    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 02-24-2013, 09:09 AM   #5371
B00t13g's Avatar
Originally Posted by RodneyB View Post
Shock end part numbers from earlier in the thread. Courtesy of a search for "shock end part".
I tried searching, but didn't come up with anything. I greatly appreciate your response.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 02-24-2013, 09:09 AM   #5372
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Ran Durango stuff for a yr. Time for change.
Would love to come back to CRCRC, but JCP in Indy has got our attention. Can't beat semi heated with indoor plumbing, catered food, and being closer helps too.Lol
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 02-24-2013, 09:58 AM   #5373
Trader Rating: 26 (88%+)
I know Ive seen it on here before and I just searched for it but can someone tell me which hangers to run for Indoor Clay Med/High traction. If i can get the part #'s that would be awesome! thanks
jgonz is offline   Reply With Quote
Old 02-24-2013, 10:25 AM   #5374
Proline is the tire of choice for the fast guys. But I will try the bar codes
Dale.0 is offline   Reply With Quote
Old 02-24-2013, 10:49 AM   #5375
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
slow down, amigo! I was just inquiring. If they don't already work, then don't go rush out and burn a set of tires and wheels... It just seems that running two different tires front and back, with dramatically different compounds, tread design, and performance... would throw any setup for a loop.
If you already have a set of x-gear white springs, you could toss those up front... that would take away a tiny bit of steering. How are you running your electronics? what battery, and where is it sitting on the chassis?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-24-2013, 10:57 AM   #5376
Orion shorty. Looks like it's about the same place as yours. And I'm running a 9.5 motor. I have a set of bar codes, I just have not mounted them up yet. I do have the white springs I will try that too. I like lots of steering, but the way it is now I'm not consistent.
Old 02-24-2013, 10:58 AM   #5377
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
I have the alum hubs coming in the mail. Now I hear they run a larger bearing? Does somebody know the bearing sizes? Or part number?
ryanpatrickgore is offline   Reply With Quote
Old 02-24-2013, 11:14 AM   #5378
Super Moderator
They come with the bearing.. and i forget the size. I'v never had to replace mine!
- RCSpecialties -
Old 02-24-2013, 11:16 AM   #5379
Super Moderator
What car did you come from? When I first switched from the RB5 to the 6, I was flabbergasted by how much steering the car had... it was uncontrollable. But the more I drove it, the more I got used to it.. and now it doesn't seem to have as much as I perceived when I first started with it. It is a beast of a car!
(but honestly, it sound more like a tire issue to me, but I admit I know nothing of your track, surface, or tire selection options).
- RCSpecialties -
Old 02-24-2013, 11:18 AM   #5380
SAMCRO's Avatar
It's med to high bite clay. Suburbs on the black scrubs on the front. Clay compound. Aka foam. Rears are broke in more than the fronts. I also tried a new set of fronts. It's good, just too aggressive to be easy to drive.
It is all your tires. I had same problem with AKA foam on our track. I would turn the wheel and just do doughnuts. Everything was fine when I went to softer foam and same tires.
I ran 3-4 packs with my aka foam, but never seemed like they got broke in. I put another pair in the washing machine a few times and that helped...
SAMCRO is offline   Reply With Quote
Old 02-24-2013, 11:47 AM   #5381
RodneyB's Avatar
Scrubs MC work well with Suburbs MC at my track, but the Scrubs do need broken in before they feel right IMO. They can be too aggressive when new. I run my scrubs with open cell foams in the front aka reds in the rear burbs.
Kyosho America; Peak Racing; Grandview Hobbies; CRCRC
CRCRC club administrator
Kyosho RB6, Kyosho ZX6, Kyosho SC6, Kyosho MP9e TKI
RodneyB is offline   Reply With Quote
Old 02-24-2013, 01:43 PM   #5382
RShockley's Avatar
Anyone have an idea when they will come off backorder. I am hoping to get mine before a race next weekend.
Richard Shockley
Kyosho RB6 / Kyosho RT5
Mike's Hobby Shop......Carrollton, TX
Kalgard / Epic Cameras / SMX Optics / Heavenly Hobbies
RShockley is offline   Reply With Quote
Old 02-24-2013, 03:00 PM   #5383
Also, make sure you don't have any toe out up front.
ChadBlanton is offline   Reply With Quote
Old 02-24-2013, 03:27 PM   #5384
Trader Rating: 54 (100%+)
When is the RB6 coming off back order?
Speedychris22 is offline   Reply With Quote
Old 02-24-2013, 03:39 PM   #5385
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
What I have been told, is that it should be back in stock anytime between 1-2 weeks all the way up to 6 weeks.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22981 Yesterday 04:29 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
