    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 02-21-2013, 05:41 PM   #5341
Trader Rating: 48 (100%+)
Originally Posted by savageboy69 View Post
hey guys ive had some stuff come up and need to sell my rb6, its been ran one race weekend and had a chassis protector, comes with like 6 sets of springs, alum hubs, and misc parts, asking $415 or best offer just need it gone, check my forsale post or pm me
Where can I get a chassis protector?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 02-21-2013, 06:10 PM   #5342
gelshocker's Avatar
Originally Posted by K_King View Post
Cpt nailed it. I also find that more caster has more exit steering on low speed turns, almost making the car hook. But I have to test that more.
Ah ha. So it's not just me. I run the Japan setup which calls for +4 caster inserts, and at very low speeds right at exit the 6 will hook. Can I power steer the car away from ever reaching this scenario?
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 02-21-2013, 06:24 PM   #5343
savageboy69's Avatar
Trader Rating: 88 (100%+)
it depends, if you just want the clear stick on ones jconcepts makes really good ones, or you could have a graphiics company make custom ones
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 02-21-2013, 06:37 PM   #5344
So what is going to give me the most off power steering? My track is very small with 3 180 degree hairpin turns. I would link youtube videos of the track but my post count isn't high enough.
I've tried pro-dive 25 +4 caster and liked it a lot. Now i'm at 30 pro-dive 0 caster and it doesn't seem quite as good. I'm thinking of going to harder springs then red in rear.
Thanks!
HalfManHalfGod is offline   Reply With Quote
Old 02-21-2013, 06:51 PM   #5345
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Thanks!
Turn and tap the brakes hard.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-21-2013, 06:54 PM   #5346
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Thanks!
Try 25/0
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 02-21-2013, 08:09 PM   #5347
B00t13g's Avatar
I put Brandon Collins setup on my car and it was an excellent base with just a few simple changes the car is hooked on my local track. Medium bite. Medium size and a good mix of technical for the size of the track. I went to white fronts with 32.5 Losi up front medium on the front camber link and that's it!
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 02-21-2013, 09:23 PM   #5348
Move the 1mm shim from behind the caster block to in front. Shortening the wheel base.
Tom87 is offline   Reply With Quote
Old 02-21-2013, 10:27 PM   #5349
joeymdz's Avatar
Send a message via MSN to joeymdz
Thanks!
Moving the battery forward if possible. Or lowering the axle height will give you more turn in but will lose some on exit
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 02-23-2013, 09:07 AM   #5350
Hi,
those of you who are running a gear diff. Have you found a fitting hex screws ? If yes, which size/company screws ?
And what kind of grease are you putting into your transmission ? or none at all ?
Kyosho RB6 Team Orion R10 Pro Team Orion VST 6,5t
TRF 501X WE LRP SXX Vers. 1 GM Pro 6,5t
Hansie is offline   Reply With Quote
Old 02-23-2013, 09:34 AM   #5351
Originally Posted by Hansie View Post
Hi,
I've been pretty curious about gear diffs - seems easier to deal with and more consistent. Please update us on your findings with it ...
ChadBlanton is offline   Reply With Quote
Old 02-23-2013, 05:38 PM   #5352
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
Finally got to race the car today. The car was great and drove well. Driver sucked. It was just one of those days.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 02-23-2013, 09:06 PM   #5353
Default Wheels
Hey guy's.. Have a new RB6 coming making the switch from AE... One question are the wheels the same with the 5 ? Trying to get some ordered so I am ready to roll as soon as my kit is here ... Thanks in advance !!
srs70 is offline   Reply With Quote
Old 02-23-2013, 09:13 PM   #5354
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
Id like to know too.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 02-23-2013, 09:31 PM   #5355
Trader Rating: 101 (99%+)
Yes they are. Highly recommend you check post #1 for a lot more useful info on this buggy...
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
