Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 02-23-2013, 10:15 PM
  #5356
Brandon. I really like your latest set up, but I need a little less steering. It's a little too aggressive. What should I do?
Dale.0 is offline
Old 02-23-2013, 10:33 PM
  #5357
Cpt.America's Avatar
Trader Rating: 52 (100%+)
What kind of surface do you race on, what tires do you run, and what do your tires look like? are your fronts more broken in than your rears by chance? My setup is designed to make the car pretty easy to drive (un-aggressive front end). If you have too much steering, you have a setup issue somewhere else in the car. The only other change you could make that would lock the rear end in even more, would be to go to .5 rear hubs... but i wouldn't do that until you are 100% sure that the car is properly setup... with both tire wear, insert wear, and weight balance. Those things will DRAMATICALLY affect how a car drives, far more than any setting or washer you change on a setup sheet.
Cpt.America is offline
Old 02-23-2013, 10:56 PM
  #5358
B00t13g's Avatar
Does anyone have the part numbers for the short medium and long shock rod ends used on the rb6?
B00t13g is offline
Old 02-23-2013, 11:06 PM
  #5359
Wife got this pic of me and the 6 at the track today
Old 02-23-2013, 11:13 PM
  #5360
It's med to high bite clay. Suburbs on the black scrubs on the front. Clay compound. Aka foam. Rears are broke in more than the fronts. I also tried a new set of fronts. It's good, just too aggressive to be easy to drive.
Dale.0 is offline
Old 02-23-2013, 11:17 PM
  #5361
suburbs might be part of your issue... they don't have enough side bite for the 6 me thinks... they are specifically a low side bite tire. Before I would play with setup too much, i would first switch to a more consistent tire, and run the same tire front and back. Do gold barcodes work at your track?
Old 02-24-2013, 03:03 AM
  #5362
Originally Posted by ChadBlanton
I've been pretty curious about gear diffs - seems easier to deal with and more consistent. Please update us on your findings with it ...
I only ran on carpet so far, that's where I'm using a gear diff. Way more direct throttle feel and higher vorner speed, if it's flat carpet only. As soon as there are slipery parts on the track like e.g. wood the ball diff got it's pros up again. And my gear diff is leaking as hell...So I'm not sure if gear diff is too interesting on clay/low traction surfaces...On high traction it definitly has its advantages but also increases tire wear.
So does anyone have an idea about which hex screws to run in the gear diff ? Which kind of grease are you guys running in the transmission ?
Hansie is offline
Old 02-24-2013, 04:55 AM
  #5363
New lay out electrics that transforms the car in MM.
Attached Thumbnails Kyosho Ultima RB6 & RB6.6 Car Thread-kyosho-008.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-kyosho-004.jpg
delanobe is offline
Old 02-24-2013, 06:03 AM
  #5364
asc6000's Avatar
Trader Rating: 15 (100%+)
Brandon, are you considering the Tekin shootout ? got some good drivers coming out. Should be good times.
asc6000 is offline
Old 02-24-2013, 06:42 AM
  #5365
Trader Rating: 125 (100%+)
Fresh paint. Hate to even put decals on it and run it on the track.
kwiksi is offline
Old 02-24-2013, 07:10 AM
  #5366
dmatter's Avatar
Hey David...Thought you were a team driver for Durango? When you guys coming to crcrc to race?
See ya buddy
Dax
dmatter is offline
  #5367
MikeXray's Avatar
Trader Rating: 73 (100%+)
Looks good, nice color combo.
MikeXray is offline
Old 02-24-2013, 07:12 AM
  #5368
B00t13g's Avatar
Anyone?
B00t13g is offline
Old 02-24-2013, 08:01 AM
  #5369
RodneyB's Avatar
See ya buddy
Dax
Looks great David. I agree with Dax, we need more RB6 presence at CRCRC. Mine has been dialed lately.
RodneyB is offline
Old 02-24-2013, 08:04 AM
  #5370
RodneyB's Avatar
Originally Posted by mdowney
S = W5015
M = 97038
L = LA43
Shock end part numbers from earlier in the thread. Courtesy of a search for "shock end part". I haven't verified these are correct.
RodneyB is offline
