    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 03-06-2013, 09:16 AM   #5521
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Speedychris22 View Post
I have a questions regarding gearing. I am trying to understand how to figure it out. Is there a page where I can get detailed explanation.
Gear your car for fastest lap times, within the motor's heat limit. The best place to look for explanations would be doing a forum search, or a google search. Or ask your question right here if you can' find what you're looking for.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-06-2013, 10:28 AM   #5522
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
I needed more torque to clear the big jump after the 180 at my track, so i geared down to 31/69... but didnt seem to do much, i got a little bit more torque out of it. thinking i am going to go back to 33/69. i asked a few ppl at the track who seemed to be clearing it with no problem. they didnt have much to say except " you shouldnt have any trouble" my slipper and diff are set correctly, but i cant seem to get the sweet spot?
running a 80c shorty with a d3.5. i just bought the gen2 17.5. maybe this will make a difference? any suggestions.?
ryanpatrickgore is offline   Reply With Quote
Old 03-06-2013, 10:40 AM   #5523
Super Moderator
In a D3.5?
What battery are you running? (what does it weigh)
1- gear at 69/31
2- run a 12.5 HT rotor
3- run end bell timing at 20degrees (all the way advanced on the can).
If you are running a super heavy pack, that might be part of the problem. The 6 is a heavy car, and for 17.5 stock, tuning with weight is super important.
- RCSpecialties -
Old 03-06-2013, 10:48 AM   #5524
Trader Rating: 50 (100%+)
where were you able to get a 31T pinion and 69t spur gear? I see Kyosho does not make any that size. Are you using a different company?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 03-06-2013, 11:07 AM   #5525
B00t13g's Avatar
Avid makes the spur gear as does kinmbrough. Rw and Robinson make the pinions.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-06-2013, 11:11 AM   #5526
MikeXray's Avatar
Trader Rating: 73 (100%+)
You will need B4 pads for this setup though, afaik no one makes spurs that use kyosho pads.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-06-2013, 11:14 AM   #5527
I wish they did make spurs for our pads. I like how they lock into the spur makes swapping spurs a breeze.
Gitsum is offline   Reply With Quote
Old 03-06-2013, 11:30 AM   #5528
Yes I run the kimbrough spur and the ae high torq pads.
The battery's are both shortys one is 60c the other 80c both brand new with this car. One is 218 grams the other is 214 grams. I just got took out the d3.5 because its getting phased out at the track,but it was nearly new and powerful. I put in a new gen2 yesterday but haven't run it yet. I hope this motor has more grunt, but hmmmm maybe a high torque rotor? I will advance the timing to 30*.
Hopefully test tonight if not tomorrow.
Wouldn't 31pinion be better for torque and clearing jumps? Rather than the 33.
Old 03-06-2013, 11:48 AM   #5529
Super Moderator
Sounds fine. I run 205 gram lipos... sweet spot for weight. The ~220s will be better for Tacoma
the HT rotor is the way to go, but it's not necessary. If you are still running your endbell timing at 0, that is the problem. Advance it as far as it will go on the can (it will not advance as far as the markings tell you it can, on the motor.)
Nope... gearing lower just SHIFTS the torque band to a lower speed. You don't gain or subtract torque by gearing up or gearing down... you just move it. But if you advance your timing all the way up, and stay with 31, you will have no problem clearing anything anybody else is clearing.
-brandon
- RCSpecialties -
Old 03-06-2013, 12:20 PM   #5530
joeymdz's Avatar
Send a message via MSN to joeymdz
^^ I would also add turn up your EPA if you haven't all ready^^
also it could be a set up issue as in your not getting enough "pop" from the rear? (I know you're running BC's set up but you could try going stiffer in the rear)
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 03-06-2013, 12:50 PM   #5531
thanks guys, i did go to red springs in the rear and it did help a bit, gave me more pop off the jumps, a little more lift. I had my timing up at ~10* previousley. I will crank it up tonight!
what would be the differnce between between 31 and 33 with max timing? mainly temperatures im guessing? otherwise, wouldnt you just want to run the 33 all the time brandon?
i had believed it was top speed before this conversation?
Old 03-06-2013, 01:04 PM   #5532
Super Moderator
Yep, if you are only at 10 on the timing, you will see a noticable improvement maxing out the timing. You CAN run 33, but from my testing, it would be slightly over-geared for your track. Tacoma is tight and slow... so gearing down to keep the car in the torque band will yield better lap times. Id gear at 33 for a larger track where the car is closer to top speed more of the time.
Trust me.. wire it back in, run 69/31 with the endbell timing turned up all the way, and check your performance on your lipo's second charge of the day and see what you get.
-Brandon
- RCSpecialties -
Old 03-06-2013, 01:54 PM   #5533
gwhiz's Avatar
-brandon
Phrasing.
It's called torque multiplication. Google it or something.
x
gwhiz is offline   Reply With Quote
Old 03-06-2013, 02:00 PM   #5534
Thanks dudes! This is the best thread that I've followed so far
Old 03-06-2013, 04:51 PM   #5535
kyle3333's Avatar
Has anyone tried this stuff? I know there is a thicker version, but I wondered if this would hold up at least for indoor racing. Plus it was the only stuff I could find wide enought to do the ZX-5.
http://www.amazon.com/gp/aw/d/B005YS..._ya_os_product
JConcepts UpGrade RC
kyle3333 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
