    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 03-15-2013, 05:09 AM   #5671
eper's Avatar
Trader Rating: 14 (100%+)
so who has a opinion on the guys at cactus running mid motor. i know for a fact that it doesnt work with my home track and mod motor.. for me anyhow. just trying to get some feed back
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is online now   Reply With Quote
Old 03-15-2013, 07:30 AM   #5672
Hessanator's Avatar
I guess there is a lot of traction at srs, something with adding sugar to the track. I'm Gona try it out a my track in a few weeks, but we also have a small tight track with med-high traction so it might work. I bet the feel of the car would be good at mid.
Mayhem
Dirt Heaven, Fantom Racing, Ballistik Ink, Live Rc
Hessanator is offline   Reply With Quote
Old 03-15-2013, 07:58 AM   #5673
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
I tried it out at my track and it worked fine. Probably would be great if I worked on the setup more. There is a guy who runs that way now with success. I switched back just because I prefer the feel of driving rear motor configuration. I am so used to it.
ryanpatrickgore is offline   Reply With Quote
Old 03-15-2013, 08:06 AM   #5674
MikeXray's Avatar
Trader Rating: 73 (100%+)
Does the car jump differently in mid? I feel like it should want to pop off the jump less.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-15-2013, 08:10 AM   #5675
Off the lip seemed pretty similar after I went to stiffer springs, before i stiffened up at first it was too soft, and not much lift like you thought. I can say it definitely flies nice and level through the air.
Old 03-15-2013, 09:39 AM   #5676
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I find that mid motor cars feel better almost any time the car is neutral throttle rolling), or off throttle. Sweepers, entrances and mids of 180s, jumping, landing, all better with a mid motor car. When traction isn't REALLY REALLY high, they feel WORSE in on-throttle situations where you need to get on the gas early and hard... like maybe a tight 180 that has a tiny run up to a larger jump. You wont be able to put the traction down to get over the jump. What you get is tire sping up the jump face with a kicked out rear-end, and your lap times suffer in general.
Now, if traction becomes high enough where that issue goes away, the mid motor car will excel everywhere on the track. So it depends on the traction level AND the nature of the track (slow and tight, or big and fast with larger sweeping corners) The only time you will really generally see that kind of traction is on a carpet or turf track. I have never heard of adding sugar to a track, but word is, traction at that track is exceedingly high.
Anybody have a video?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-15-2013, 09:49 AM   #5677
I heard it eats tires really fast too
Old 03-15-2013, 10:55 AM   #5678
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
They are using a fertilizer spreader to spread it then watering the track. The first treatment was over 400 lbs of sugar.
We did something similar to a track around here. Traction was high but it would stink very bad for awhile after you apply the sugar. We used corn syrup.
Tire wear is supposed to be astronomical out there this weekend. We did not have any real issues with it on the track we treated. The tires are one 5 min run and done at Cactus this weekend.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 03-15-2013, 11:08 AM   #5679
eper's Avatar
wow that is a lot of tire wear. i believe that surface is always abrasive. a guy ran mm in 17.5 at my home track which is low traction and i drove it. it actually felt really good. just not sure how it would do in mod. last time i went out and tried a new setup tebos last one i absolutely hated the car. but because of who he is i kept chasing that set up trying to get it to work for me. needless to say it was a complete waste of three weeks. so its really going o take a lot to get me to go through that BS again
as for sugar on the track thats great for outside but would probably cause an ant infestation on a indoor track
new milford ct,
Old 03-15-2013, 12:08 PM   #5680
Rfury's Avatar
http://www.liverc.com/news/special_f..._with_that%3F/
Just an example of tire wear this year...
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Old 03-15-2013, 12:19 PM   #5681
aloksatoor's Avatar
Trader Rating: 42 (100%+)
If that surface is that sticky, why not go with a hard compound to minimize wear? Its just silly to throw good tires out after 1 quali run.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 03-15-2013, 12:23 PM   #5682
Rfury's Avatar
My understanding is that they are running some of the hardest compounds the tire manufactures make. Proline guys are running MX, JC are running Orange and AKA are running whatever is their hardest.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Old 03-15-2013, 12:49 PM   #5683
B00t13g's Avatar
I would kill to have that kind of traction at every big race, but I wouldn't want it for club racing.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-15-2013, 01:37 PM   #5684
Super Moderator
My home track at Bremerton is lucky to have best of both worlds. We have really high traction with our indoor clay, and almost zero tire wear. A set of gold barcode rear tires will last you a couple months running twice a week. Tire wear is so low, that the problem is actualy breaking them in! I have 3 or 4 hard practice runs on my latest set, and they still look 99% new... (which isn't good, because traction is low until they are broken in)
- RCSpecialties -
Old 03-15-2013, 01:53 PM   #5685
MikeXray's Avatar
Why not just sand off the shiney layer?
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22955 Today 12:08 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
