    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 02-18-2013, 04:35 PM   #5251
Dusttt's Avatar
Trader Rating: 123 (100%+)
Originally Posted by Cpt.America View Post
Avids are softer. But don't forget, it isn't just about the spring rate. Other cars don't carry as much weight up front, and their shock mounting positions might not be the same (huge affect on what weight spring you want to run). So take all that into consideration.
Nope... and probably never will be. My latest is on my website, and the link always takes you to my latest (I just update the same link). I just made my changes/updates yesterday. Car was brutally good this last weekend.
Brandon Collin's RB6 setup for high traction indoor clay
so you have 30 deg total castor then? if we run the block set on 25 and then use 4 deg chubs we are at 29 no? is the one degree worth it?
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 02-18-2013, 04:38 PM   #5252
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Front suspension hanger changes kickup, as well as caster. So 30/0 and 25/4 are very close in regards to caster, they are not close in kikcup/pro-dive.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-18-2013, 04:46 PM   #5253
Dusttt's Avatar
ahh I see
Old 02-18-2013, 04:50 PM   #5254
steam's Avatar
Default Picture
Brandon,
Do you happen to have a current picture of your car?
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 02-18-2013, 05:17 PM   #5255
Super Moderator
Originally Posted by steam View Post
Brandon,
- RCSpecialties -
Old 02-18-2013, 05:18 PM   #5256
Brandon what is your website?
Dale.0 is offline   Reply With Quote
Old 02-18-2013, 05:21 PM   #5257
Super Moderator
gave you the link, last post of last page.
- RCSpecialties -
Old 02-18-2013, 06:11 PM   #5258
MikeXray's Avatar
Trader Rating: 73 (100%+)
Yeah I know, you can tell when pressing on the front that it is stiff, again it works, just fielding options. It can't have more weight than a losi, my buddy has some brass kickup plate that is like 30g on his and still runs softer springs (but I see cav running kyo pink springs on his B4.2 most of the time) lol.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-18-2013, 06:40 PM   #5259
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
how does the durability on the tb6 compare to the tlr22 after they addressed some of the early issues?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 02-18-2013, 07:09 PM   #5260
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Here is what you need to remember:
25 caster = 0mm bumpsteer
30 caster = 3mm bumpsteer (what I am running now)
You can do the math to figure out how much you will need at 27, 29, 32, etc. If you changed caster but didn't adjust bumpsteer washers to keep the car at 0 bumpsteer, you actually made two changes at once. You will feel the affects of bumpsteer just as much as caster... so your test was inconclusive until you make those change corrections.
There might be a difference in how much B.S. washers you run depending on the angle of your camber link as well, but I haven't tested that. The key is to just make sure you measure your bumpsteer before and after your caster changes to make sure you keep it the same so you aren't making two changes at once.
Yeah 1.67mm per ever 3 degrees of caster I suppose.
I was running 29 with 0 shims also before annnnnnnnnnd yeah. hehe. I Was wondering why my toe was so jacked.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 02-18-2013, 10:01 PM   #5261
umm winning's Avatar
Originally Posted by Wildcat1971 View Post
how does the durability on the rb6 compare to the tlr22 after they addressed some of the early issues?
Well I found my losi 22 was a tank when it came to durability. But seriously the Rb6 IMO places higher than that. If you read over some posts a few pages back, there are some people who have yet to break a part since they've owned it. The only likely break that i can think of is the steering rack, but there are optional aluminum replacements that some do out of the box. The rb6 is high quality and more pricier for a reason and is probably the most durable 2wd buggies out there.
umm winning is offline   Reply With Quote
Old 02-19-2013, 07:52 AM   #5262
Originally Posted by Turbo911 View Post
Has anybody weighed their rb6 for weight distribution?
My rear motor weights - 1561 grams with 32.5% front and 65.5% rear
My mid motor weights - 1506 grams with 35.5% front and 62.5% rear
Went to Joliet (252 entries) this past week end and raced the the rear motor (8.5) in mod and the mid motor in stock (17.5) blinky. Fast lap for the mod was 20.9 secs and 22.4 for stock. It was a high bite wet clay surface that started out with slicks and we finished on ghost pins. Still haven't decided between the mid and rear motor setup, like both.
Turbo
I can't decide between mid or rear motor. I ran mod rear motor last weekend and could not get the buggy set up right. Ran mid motor 17.5 blinky and I liked how it jumped/turned. The best "upgrade" I have done in my opinion is going to "narrow" aluminum hub carriers.
noworries is offline   Reply With Quote
Old 02-19-2013, 09:39 AM   #5263
English365's Avatar
Trader Rating: 128 (100%+)
I don't post on here very often, but need some help.
I will be attending the Cactus Classic, and need some setup help!
Anyone that has a setup for SRS and would love to share I would greatly appreciate it.
Thanks,
Dustin
Kyosho America~Thunder Power~Team Orion~KO PROPO~AKA
Mikes Hobby Shop...TeamTreeTop!
English365 is offline   Reply With Quote
Old 02-19-2013, 10:10 AM   #5264
lbckevin's Avatar
Trader Rating: 89 (99%+)
For SRS...I would use the Hot Rod Hobbies setup on Petit rc.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 02-19-2013, 10:55 AM   #5265
English365's Avatar
Okay cool! Was looking at that but wasn't sure.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
