    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 03-10-2013, 09:51 PM   #5596
joeymdz's Avatar
Send a message via MSN to joeymdz
25/-4 was quick and responsive with no loss on the high and low speed sections. With ghea pistons 32.5f and 27.5r losi oil with white front springs and gold rears
i have a an onroad background so i like steering. The track condition was med/high bite but towards the end of the day everyone was loose so that's why i tried 25/-4. If traction was high i would of been rolling for days with that set up!!
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 03-10-2013, 10:44 PM   #5597
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
My background is all on-road as well ... outdoor asphalt TC is my RC racing class of choice... my home track in Bremerton has an indoor clay track, and an outdoor asphalt onroad track we run 4-5 months a year at. So during the summer, I get to race offroad on Saturdays, and onroad on Sundays
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-10-2013, 10:58 PM   #5598
B00t13g's Avatar
Originally Posted by Cpt.America View Post
Mid corner, I would start with roll center. Keep the same number of shims, but move your inner link inwards to the middle hole to start.
Already there! I'm really just looking to take away initial steering and move it later in the corner, which is why I was thinking caster.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-11-2013, 08:57 AM   #5599
joeymdz's Avatar
you could raise the axle and that will give your car less front grip entering corners and a little more grip on exit. I would put 1.5mm on the bottom and .5 on top (or do the drastic and go all on the bottom but it will push like a dump truck)
Old 03-11-2013, 10:35 AM   #5600
Anyone know who has Gold rear springs in stock? I cant seem to find any.
Dale.0 is offline   Reply With Quote
Old 03-11-2013, 12:26 PM   #5601
MikeXray's Avatar
Trader Rating: 73 (100%+)
Got to run again this weekend (rare to run 2 weeks in a row), last week I ran the car with 13.5 and ran my b4.1 in 17.5, the B4 was out of action so I put a 17.5 in and ran it. I was very happy with it, I ended up throwing red rears on, and using a set of M4 ghost pins with open cell foam up front over full slick/closed cell. I could probably still use a bit more steering, but at this point I still need to fix driving in a few spots that I can't get the line right every lap. Its sweet to have a car that I don't constantly want a setup change to fix an issue with..
That being said, there are a few small tweaks I want to try when I get time, I don't think I need the .5 rears in 17.5, and I would like to see how adding squat would feel.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-11-2013, 01:02 PM   #5602
Super Moderator
If you are running .5 rear hubs, but want the car to rotate better... the hubs are certainly the first thing you should change out. Sounds like you locked the rear end in too much. Go back to the 0s, you will be golden
- RCSpecialties -
Old 03-11-2013, 01:24 PM   #5603
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
He is right on the 0 degree. Dialed.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 03-11-2013, 04:26 PM   #5604
Originally Posted by desertracerdad View Post
The flat/rear arms UM521, UM521-1 or UM566 work best on higher traction layouts. They lock the rear end in more and provide a more consistent feel in corners. If you do have a track where you can run these, make sure to use the medium rear shock eyelets so you can achieve the correct amount of droop & ride height. Also, you will only have 1mm of spacing between the arm and rear suspension holders (not 2mm like the kit UM713 arms). I tested in front & behind the arm and for 17.5 & 13.5, prefer the 1mm behind the arms (which is to the rear bumper).
Difference between the above three rear arms is:
UM521 = 2 hole Rr arm with RB5 SP Fr arms
UM521-1 = 1 hole Rr arm with RB5 SP2 Fr arms
UM566 = 2 hole Rr arm (same rear as UM521) with RB5 SP2-WC Fr arms
are all these are the exact same length? In other words, are all the rears the same except the shock positions?
nitrorush27 is offline   Reply With Quote
Old 03-11-2013, 05:16 PM   #5605
Just1More's Avatar
Yes. Even the same length as the Rb6 arms(I verified this)
Mark Clark
RB6
B44.1
TC6.1
Just1More is offline   Reply With Quote
Old 03-11-2013, 05:59 PM   #5606
Awesome, thank you!
Old 03-11-2013, 07:29 PM   #5607
Super Moderator
Not a professional video or anything, but here is a normal club night race a week ago Saturday. Battled to the end with John Cantrell for all 8 minutes. Other than a few laps, he was ahead of me by 1 or 2 seconds the entire race, until a bobble just one minute before the end of the race where I got him, and held on. (he's a fast bugger!) (this layout is 10x more technical, and more obnoxious, than it looks)
Im the blue/white/orage rb6, with yellow wheels, starting in 2nd.
+ YouTube Video
- RCSpecialties -
Old 03-11-2013, 09:52 PM   #5608
Nice video, looks like a tight technical track. Goes to show, you don't need a big track to have a great race track.
Turbo911 is offline   Reply With Quote
Old 03-11-2013, 09:52 PM   #5609
Default BB Shocks
What do you use for internal limiters on the big bore shocks?
Turbo
Old 03-12-2013, 12:41 AM   #5610
silvalis's Avatar
Trader Rating: 29 (100%+)
hm. Looks like you were carrying less corner speed than him (well, everyone was). Especially noticeable on that last landing before the straight and the one at the end of the straight. Although these looked more like driving lines rather than corner speed...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 10-20-2017 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
cruz1383
