    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-05-2013, 10:30 AM   #5506
Nitronut3's Avatar
Send a message via AIM to Nitronut3
Originally Posted by seth556 View Post
I've been wanting to know that too. I'm running this setup http://www.petitrc.com/setup/kyosho/...WCRC201212.pdf with the wide blocks and 521-1 arms like he is in the pictures for Smac Track. I noticed his front camber link is a bit different now though.
Cody ran tebos setup at the winter nationals,
Nate Jaskot
XRAY, RC America, KO Propo, Hudy, FX Engines, Nitropro, Rc addiction products , TeamSR, SmacTrac
Nitronut3 is offline   Reply With Quote
Old 03-05-2013, 11:18 AM   #5507
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by MikeXray View Post
Have you tried laying the front shocks in all the way? how come no one runs that?
going from the middle hole on the tower, to the inside hole, is a tiny tiny change. It sounds like Ryan was looking for more steering than that. I don't start with the small things like that... I like to get my car feeling as neutral as possible, with the general amount of steering that I want, with all those settings still down "the middle". Then from THERE, you make the smaller changes to fine tune. Springs, Oil, weight, track, WB, caster... these are all the big guys.
Originally Posted by ryanpatrickgore View Post
Thanks Brandon. I have gone back to reds at the moment already and it felt good. This car has so much traction, I feel like I gave none up goin from golds to reds. I will give the castor change a shot. Thanks guys
Edit. Haven't tried laying shocks down yet, just because nobody does it like you said. Probably worth a try tho
I gotta get out to TRCR more!! the dang drive, AND bridge toll, always keeps me away. Maybe ill make it out this Friday.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-05-2013, 11:30 AM   #5508
toast.'s Avatar
Originally Posted by Cpt.America View Post
yeah! i haven't run the ions yet on my track, but a tire with a nice low pin like that, looks good. Side bite seems (looks) like it might be inbetween a bar code and a suburb... but not sure. Also not sure about the compound. The only downside, is they are expensive!
I was thinking about getting "ION 2.2" M3 (Soft) Off-Road Buggy Rear Tires"
Should I use "ION 2.2" 4WD M3 (Soft) Off-Road Buggy Front Tires" in the front?
Main ION tire link
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SCT410, SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 03-05-2013, 11:42 AM   #5509
Super Moderator
Originally Posted by toast. View Post
I was thinking of doing exactly this, as the 2wds aren't out yet. It's a bigger tire... so it will change how the car drives, based on the width alone.. but might give a good idea on how they will drive. If you have the time, you could always cut down a set of 4wds to the width of a 2wd for testing.
- RCSpecialties -
Old 03-05-2013, 08:50 PM   #5510
Trader Rating: 31 (97%+)
if you use the exotek shock posts, do you still need the small nut first? or can u eliminate.
thx
Jay
Jason Collins
Losi 22 3.0 & 22-4
Friday night @ Island Raceway & Hobby
Jay rb5 is offline   Reply With Quote
Old 03-05-2013, 09:23 PM   #5511
silvalis's Avatar
Trader Rating: 29 (100%+)
Pretty sure you need the nut, but not the washer/spacers + ball.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 03-05-2013, 09:45 PM   #5512
silvalis's Avatar
Anyone tried to jam an LRP Flow/Nosram Comet esc under the bulkhead? I'm not sure how tall these are...
Old 03-05-2013, 09:48 PM   #5513
B00t13g's Avatar
I'm 90% sure it would fit, I never tried mine though.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-06-2013, 03:58 AM   #5514
Bcholka's Avatar
thx
Jay
A number of pages back there was mention of using the Exotek posts and the concern that there is now a metal-on-metal situation with the shock caps--curious what people experiences/thoughts are with this?
Might it be better to stay with the stock bushings?
Bcholka is offline   Reply With Quote
Old 03-06-2013, 04:11 AM   #5515
Trader Rating: 48 (100%+)
thx
Jay
I dont think you need them. They should screw right into the screw which would eliminate the need for the little screw.
Thanks to my sponsors:
My Credit Card
Speedychris22 is online now   Reply With Quote
Old 03-06-2013, 06:10 AM   #5516
MikeXray's Avatar
Trader Rating: 73 (100%+)
The released a delrin set now.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-06-2013, 06:22 AM   #5517
thanks!
Jason Collins
Losi 22 3.0 & 22-4
Old 03-06-2013, 07:13 AM   #5518
Trader Rating: 38 (100%+)
Anyone selling RB6, please text me at 518-495-0703. send me photos. I pay right away
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 03-06-2013, 07:23 AM   #5519
i know savageboy69 was selling his. Great seller also I know they are back in stock everywhere. I just purchased my Rb6 yesterday
My Credit Card
Old 03-06-2013, 08:46 AM   #5520
I have a questions regarding gearing. I am trying to understand how to figure it out. Is there a page where I can get detailed explanation.
My Credit Card
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
