    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 09-09-2012, 02:11 PM   #556
savageboy69's Avatar
Trader Rating: 88 (100%+)
Originally Posted by CanyonCarverR1 View Post
Thanks, I'll use it on my 2 RB6 kits.....soon I hope.
it might be best to order the 2 kits seperatly, and see if you could use the code for each
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 09-09-2012, 02:25 PM   #557
silvalis's Avatar
Trader Rating: 29 (100%+)
You can only use it once per account I think?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 09-09-2012, 02:52 PM   #558
yodace's Avatar
R/C Tech Charter Subscriber
How's the traction compared to a rb5?
yodace is offline   Reply With Quote
Old 09-09-2012, 04:58 PM   #559
Well nobody really has one except for a few people, they arent released yet
XB8 2016
XB8-E 2016
XB4 2017
Old 09-09-2012, 07:46 PM   #560
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
You can only use 1 code, once.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 09-09-2012, 07:58 PM   #561
yea, per account, most people have more than one email address, so it would take a few minutes and make another account
XB8 2016
XB8-E 2016
XB4 2017
Old 09-09-2012, 08:13 PM   #562
gelshocker's Avatar
Anybody know if Tebo was running a pair of aluminium RF2/RR2 (wide) hinge pin holders? Can't make it out from the pictures. Would it be necessary with the alum chassis I wonder? I can make out the finned SP motor plate and alum 0 deg hubs. Thanks,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 09-09-2012, 08:17 PM   #563
Trader Rating: 77 (100%+)
Yes he does.
goin2drt is offline   Reply With Quote
Old 09-09-2012, 08:48 PM   #564
gelshocker's Avatar
Originally Posted by goin2drt View Post
Yes he does.
Thanks. Looks like he was also running the old front axle with alum clamp LAW30 too. Kyosho need to release the setup.
Kyosho RT5 | RB6
Old 09-09-2012, 08:52 PM   #565
I have his first one from Hot Rod hobbies. Understand he didnt change all that much for Nats. PM me your email if you would like it.
Old 09-09-2012, 08:58 PM   #566
Trader Rating: 16 (100%+)
Send a message via Yahoo to Zach Phillips
I talked to Jared about the rb6 this weekend at the Missouri state finals. He ran the clamping front hexes and axles with the caster inserts set to a shorter width, but still ran the RB6 suspension mount. He did not run aluminum hinge pin mounts, the new ones are stronger and so are the rear hubs. He also ran .5* hubs at WCRC nationals because the track was a little loose. He also ran the original RB5 flat 521-1 arms with one hole. He said he does not like the feel of the gull wing arms.
KYOSHO | JCONCEPTS | ORION | SMACTRAC |
Zach Phillips is offline   Reply With Quote
Old 09-09-2012, 09:21 PM   #567
gelshocker's Avatar
LOL! Luckily the RB6 didn't win ROAR otherwise we'll be seeing the RB6 SP!
I am wondering if the RB6 hinge pin mounts are those that came with the RB5 carbon comp T-plate pack, therefore being carbon composite? Reading through the manual and sorting thru the pieces. The shock o-rings are the normal orange type, not x o-rings. The hinge pin bushings are metal, will need LAW32 SP bushings if I run alum hinge pin holders. The alum chassis plate is amazing though wow. The lexan wing has 3 cut-out lines for your lip/drag, which is nice little improvement over the RB5/ZX5 wing pack.
Kyosho RT5 | RB6
Old 09-10-2012, 06:54 AM   #568
eper's Avatar
Trader Rating: 14 (100%+)
Was he running the clamping front axle for any reason impaticular. U can get the same offset with either axle. Just wonder what the reason for this is
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 09-10-2012, 07:35 AM   #569
Hello..
If anyone is interested...
JE Models (Formerley JE Spares.. they have moved to a bigger premises etc)
Have 10+ of the RB6 kits in and a good assortment of spares.
email me... nick@jemodels.com
njc11 is offline   Reply With Quote
Old 09-10-2012, 07:56 AM   #570
Originally Posted by njc11 View Post
Hello..
20 more than the Xray XB9 on your site?
I sure hope this price will fall a bit.
"If you have complete control over the damned thing, you're not going fast enough."
kaan is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
