    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 03-07-2013, 05:11 PM   #5551
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by ChadBlanton View Post
I'm thinking of turning the steering rack backwards to "calm" the car (it's pretty pointy) this mod pushes the ballstuds back towards the rear of the car ... My question is, why are some guys running a 1mm spacer under the ballstuds on the steering rack? This pushes the studs even further forwards on the car, so wouldn't that make it even more darty?? or am I confused on the whole Ackerman theory
I haven't tested too much with this, but I did measure on my setup station... and the difference in ackerman angle (on a stock facing steering rack) between 0 washers and 1mm washers, was exactly 0. No measurable difference in ackerman angle. Not sure what that means ... it is what it is.
don't forget, you have an easy way to play with ackerman, and that is front toe-in or toe-out. I usually run dead 0, or .5 out. ... so play with 1 or even 2 out and see if that calms the car down. Eventually you start to really develop a slip angle in the front of the car, taking away steering. At some point I will have time to measure ackerman angle with different shims on the rack, and I can publish them. "when I have time" is the key
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-07-2013, 06:06 PM   #5552
thanks cpt,
anyone else running their steering rack backwards?
ChadBlanton is offline   Reply With Quote
Old 03-07-2013, 06:09 PM   #5553
Moderator
Posvar's Avatar
Trader Rating: 463 (100%+)
Mine is backwards and I like it.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 03-07-2013, 07:05 PM   #5554
RShockley's Avatar
Pic of the buggies all cleaned up and ready to go for the first round of qualifying at last weekends Bigfoot race here at Mike's.
Richard Shockley
Kyosho RB6 / Kyosho RT5
Mike's Hobby Shop......Carrollton, TX
Kalgard / Epic Cameras / SMX Optics / Heavenly Hobbies
RShockley is offline   Reply With Quote
Old 03-07-2013, 07:08 PM   #5555
Super Moderator
Love the colors...
- RCSpecialties -
Old 03-07-2013, 07:10 PM   #5556
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Have the same cars as well love them to death xb4 and rb6.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 03-07-2013, 10:24 PM   #5557
cnelson3's Avatar
Trader Rating: 66 (100%+)
I've had good luck with it backwards as well. If u hold to steering racks together ( one forward and one back wards with the hinge mounting holes lined up perfectly) u can visibly see a difference. I tried it backwards and never put it back. I hate to admit this but I finally have my buggy handling similarly to my old rb5 with a +10 mm chassis. It's fast and forgiving. Little more initial and mid corner steering tho.
cnelson3 is offline   Reply With Quote
Old 03-08-2013, 11:53 AM   #5558
Trader Rating: 38 (100%+)
has anyone tried the MIP Diff?
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 03-08-2013, 12:06 PM   #5559
Moderator
Posvar's Avatar
I can't see the pics! Have they been deleted?
Old 03-08-2013, 12:13 PM   #5560
RShockley's Avatar
Fixed it.
Richard Shockley
Old 03-08-2013, 01:15 PM   #5561
Moderator
Posvar's Avatar
Old 03-08-2013, 01:42 PM   #5562
I wonder the same. I bought one, but the original one is still so smooth i havnt felt the need to try the MIP yet. Anyone else tried oone yet?
Dale.0 is offline   Reply With Quote
Old 03-08-2013, 01:45 PM   #5563
my diff is lasting forever too ... pretty awesome stock diff!
Old 03-08-2013, 02:52 PM   #5564
aloksatoor's Avatar
I have the mip diff outdrives the whole kit for the rear. Longevity is more than the stock swing shafts at least. The diffs similar to the stock one. The hexes are definitely better. The wear seems to be better than the stockers for sure. I will keep running mine not going back to stock.
Old 03-08-2013, 03:10 PM   #5565
What is the psrt number for the shock ends?
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 11-22-2017 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Hilbouy
