.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-19-2013, 06:52 AM   #5744
Sorry should have added i'm running 17.5 blinky.
Old 03-19-2013, 06:57 AM   #5745
Ya I know that race was a special case as they were going through tires after 5minutes of practice but even if you watch their wcrc race which Tebo called medium traction the car looks soooooo much more composed then mine.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22943 Yesterday 07:07 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
