    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 02-21-2013, 07:49 AM   #5311
Trader Rating: 38 (100%+)
Originally Posted by MikeXray View Post
There are no issues running B4 slipper pads with kyo plates if I wanted to use a kimbrough spur right?
I had no issues at all.
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 02-21-2013, 07:49 AM   #5312
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Cpt nailed it. I also find that more caster has more exit steering on low speed turns, almost making the car hook. But I have to test that more.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 02-21-2013, 07:52 AM   #5313
seth556's Avatar
Trader Rating: 42 (100%+)
Caster is faster. I find less caster gives more turn in but less steering in the middle of the turn. With more caster it seems more linear throughout the turn. You can also think of it as the more caster you have the more the car will dig in at higher speeds.
seth556 is offline   Reply With Quote
Old 02-21-2013, 08:21 AM   #5314
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Curious, for those of you running the 30 degree kickup have you run the inserts backwards so you would get 28, 26 degree caster? I am just wondering if the results would be similar to running 25 kickup with different inserts.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-21-2013, 08:52 AM   #5315
Originally Posted by noworries View Post
FOR SALE: this is killing me. I just can't run so many classes.
RB6 roller. Like new. Not a scratch on it. Ran on carpet only.
3 painted bodies. 1 custom painted j concepts with wing. 1 stock body and 1 proline body.
Avid triad with Kyosho topshaft. comes with 69, 72 and 76 spur
Kyosho gun metal battery supports
Kyosho carbon fiber battery strap.
Exotek: aluminum (red) steering rack
Exotek: rear camber plate (red)
extra set of x-gear springs. front and rear. Front GOLD. Rear YELLOW
Kimbrough 69 spur with AE upgraded pads included.
All kit parts replaced with above are included.
Extra set (4) of yellow Kyosho wheels.
new tires, mounted slightly used tires (schumacher) will be included.
I am new to this forum but I have 100% score on ebay. Buy with confidence. 89 feedbacks on Ebay. Text me at 518-495-0703 or leave message here.
$540 firm.
SOLD. THANK YOU VERY MUCH
Old 02-21-2013, 09:03 AM   #5316
Super Moderator
Kraig's Avatar
Hey gang, lets us the For Sale forum to sell your stuff as that is the reason why it is there.
Thanks!
Old 02-21-2013, 09:04 AM   #5317
Kooz's Avatar
Originally Posted by steam View Post
I feel out of the loop, What is a ghost pin?
Worn down tires so that the pins are barely visible.
Only bad question is the one not asked.
Kooz is offline   Reply With Quote
Old 02-21-2013, 09:05 AM   #5318
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Yes, you can run the 30 and go backwards for 28 or 26... heck, run 25 and go down to 23 or 21
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-21-2013, 09:15 AM   #5319
Super Moderator
Kraig's Avatar
Yes that I understand. I was just curious to see if anyone tried it and how it felt.
Old 02-21-2013, 10:25 AM   #5320
Super Moderator
I am actually going to make this change for this weekend. I want to lower my caster, but want the kick up for off throttle rotation. I am going to try 30/-4
- RCSpecialties -
Old 02-21-2013, 10:32 AM   #5321
Johnn27's Avatar
Thumbs up kimbrough spiur
Johnn27 is offline   Reply With Quote
Old 02-21-2013, 10:33 AM   #5322
Johnn27's Avatar
Thumbs up kimbrough spur
None , I run a 69 kimbrough associated spur with the associated slipper pads
in my RB6 with the RB6 plates!
Old 02-21-2013, 10:53 AM   #5323
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
So this will equal 26*? Achieved by just flipping you blocks to the opposite side?
I was thinking of trying 29* I want more mid and exit steering right now. Maybe ill try the red springs again as I have gold on right now.
Also, which front hinge pin holder is the thicker prefered one? Seems like there are quite a few to choose from? Part number?
ryanpatrickgore is offline   Reply With Quote
Old 02-21-2013, 12:30 PM   #5324
Super Moderator
Kraig's Avatar
Ok, I am glad you understood my question. I am curious as to what you find.
This is the latest one that has been refined, KYOUM720B. I put it on my car last Tuesday and so far so good.
Old 02-21-2013, 12:34 PM   #5325
joeymdz's Avatar
Send a message via MSN to joeymdz
I tired of using a hammer to the other one! thats good to know
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Yesterday 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
