    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 03-04-2013, 08:27 AM   #5476
pablo101's Avatar
Trader Rating: 50 (100%+)
Will the proline rb5 wheels fit work on a rb6 with same offset?
pablo101 is offline   Reply With Quote
Old 03-04-2013, 08:45 AM   #5477
MikeXray's Avatar
Trader Rating: 73 (100%+)
Yes, you will need lo profile serrated wheel nuts for the rear.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-04-2013, 09:16 AM   #5478
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Durango nuts are cheap and I have never had one come loose. No need to tighten the hell out of them either.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 03-04-2013, 09:52 AM   #5479
MikeXray's Avatar
traaxas has them as well and can be found in non racey hobby shops.
Old 03-04-2013, 09:53 AM   #5480
B00t13g's Avatar
From the mains on Sunday. Buggy was straight dialed!
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-04-2013, 01:12 PM   #5481
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by B00t13g View Post
[IMG]From the mains on Sunday. Buggy was straight dialed!
Looking good!! I similar picture was taken of my buggy on the grid this weekend....
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-04-2013, 02:13 PM   #5482
Capt. I have been using your set up for a couple weeks not. Before i had mentioned it was too aggresive. But you were right i just needed to get my tires sorted out. Scrub on the front, and Suburbs on the back is working great.
I saw you have gone to 30/-4. I think i am going to try less castor also. Is there a reason to go to 30/-4, instead of 25/0?
Dale.0 is offline   Reply With Quote
Old 03-04-2013, 02:14 PM   #5483
t8rtot's Avatar
Trader Rating: 14 (94%+)
different kick-up
Sfida
t8rtot is offline   Reply With Quote
Old 03-04-2013, 02:52 PM   #5484
Super Moderator
I find it strange that you are using two different kinds of tires front and back. Not only are you using very different side bite, but also different compounds. And maybe I am just ignorant to it as the tracks I run at here, we all run the same tire front and back, almost all the time.... but it would seem to ME, that you would first and foremost want to tune and set the car up so that it handles the way you want it to with matching tires... and you would only use miss-matched tires to address a setup issue you can't fix otherwise.
Is that what most guys at your track run? burbs back, scrubs front? Tracks and clay are SO different!!... scrubs absolutely don't work in the slightest at my tracks. (unless you want to scrub speed!)
Im glad you got the tires set... that is always job #1 before you worry about finer level adjustments on setup. Not only do you need the proper tires, but you need to get a set broken in properly first, and THEN take note of how the car drives... THEN work on those finer level changes on setup.
Traction is up way at my track, and with the increased rear traction, I am able to dial back in more steering. 30/ -4 is going to be the most aggressive steering you can get. 30 kick-up will give the best off-throttle forward weight transfer, and the low overall caster will give the most infield steering. I am running this specifically because my current layout has no highspeed steering sections where more caster is used... it's all slower speed turns.
But like always, I am still playing and fudging and learning where the car likes to be. I don't think I will keep 30/ -4 for long before changing again... track conditions (right now)... are changing too fast at my track to really nail something down. (kind of frustrating). We have another track change starting this coming weekend too, so its back to square 1. Can't finalize a setup until the clay starts to become consistent.... BUT, I am glad we are doing a track build for a change as our current layout is almost no fun at all.
- RCSpecialties -
Old 03-04-2013, 03:53 PM   #5485
I'm afraid I have to do sell my RB6 and FS2
Buy/Sell/Trade
Lou Colmo/Tekno EB48.3, SL & SCT410.3/ Tekno R/C,Tekin / Reedy Batteries / Savox /AKA / Futaba 4PKs
Blaze R/C,St.Louis DirtBurners,SMAC Trac
X God is offline   Reply With Quote
Old 03-04-2013, 04:50 PM   #5486
Capt. Ya all the team guys at my track run Burbs in the rear. Few run them on the front. Most guys run Scrubs on the front, or Bar Codes on the front since they were practicing for the REEDY, and that was the hand out tires. I think the biggest thing was just getting them broken in enough. I also tried Bar Codes in the rear, but just could not get hooked up with them.
Old 03-04-2013, 05:23 PM   #5487
305M3's Avatar
Trader Rating: 40 (100%+)
Scrubs Front / Suburbs Rear is a popular setup at our track too (The Track, Gaithersburg, MD). It's hard packed dirt, moist in the morning and super nice at the end of a race day. I've tried to match F/R tires and I can not get a Suburbs Front/Rear, BarCodes F/R, or etc... to work.
I will try the 30/-4 b/c there are more turn sections than straight-aways so I think i will benefit from the change.
305M3 is offline   Reply With Quote
Old 03-04-2013, 05:43 PM   #5488
Todd Putnam's Avatar
I saw some people trying to locate RB6 kits. We were able to get some out of the latest shipment to hit the USA (last week) and we have 8 of them left in stock-
http://rcspeedshop.com/index.php?cPath=163_166
We will be putting the spare parts inventory we have up this week as well - lots in stock, just not on the site yet. I am so impressed with this kit, I have decided to keep one for myself!
Hope this helps...
Todd Putnam is offline   Reply With Quote
Old 03-04-2013, 06:22 PM   #5489
Super Moderator
I see.. just so different from the hard packed indoor clay tracks we run up here in the northwest. I guess we are a bit lucky... toss on gold bar codes front and back, break them in, and you are dialed.
Do any of you guys run blue bar codes? I have 3 or 4 sets of NIP blue rears that I will never run... could sell for cheap.
- RCSpecialties -
Old 03-04-2013, 07:10 PM   #5490
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Only place I've been that the blues work is RC Excitement up in Mass. They work at home for about a week, and then it's on to golds. They must have changed the compound on the golds, because they never worked before.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
