    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-14-2013, 04:33 AM   #5656
Trader Rating: 48 (100%+)
Hey Brandon how do you know if you have bump steer?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 03-14-2013, 06:18 AM   #5657
Trader Rating: 23 (100%+)
Originally Posted by steam View Post
There are 2 RF2 (fronts) in the kit, one has a thin sidewall which breaks and you aren't supposed to use and one has a thicker sidewall which is much stronger.
Check your parts
The extra RF2 block(the stronger looking one with counter bores on the top) is for mid motor. It has clearance holes for the screws to pass thru to the mid motor bulkhead which keys into the pivot and holds it all together. If you try to use it for rear motor the screws will not get tight.
Brandon, maybe you can post this on the first thread. I'd hate to see someone struggle with the handling of their car due to antisquat changing from the RF2 block coming loose.
Mike Coreia
Bumps & Jumps
www.bumpsandjumpsrc.com
Mike C is offline   Reply With Quote
Old 03-14-2013, 06:28 AM   #5658
MikeXray's Avatar
Trader Rating: 73 (100%+)
Interesting, how can you be the first one to notice that??? I'm running RF and have not tried RF2 yet, but if the skinny one is the only one that works, I'm going to wait until the alum parts are back in stock..
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-14-2013, 06:31 AM   #5659
I actually mentioned this earlier in this thread. I'm a machinist/tool and die maker. I'm fussy about everything but the counterbores on the top gave it away.
Mike Coreia
Bumps & Jumps
Old 03-14-2013, 07:07 AM   #5660
MikeXray's Avatar
Is there room to use a longer screw and a mini nut?
Old 03-14-2013, 07:26 AM   #5661
You might be able to do that using a low profile, non-nylock nut like the ones used on the shock towers. The other problem will be you will lose some motor adjustment. If you're running stock you might have a problem with getting the motor far enough forward to run the gearing that needs to run.
Mike Coreia
Bumps & Jumps
Old 03-14-2013, 07:48 AM   #5662
MikeXray's Avatar
Ok, you had me confused, you are talking about the rear block, and you are right, there are actually 2 versions of that, but if you follow the manual you should not end up with the wrong one, the thick/skinny RF2 they are talking about is for the front mount, and the only one actually marked RF2, I don't know why the rear ones are not marked.
Old 03-14-2013, 08:31 AM   #5663
Sorry, i read your post quick and didn't realize you said rf2. I only had one RF2 block with my kits. the other one is the RF(narrow).
Mike Coreia
Bumps & Jumps
Old 03-14-2013, 08:59 AM   #5664
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
How can this be?
There should be a total Of 6 blocks in every kit. 2 rf2 loose in te mid motor parts bag. The other 2 rf2 and 2 rf are on a parts tree. The blocks in the bag are the Beefey pair
ryanpatrickgore is offline   Reply With Quote
Old 03-14-2013, 09:27 AM   #5665
Originally Posted by ryanpatrickgore View Post
How can this be?
I guess there is 6. The pivots on the trees are RR/RF(narrow),RR2/RF2(wide). I keep forgetting the other blocks come from the mid motor bag. They are RR2 and RF2. Like I said, i read his post quickly and over looked where he was talking about the front block. I assumed the he was talking about the mid motor RR2 block which won't work in rear motor due to not having enough material for the screw to bite into.
Mike Coreia
Bumps & Jumps
Old 03-14-2013, 09:28 AM   #5666
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Set your toe at 0 degrees with the car sitting at running ride height... press the front end to the ground and see if you have 0, toe in, or toe out. You want to be at 0 with the suspension compressed. You control the "tug" on the steering blocks, which affects toe on compression, by changing the height of the ballstud ON the steering block. If you have bump-in, you need to raise the ball stud. If you have bump-out, you need to lower it.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-14-2013, 11:07 AM   #5667
thanks brandon makes sense. but outside of this test do you want to be at 0 degrees toe?
My Credit Card
Old 03-14-2013, 11:32 AM   #5668
Super Moderator
I do
- RCSpecialties -
Old 03-14-2013, 04:51 PM   #5669
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Some people use toe in/out as an tuning aid. I usually don't go more than 1 degree either way depending on what I want the car to do.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-14-2013, 06:54 PM   #5670
Right on... Thanks for the info guy's
srs70 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Gayosaka
