    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 02-27-2013, 08:32 AM   #5416
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Had a fun night racing last night at trcr. Running Brandon's setup felt really good. I was running the gold rear springs and decided to go up to reds and the car felt even better, less dumping in the corners and faster steering and cornering after the change. I am running stock pistons 35/30 oils. This car Is on rails as I have had no traction issues with the change at all. the track itself had great traction last night. So stable, best car I have ever owned! Just gets better.
ryanpatrickgore is offline   Reply With Quote
Old 02-27-2013, 07:35 PM   #5417
B00t13g's Avatar
So I just realized the manual states to use the A0 caster insert in the right side and the B0 in the left side. I have mine the exact opposite, but still in the the proper wide track width configuration. What is the difference while using the 0's in the opposite configuration? Basically does it matter if I have the A on the B side and vice versa?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 02-27-2013, 07:46 PM   #5418
savageboy69's Avatar
Trader Rating: 88 (100%+)
Still have a 1 race old rb6 for sale, pm me in interested
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 02-27-2013, 07:59 PM   #5419
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
With the 0, nothing. With any others, you'd be decreasing caster, rather than increasing.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 02-27-2013, 08:06 PM   #5420
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Nothing except change the width. You have to do the same thing on the other caster inserts to change the width also.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 02-27-2013, 08:16 PM   #5421
B00t13g's Avatar
So if I'm running a2 on the left and b2 on the right in the narrow configuration i would be increasing caster and if I'm running a2 on the right and b2 on the left in the wide configuration I'm also increasing caster?
Mackenzie Meyercord
Old 02-27-2013, 08:42 PM   #5422
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
FYI kits are now off back-order. I have one coming in the mail to my LHS, should be here Friday.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-28-2013, 04:05 AM   #5423
Trader Rating: 48 (100%+)
Finally
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 02-28-2013, 06:22 AM   #5424
MikeXray's Avatar
Trader Rating: 73 (100%+)
Finally got a few hours of practice with the car yesterday, and its really good I still feel like I need to adjust the shock package, but I'm not 100% which direction to go. I made 4x1.2 pistons, but could only find one pair in stock, I plan to try them up front.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-28-2013, 06:26 AM   #5425
Ostach24's Avatar
Trader Rating: 85 (100%+)
I still have my rand new built rb6 for sale. Check it out in the for sale thread.
Ostach24 is offline   Reply With Quote
Old 02-28-2013, 06:53 AM   #5426
B00t13g's Avatar
Correct?
Mackenzie Meyercord
Old 02-28-2013, 08:04 AM   #5427
Super Moderator
Correct?
that sounds right to me, but I admit I tend to need to have a visual on these things, and don't have the car in front of me. Search a couple pages back for a post I typed out about how you tell if the insert is increasing, or decreasing caster, regardless of where you put your insert.
- RCSpecialties -
Old 02-28-2013, 08:38 AM   #5428
B00t13g's Avatar
Thanks Brandon. I don't either, but your explanation works!
Mackenzie Meyercord
Old 02-28-2013, 06:12 PM   #5429
How do u guys measure the front ride height
My Credit Card
Old 02-28-2013, 09:27 PM   #5430
Super Moderator
Ride height gauge.. under the front.
- RCSpecialties -
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22939 Today 01:36 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
