    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-01-2013, 01:55 PM   #5446
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Speedychris22 View Post
Hi guys got a gearing question? I will be running Team Orion 13.5T motor in my rb6, someone told me to run 26/75 on the gearing but I see the best I can do is 25/76. He mentioned to get a 27 tooth pinion gear as well but I dont see that Kyosho makes them. Any advise or what would you guys run on a tight indoor track?
Run a smaller spur, no biggy. Try something like 72/27-28. The first thing I did when I switched to Kyosho, was ditch the kyosho spurs and slipper pads for this very reason. I now run Kimbrough spur gears, and AE pads. AE pads are cheap, work well, and are easy to find... as are the spurs (and you can get any gearing you want with them). The Kimbrough spurs are quiet, and perfectly round... can't beat em.
http://www.amainhobbies.com/index.ph.../filter_mfr/85
http://www.amainhobbies.com/product_...pper-Pad-B4-T4
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-01-2013, 02:13 PM   #5447
Trader Rating: 48 (100%+)
awsome I am assuming I can still run the Kyosho Pinion gears?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 03-01-2013, 02:25 PM   #5448
silvalis's Avatar
Trader Rating: 29 (100%+)
yep. as long as they are 48 pitch
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 03-01-2013, 02:28 PM   #5449
great thanks guys.
Also anyone running the Avid System? is it worth it?
My Credit Card
Old 03-01-2013, 02:42 PM   #5450
fullsyzz's Avatar
Trader Rating: 102 (100%+)
Hell yeah on the Avid slipper.
fullsyzz is offline   Reply With Quote
Old 03-01-2013, 03:22 PM   #5451
silvalis's Avatar
Im running one.
Bit more consistent than a regular slipper I think. Not quite as easy to set up though.
I'd go an avid over an rb6 slipper, but i'm not sure i'd bother if you had the rb5wc vented plates in...
Old 03-01-2013, 04:57 PM   #5452
Yes, and making this adjustment makes your camber length longer or shorter, changing your roll center, camber gain, etc. If it's .5mm at each side, probably not a big impact, if it's 1.5+mm that equivalent to one of the offset holes on the option hubs. I just wonder if the shorter link achieved when going wider is a bigger influence on the steering gained than the actual width. (could be tested by shimming at the hex instead).
I measured them a while back and it 1mm per side. I have also tried shimming at the hex as well. Same effect as wide blocks but about half as strong in effect. You need kyosho wheel with serrated nut to do this. As its a very quick change its a nice option to respond to a changing track.
Tom87 is offline   Reply With Quote
Old 03-01-2013, 08:41 PM   #5453
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
The narrow to wide blocks has to have another effect due to the pivot point. I ran the narrow caster blocks up front with RB5 axles/clamp hexes and found no loss of steering but much smoother and predictable steering. Width was about the same, but the pivot changes. On-road guys have done similar changes.
You could try narrow blocks with SC-R 3 line axles and shim 1mm to the inside to be equal to wide blocks. Use 1.5mm inside for for a little less rotation or stock axles for max rear grip. I found that 2mm inside on SC-R axles makes the dogbone rub on the outdrive at full compression. Just another tuning option.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 03-01-2013, 09:19 PM   #5454
B00t13g's Avatar
You could try narrow blocks with SC-R 3 line axles and shim 1mm to the inside to be equal to wide blocks. Use 1.5mm inside for for a little less rotation or stock axles for max rear grip. I found that 2mm inside on SC-R axles makes the axles rub on the outdrive at full compression. Just another tuning option.
Is there any shimming required when using the rb5 axles? If so what?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-01-2013, 10:05 PM   #5455
Haha I thought we were talking rear hing pin holders not front caster blocks. Front blocks are next on my list to test if the rain ever stops. Good info but.
Old 03-02-2013, 12:39 AM   #5456
This is good true advice. A set of 5x7x1mm Aluminum Collars(W0149GM) and the 3 line axles (UM510-02) is what you will need to space the hexs out 1mm each side when using the narrow rear RF blocks.
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Old 03-02-2013, 01:57 AM   #5457
eper's Avatar
Trader Rating: 14 (100%+)
mikexray the rf block is@ 41mm from outside of hole to hole the rf2 is 43 so its a 2mm difference..
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 03-02-2013, 05:15 AM   #5458
Yeti AS3's Avatar
I used 1mm on the inside and zero shims outside.
Hot Bodies D413
AE B5m
Old 03-02-2013, 05:17 AM   #5459
B00t13g's Avatar
Thanks man. And you were saying that with your setup width was the same as running the rb6 axles in the wide configuration?
Mackenzie Meyercord
Old 03-02-2013, 06:05 AM   #5460
Yeti AS3's Avatar
Just measured it. The rb5 setup actually increases the track width by 1mm per side. It feels real good on high bite.
Hot Bodies D413
AE B5m
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
JAE
