    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-17-2013, 01:51 PM   #5701
RShockley's Avatar
Tebo takes A2 as well for the class win.
Richard Shockley
Kyosho RB6 / Kyosho RT5
Mike's Hobby Shop......Carrollton, TX
Kalgard / Epic Cameras / SMX Optics / Heavenly Hobbies
RShockley is offline   Reply With Quote
Old 03-17-2013, 02:02 PM   #5702
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Originally Posted by Cpt.America View Post
Uhm.. Tebo and the 6 looked amazing. But am I the only one that thinks there was some dirty driving in that race by the other guys in the front? Cav took one in the kiester, with no lube, 4 feet before the finish line. wth?
(edit: I spy gil losi jr, there at the end! )
I thought the same thing. It happens fast, but it looked like Maifield got into Naoto after the triple and a-holed Cav at the end. Naoto did go a little wide and maybe tried to get back into his line too late.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 03-17-2013, 02:23 PM   #5703
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Congrats to Tebo and The other members of the red army!
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-17-2013, 03:20 PM   #5704
Trader Rating: 48 (100%+)
I started the build nd have a question regarding the front hubs installing on the arms. With the 1mm plastic collar it seems to bind a little should I replace with the .5 plastic collar
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 03-17-2013, 03:45 PM   #5705
Super Moderator
I would build the kit as-is.. run a couple packs through it... and check again. The car has tight tolerances, but it will loosen up all on it's own. Same with the gears in the gearbox.
- RCSpecialties -
Old 03-17-2013, 05:29 PM   #5706
Trader Rating: 29 (100%+)
Originally Posted by revrace View Post
Does anyone know of an Aluminum Servo Horn that fits the RB6? My RB5 horn doesn't work and I stripped a plastic one recently. Thanks
I put the tlr22 alum horn on mine..
Yzlvr is offline   Reply With Quote
Old 03-17-2013, 08:00 PM   #5707
vikingen's Avatar
Trader Rating: 27 (100%+)
first run of my RB6 this past weekend. have had it build and ready for a couple months, just no opportunity to run it until now.
1st drive/meet, out of the box setup.. and did far better (7th in the Amain) than I ever did with my TLR 22 after countless changes. VERY happy.
vikingen is offline   Reply With Quote
Old 03-17-2013, 08:06 PM   #5708
Trader Rating: 101 (99%+)
Default Servo Horn
I use the Kyosho LAW42 servo horns on both of my RB6's... Have had the same two servo horns for 2+years now (with KO RSX Response servo's), never skipped a beat and I run 3-4 days a week. R'Dub
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 03-17-2013, 08:10 PM   #5709
Here is a quick pic before the start of the build.
My Credit Card
Old 03-17-2013, 08:32 PM   #5710
Super Moderator
aaahhh yeah! get that started!
- RCSpecialties -
Old 03-17-2013, 09:05 PM   #5711
in regards to the caster block/arm spacing, you will only use quantity one, 1mm shim towards the back of the block (if building per the manual with a neutral/middle front wheelbase). The inserts were specifically designed to have 1mm built into them already.
Old 03-17-2013, 10:08 PM   #5712
Super Moderator
Anybody have a link to a video of A2?
- RCSpecialties -
Old 03-17-2013, 10:14 PM   #5713
Losiho's Avatar
http://www.youtube.com/watch?v=NShjpDo15UI
Losiho is offline   Reply With Quote
Old 03-17-2013, 10:37 PM   #5714
Super Moderator
Originally Posted by Losiho View Post
HOlYCRAP THAT PASS!@! Tebo was a monster that race.... maybe the best offroad race iv seen.
- RCSpecialties -
Old 03-18-2013, 04:15 AM   #5715
jelly's Avatar
yep that was awesome
like to see the setup he ran on the mid mount
jelly is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
