    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 02-28-2013, 10:14 PM   #5431
joeymdz's Avatar
Send a message via MSN to joeymdz
Originally Posted by Cpt.America View Post
Ride height gauge.. under the front.
And behind the front wheels. If you do it straight on sometimes the bumper hangs lower than the chassis
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 02-28-2013, 11:11 PM   #5432
B00t13g's Avatar
What is removing the .5mm shim I have between the pivot block and chassis supposed to do?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-01-2013, 12:36 AM   #5433
steam's Avatar
Lowers Roll center
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 03-01-2013, 07:12 AM   #5434
B00t13g's Avatar
Sorry Kyosho calls it a front suspension mount block.
Mackenzie Meyercord
Old 03-01-2013, 07:55 AM   #5435
MikeXray's Avatar
Trader Rating: 73 (100%+)
Does anyone know the width difference between the RF and RF2 configurations?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-01-2013, 08:43 AM   #5436
seth556's Avatar
Trader Rating: 42 (100%+)
The RF2 makes the arms sit out a little wider. Helps free up the rear end and make it more stable.
seth556 is offline   Reply With Quote
Old 03-01-2013, 08:51 AM   #5437
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Yeah, but I think he's asking how MUCH wider the wide hangers are. Mike, without measuring (i don't have two sets off a car at the moment)... I would guess (dont' quote me) 1.5mm wider per side (3mm total) . I will be doing some work on my cars tonight, id be happy to measure later.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-01-2013, 08:53 AM   #5438
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
this thread makes my head spin
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 03-01-2013, 09:01 AM   #5439
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Happy birthday to me, I bought the ghea pistons 4 hole 1.3 and some spare parts. And the wife got me a new tekin gen2 for stock! Can't wait for the weekend now . Weeee
Any body using the tekin? Did you add timing on the can at all?
ryanpatrickgore is offline   Reply With Quote
Old 03-01-2013, 09:36 AM   #5440
MikeXray's Avatar
Ok, I will measure them as well, just curious if anyone had yet. I think most will change the blocks and not change the link length, which I feel will has at least as much of an impact on handling as the width change will.
Old 03-01-2013, 09:51 AM   #5441
Super Moderator
link length? The camber tie-rod? Yeah, if you go from the narrow blocks to the wide blocks and don't re-adjust camber, you will probably be looking at like -6 camber
- RCSpecialties -
Old 03-01-2013, 09:55 AM   #5442
fullsyzz's Avatar
Trader Rating: 102 (100%+)
Gen2 17.5? Great motor! Set the timing on the can to 30deg. and gear 69/33 to start with.
fullsyzz is offline   Reply With Quote
Old 03-01-2013, 10:31 AM   #5443
MikeXray's Avatar
Yes, and making this adjustment makes your camber length longer or shorter, changing your roll center, camber gain, etc. If it's .5mm at each side, probably not a big impact, if it's 1.5+mm that equivalent to one of the offset holes on the option hubs. I just wonder if the shorter link achieved when going wider is a bigger influence on the steering gained than the actual width. (could be tested by shimming at the hex instead).
Old 03-01-2013, 12:42 PM   #5444
Great thanks or the heads up. Right now I'm 31/69 on my trinity. With 5 extra degrees.
Old 03-01-2013, 01:45 PM   #5445
Trader Rating: 48 (100%+)
Hi guys got a gearing question? I will be running Team Orion 13.5T motor in my rb6, someone told me to run 26/75 on the gearing but I see the best I can do is 25/76. He mentioned to get a 27 tooth pinion gear as well but I dont see that Kyosho makes them. Any advise or what would you guys run on a tight indoor track?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22953 Today 12:29 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
