    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 03-04-2013, 08:29 PM   #5491
RodneyB's Avatar
Scrubs front and suburb rear both in MC work great at CRCRC in Columbus OH too. Before the suburb fronts came out, which usually grab too much, scrubs were the proline "match" to the suburb rears.
Kyosho America; Peak Racing; Grandview Hobbies; CRCRC
CRCRC club administrator
Kyosho RB6, Kyosho ZX6, Kyosho SC6, Kyosho MP9e TKI
RodneyB is offline   Reply With Quote
Old 03-04-2013, 09:36 PM   #5492
B00t13g's Avatar
Is anyone running the 521-1 arms with narrow suspension hangers?
I tried the arms today and ended up with a super high ride height when using the long eyelets. I was able to get 23mm of ride height using the medium eye lets. I noticed tebos setup uses a shock length of 27mn with the short eyelets, but I was unable to get that without the shock shaft hitting the pivot balls and binding it all up. Not sure what I'm doing wrong here. Also is everyone just shimming the rear hubs in the middle with those arms?
The setup I was running was based off of Brandon Collins setup was awesome for stock buggy but was terrible for mod. Not enough steering or traction.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-04-2013, 10:33 PM   #5493
silvalis's Avatar
Trader Rating: 29 (100%+)
Probably internal limiters to get that length.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 03-04-2013, 10:35 PM   #5494
seth556's Avatar
Trader Rating: 42 (100%+)
I'm not sure what the shock length is on my shocks but I run the 521-1 arms and the short eyelet, 1mm limiter. It screws all the way onto the threads despite me thinking I was going to over do it the first time I put them on. Very little droop, arms basically go flat. You shouldn't have any problem getting a 24mm ride height, then you'll have about ~6 more mm of downtravel past that.
I've been running the hubs spaced forward but need to try them in the middle and all the way back, although the car feels awesome as is.
Try the Cody Turner setup but with the 521-1 arms, wide hangers, and 2nd hole from the inside for the top of the rear shocks. That's what I'm running and the car is dialed for mod. Lots of rear bite, car is very composed when you push it hard. It also seems very balanced front to rear, can't ask for much more than that.
seth556 is offline   Reply With Quote
Old 03-05-2013, 12:56 AM   #5495
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Where can the Cody Turner Smac Track setup be found? Petitrc has a bad link.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 03-05-2013, 12:58 AM   #5496
racer x 1's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Cpt.America View Post
I find it strange that you are using two different kinds of tires front and back. Not only are you using very different side bite, but also different compounds. And maybe I am just ignorant to it as the tracks I run at here, we all run the same tire front and back, almost all the time.... but it would seem to ME, that you would first and foremost want to tune and set the car up so that it handles the way you want it to with matching tires... and you would only use miss-matched tires to address a setup issue you can't fix otherwise.
Is that what most guys at your track run? burbs back, scrubs front? Tracks and clay are SO different!!... scrubs absolutely don't work in the slightest at my tracks. (unless you want to scrub speed!)
Im glad you got the tires set... that is always job #1 before you worry about finer level adjustments on setup. Not only do you need the proper tires, but you need to get a set broken in properly first, and THEN take note of how the car drives... THEN work on those finer level changes on setup.
Traction is up way at my track, and with the increased rear traction, I am able to dial back in more steering. 30/ -4 is going to be the most aggressive steering you can get. 30 kick-up will give the best off-throttle forward weight transfer, and the low overall caster will give the most infield steering. I am running this specifically because my current layout has no highspeed steering sections where more caster is used... it's all slower speed turns.
But like always, I am still playing and fudging and learning where the car likes to be. I don't think I will keep 30/ -4 for long before changing again... track conditions (right now)... are changing too fast at my track to really nail something down. (kind of frustrating). We have another track change starting this coming weekend too, so its back to square 1. Can't finalize a setup until the clay starts to become consistent.... BUT, I am glad we are doing a track build for a change as our current layout is almost no fun at all.
just some feedback on the tires. at WCRC (reedy race track) barcodes up front with burbs out back is very very common and having played alot with my tires and inserts on my rb5 i do find codes upfront well broken in provide a touch more steering than scrubs and are more consistent through the corner. and the burbs for the front I just dont care for. Interesting when i drove a B4.1 codes front and back were much faster for me. looking to get my hands on a set of ions to try heard great things about them and sound to be the ticket.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 03-05-2013, 07:02 AM   #5497
MikeXray's Avatar
Trader Rating: 73 (100%+)
We run the medium eyelet with those arms at our track.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-05-2013, 08:30 AM   #5498
B00t13g's Avatar
Does anyone have an aluminum rf2 they can sell me?
Mackenzie Meyercord
Old 03-05-2013, 08:57 AM   #5499
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
yeah! i haven't run the ions yet on my track, but a tire with a nice low pin like that, looks good. Side bite seems (looks) like it might be inbetween a bar code and a suburb... but not sure. Also not sure about the compound. The only downside, is they are expensive!
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-05-2013, 10:04 AM   #5500
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
I hear they have more side bite and that seems to be where the races are won... In corners in the infield.
I am looking for a little more steering, runnin the B.Collins setup and like it a lot. Should I try dropping down to 25* for the front block and maybe 2 or 4* castor? I am running 30* now, will I get more by going down to maybe 29 or 27 or 25*?
ryanpatrickgore is offline   Reply With Quote
Old 03-05-2013, 10:13 AM   #5501
seth556's Avatar
I've been wanting to know that too. I'm running this setup http://www.petitrc.com/setup/kyosho/...WCRC201212.pdf with the wide blocks and 521-1 arms like he is in the pictures for Smac Track. I noticed his front camber link is a bit different now though.
Old 03-05-2013, 10:30 AM   #5502
I wonder why so little droop on the Tebo set up?
Dale.0 is offline   Reply With Quote
Old 03-05-2013, 10:54 AM   #5503
Super Moderator
More steering, go back to the red springs, and drop down to something like 25/2 caster. It will take a tiny bit away from the sweeper, and add it to the infield.
- RCSpecialties -
Old 03-05-2013, 11:17 AM   #5504
MikeXray's Avatar
Have you tried laying the front shocks in all the way? how come no one runs that?
Old 03-05-2013, 11:29 AM   #5505
Thanks Brandon. I have gone back to reds at the moment already and it felt good. This car has so much traction, I feel like I gave none up goin from golds to reds. I will give the castor change a shot. Thanks guys
Edit. Haven't tried laying shocks down yet, just because nobody does it like you said. Probably worth a try tho
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 11-22-2017 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
