    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-10-2013, 02:40 PM   #5581
Trader Rating: 101 (99%+)
Originally Posted by motorhead68 View Post
hi, whats the purpose of the 521 1 arms? more traction or corner speed?? thanks
The flat/rear arms UM521, UM521-1 or UM566 work best on higher traction layouts. They lock the rear end in more and provide a more consistent feel in corners. If you do have a track where you can run these, make sure to use the medium rear shock eyelets so you can achieve the correct amount of droop & ride height. Also, you will only have 1mm of spacing between the arm and rear suspension holders (not 2mm like the kit UM713 arms). I tested in front & behind the arm and for 17.5 & 13.5, prefer the 1mm behind the arms (which is to the rear bumper).
Difference between the above three rear arms is:
UM521 = 2 hole Rr arm with RB5 SP Fr arms
UM521-1 = 1 hole Rr arm with RB5 SP2 Fr arms
UM566 = 2 hole Rr arm (same rear as UM521) with RB5 SP2-WC Fr arms
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 03-10-2013, 07:07 PM   #5582
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by B00t13g View Post
I want to say that's not the most current, only because Brandon went to 3mm of bump steer shims with 30mm of kick up.
Yep.. im not sure that is right (did i post that? *blush*). At 30 caster I rum 3mm bumpsteer. Its 0mm bump at 25 caster, and 3mm bump at 30 caster. Split it up for your incriments for 26, 27, 28, and 29. I measure on a setup station, or with a metric ruler.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-10-2013, 07:16 PM   #5583
OMG23RC's Avatar
Trader Rating: 21 (100%+)
guys are there any special tips for making the big bores more smooth when building them?
www.sydneyrc.com - Sydney's best off road track.
Kyosho|Associated|Viper|Schuur Speed|Savox|Sanwa.
RB5 SP2 WC|Viper vtx10 B.E|Schuur Speed 17.5|Savox 1257tg|Sanwa MT-4
SC-R|Turnigy Trackstar Turbo|Reedy sonic 10.5|BMS-616DMG|Sanwa MT-4
B44.2|Viper vtx10r|Viper 8.5|Savox 1258tg|Sanwa MT-4
OMG23RC is offline   Reply With Quote
Old 03-10-2013, 07:21 PM   #5584
B00t13g's Avatar
You would make me do the math lol. What setup station are you using?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-10-2013, 07:24 PM   #5585
Super Moderator
Hudy.
- RCSpecialties -
Old 03-10-2013, 07:46 PM   #5586
joeymdz's Avatar
Send a message via MSN to joeymdz
Played around with my caster 25/-4 and wow.. Insane steering!! I liked it over 30/-4 as it had more aggressive response to on and off power. Im running a slightly modified tbo setup
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 03-10-2013, 08:27 PM   #5587
B00t13g's Avatar
Hudy.
At 25=0 at 25+2= 1.2 at 25+4= 2.4
Does that sound correct?
Mackenzie Meyercord
Old 03-10-2013, 08:46 PM   #5588
silvalis's Avatar
Trader Rating: 29 (100%+)
Follow the instructions when bleeding? I've never had to do anything special. Were you having issues, or just curious?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 03-10-2013, 09:10 PM   #5589
Default Awesome
Must say I am very Impressed.... I got my RB6 Thursday night ... Proceeded to have a wrenching session Thursday and Friday night.. went to the track Saturday was TQ with some very tuff guy's running. Lost TQ in the 3rd round and ended up 2nd in the main!! Long time AE guy and now asking why.. This car rocks !!
srs70 is offline   Reply With Quote
Old 03-10-2013, 09:20 PM   #5590
Are you using the negatives to say that you're running the caster inserts backwards? I'm still trying to figure out the caster. I'm running 25/4 and I have a little too much turn in and the car seems to over rotate in the infield....
ChadBlanton is offline   Reply With Quote
Old 03-10-2013, 09:21 PM   #5591
Super Moderator
Ill trust your math It doesn't need to be dead smack on... only close. If you are good at eyeballing toe.. you can just eyeball it. The easy way, is to measure with a ruler just like measuring static toe.
- RCSpecialties -
Old 03-10-2013, 09:24 PM   #5592
Super Moderator
You're running 21 caster? That would be ultra sensitive in the infield.... and you might be lacking some in the faster sections. I am back to 25/2, and am in heaven. Went up in shock oil last night, and the car has never been better.
25/4 is where you want to be then... It will give you the tamest infield steering, with the least amount of pro-dive. Over-rotating in the infield sounds like a tire issue, or a static weight balance issue... without seeing a detailed setup sheet. Post the rest of your setup, and we can help you get that sorted out.
- RCSpecialties -
Old 03-10-2013, 09:31 PM   #5593
B00t13g's Avatar
I went to 25/0 and it's better, but I'm needing more steering after entry and was thinking 2 degree inserts would be the ticket as well. Ill have to try that when I get my car back. What bump steer are you running?
Mackenzie Meyercord
Old 03-10-2013, 09:36 PM   #5594
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
I am running 25/2 and I am really liking it as well. Came from 30* and this is a bit more aggressive, my car is feeling great!
ryanpatrickgore is offline   Reply With Quote
Old 03-10-2013, 09:40 PM   #5595
Super Moderator
Mid corner, I would start with roll center. Keep the same number of shims, but move your inner link inwards to the middle hole to start.
- RCSpecialties -
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22937 Today 06:57 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
