    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-08-2013, 03:11 PM   #5566
fullsyzz's Avatar
Trader Rating: 102 (100%+)
Originally Posted by Dale.0 View Post
What is the psrt number for the shock ends?
Originally Posted by mdowney View Post
S = W5015
M = 97038
L = LA43
fullsyzz is offline   Reply With Quote
Old 03-08-2013, 03:18 PM   #5567
Thank you!
Dale.0 is offline   Reply With Quote
Old 03-08-2013, 06:56 PM   #5568
joeymdz's Avatar
Send a message via MSN to joeymdz
S = W5015
M = 97038
L = LA43
this needs to be stickied!
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 03-08-2013, 07:14 PM   #5569
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by joeymdz View Post
S = W5015
M = 97038
L = LA43
I can add to post #1!! This is a good one to have there, I think.
(EDIT: added to post #1... I didn't double check that they are in fact accurate part numbers... if there is an issue, let me know? Somebody check my work.)
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-08-2013, 07:47 PM   #5570
B00t13g's Avatar
The part numbers you quoted are correct and accurate.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-09-2013, 05:07 PM   #5571
B00t13g's Avatar
I remember seeing a formula for how much bumpsteer to run for a given amount of caster and kick up. I can't seem to find it. Does anyone remember?
Mackenzie Meyercord
Old 03-09-2013, 06:27 PM   #5572
MikeXray's Avatar
Trader Rating: 73 (100%+)
Someone said recently 1mm per 3dg, I have no formula to back that up
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-09-2013, 06:35 PM   #5573
Kellen Guthrie's Avatar
Bump steer just changes the amount of toe you gain or lose when the suspension compresses. Most people set it up so that the toe stays the same through whole corner.
LRP America
Kellen Guthrie is offline   Reply With Quote
Old 03-09-2013, 06:54 PM   #5574
steam's Avatar
I had stickied this
Caster, Bumpsteer, and Ackerman math.
I decided to break out my hudy setup station, and my 2mm hex, and do some measuring for our setup sheets. Lets start with bumpsteer and caster.
Bumpsteer - bumpsteer is what happens when you induce either more toe in, or more toe out, as the front suspension compresses. (bump-in, or bump-out). You can change how much or little bumpsteer you have by controlling the vertical angle of the steering turnbuckles. The more vertical the steering link goes as the suspension compresses, the more the turnbuckle will pull the steering block inwards, inducing bump out. So to reduce bump-out, you have to reduce the height of the ballstud on the turnblock. If you get bump-in, that means you need to raise the height of the ballstud.
What some people don't realize, is that changing caster, changes the relative height of the ballstud / turnblock, because more caster rotates the turnblock backwards, so it drops the ear/stud closer to the ground. So if you run 25 caster and set your bumpsteer to 0 (no bump in or bump out), and then decide to change your caster to 30, you actually dropped the height of the ballstud by 2mm. So I did a lot of testing and measuring just to make sure that the numbers are accurate. For ZERO bumpsteer:
  • 25 caster = 0mm washer under turnblock ballstud
  • 27 caster = 1mm washer under turnblock ballstud
  • 30 caster = 2mm washer under turnblock ballstud
Ackerman - Ackerman affect is the difference between the turning radius of the inside wheel, and the outside wheel, in a corner. Because the inside of the car will natually track along a smaller circle, to maximize steering and minimize a slip angle, the angle of the tires need to match the steering radius. If you have too little ackerman, or too much, the slip angle means one tire is sliding instead of rolling, reducing steering.
I tested just two ackerman settings on the steering rack just for my own info, and got the following:
  • 0mm under steering rack ballstud = 30deg and 23deg
  • 1mm under steering rack ballstud = 30deg and 23deg
zero change in ackerman. Might have something to do with the fact that the steering turnbuckkles are right about flat, straight across /perpendicular to the chassis. I think ill test again later with my plastic steering rack to make sure it's not my alu version. More to come.
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 03-09-2013, 09:31 PM   #5575
gelshocker's Avatar
Originally Posted by steam View Post
I had stickied this
Capt. pls add the above to your opening post, Cheers!
p.s. For 25 + 4 deg (caster block), 2mm would be okay right? (Japan setup has it as 2.5mm)
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 03-09-2013, 11:14 PM   #5576
B00t13g's Avatar
I had stickied this
I want to say that's not the most current, only because Brandon went to 3mm of bump steer shims with 30mm of kick up.
Mackenzie Meyercord
Old 03-10-2013, 12:55 AM   #5577
cool car
mormat is offline   Reply With Quote
Old 03-10-2013, 05:26 AM   #5578
jelly's Avatar
Originally Posted by Posvar View Post
Mine is backwards and I like it.
what sort of track have you tried this on?
jelly is offline   Reply With Quote
Old 03-10-2013, 10:26 AM   #5579
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Our club track is outdoor red hard packed clay which develops a groove in the afternoon but also can have a loose layer of dust on top that gets blown off. I would say traction is low to medium at best depending on the time of day. By night you can run almost slicks and have grip. I feel it quiets down the steering on my car. I run a full size servo and also amb transponder on top of servo. Shorty pack in mid position.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 03-10-2013, 02:26 PM   #5580
Default rear arms
hi, whats the purpose of the 521 1 arms? more traction or corner speed?? thanks
motorhead68 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
