    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 03-15-2013, 01:56 PM   #5686
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by MikeXray View Post
Why not just sand off the shiney layer?
yeah, we do some sanding... but its still not quite teh same as being broken in on the track.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-16-2013, 09:54 AM   #5687
Originally Posted by desertracerdad
The flat/rear arms UM521, UM521-1 or UM566 work best on higher traction layouts. They lock the rear end in more and provide a more consistent feel in corners. If you do have a track where you can run these, make sure to use the medium rear shock eyelets so you can achieve the correct amount of droop & ride height. Also, you will only have 1mm of spacing between the arm and rear suspension holders (not 2mm like the kit UM713 arms). I tested in front & behind the arm and for 17.5 & 13.5, prefer the 1mm behind the arms (which is to the rear bumper).
Difference between the above three rear arms is:
UM521 = 2 hole Rr arm with RB5 SP Fr arms
UM521-1 = 1 hole Rr arm with RB5 SP2 Fr arms
UM566 = 2 hole Rr arm (same rear as UM521) with RB5 SP2-WC Fr arms
are all these are the exact same length? In other words, are all the rears the same except the shock positions?
So are the shock mounting holes different?
I have 521/566 rears but not the 521-1
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 03-16-2013, 03:53 PM   #5688
MikeXray's Avatar
Trader Rating: 73 (100%+)
Yes, the 521-1 is the inbetween hole of the 2 on the 521.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-16-2013, 05:56 PM   #5689
Trader Rating: 101 (99%+)
^^^^^ Correct ^^^^^
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 03-16-2013, 06:19 PM   #5690
Trader Rating: 49 (100%+)
Are the aluminum rear hubs a necessary upgrade
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 03-16-2013, 07:55 PM   #5691
They are not necessary, but if you race competitively they are a good upgrade as they have a larger outer bearing for durability. I have never seen anyone break a stock plastic hub, but for that added sense of security, we run them. Plus you have two more camber link mounting positions with the alum hubs.
R'Dub
Old 03-16-2013, 10:41 PM   #5692
JEFF.777's Avatar
Just saying to the people saying "sugar makes traction? Wow!" It doesn't, it helps with traction it makes the dirt at srs hold up and the dirt doesn't brake up much like other grooved tracks so sugar helps with traction it doesn't make u have traction it helps if that makes sense.
probably welding
JEFF.777 is offline   Reply With Quote
Old 03-16-2013, 11:43 PM   #5693
silvalis's Avatar
Trader Rating: 29 (100%+)
Only on the RB5/RT5/ZX5 - wasn't too hard to break one by cartwheeling. The RB6 rear hubs are more durable. That being said, you can use RB6 hubs on the others...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 03-17-2013, 10:01 AM   #5694
revrace's Avatar
Does anyone know of an Aluminum Servo Horn that fits the RB6? My RB5 horn doesn't work and I stripped a plastic one recently. Thanks
Brandon
-Kyosho America - Team Orion - AKA - VP Powermaster Fuel - DE Racing
revrace is offline   Reply With Quote
Old 03-17-2013, 10:28 AM   #5695
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
It does help the track stay together and significantly reduces the labor of track maintenance. But, it also adds traction, alot. Were you there last year? are you there this year? Last year they did nothing to the track except let it groove, it was slick, no one tire worked very well at all. For a blue groove track with the sun out and baking it...it didnt have the amount of traction it should have. Adding the sugar and then watering it into the dirt makes the dirt feel like sandpaper. Do you really think they would be running mid motor cars if it didnt add traction?
Good win for Tebo in A1, here is the video:
http://www.youtube.com/watch?feature...&v=2yws2HiesKU
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-17-2013, 12:08 PM   #5696
Super Moderator
Uhm.. Tebo and the 6 looked amazing. But am I the only one that thinks there was some dirty driving in that race by the other guys in the front? Cav took one in the kiester, with no lube, 4 feet before the finish line. wth?
(edit: I spy gil losi jr, there at the end! )
- RCSpecialties -
Old 03-17-2013, 12:32 PM   #5697
Super Moderator
With it being that grippy there was some incidents throughout the race that could have been viewed that way but it was alot of wheel to wheel racing. The incident right before the line was ....... fill in the blank. I remember Cav doing that same kind of thing to tebo (maybe it was the other way around) a couple years ago at cactus but they didnt wreck and it worked to get past him.
Old 03-17-2013, 01:11 PM   #5698
Super Moderator
Yeah, maybe there was just some bad luck throw in there... sure looked like some robust driving to me
- RCSpecialties -
Old 03-17-2013, 01:41 PM   #5699
RShockley's Avatar
Was that Mayfield that cleared out his own teammate at the line? Couldn't really see what happened very well on the small computer screen.
Richard Shockley
Kyosho RB6 / Kyosho RT5
Mike's Hobby Shop......Carrollton, TX
Kalgard / Epic Cameras / SMX Optics / Heavenly Hobbies
RShockley is offline   Reply With Quote
Old 03-17-2013, 01:50 PM   #5700
B00t13g's Avatar
And tebo takes the overall win!
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Yesterday 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
