    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 02-16-2013, 10:55 AM   #5221
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Originally Posted by B00t13g View Post
Looking for a starting point for 17.5 gearing/ timing.
D3.5 with a 12.5 high torque rotor
Orion r10 pro
Orion 4000mah 90c
Avid triad
31/72 was my sweet spot for d3.5 blinky.
I need lots of torque for my track tho. Timing at 5* more than the stock 30* baseline setting
ryanpatrickgore is offline   Reply With Quote
Old 02-16-2013, 10:58 AM   #5222
Originally Posted by MikeXray View Post
Just to make sure I'm not crazy here, the manual has you build the front end wide right? I've had people tell me they run narrow "like the manual" but the eccentric needs to be pointing away from the kingpin to be narrow, that moves the whole chub in. Manual has the hole furthest away from the kingpin which widens the track...
What exactly does this refer to? THe bulkhead with the options of UM502, UM721/STD, or UM567?
Also, does anyone know why Tebo runs the 521-1 as opposed to the 2hole WC- arms? I think the 2-hole are UM521....
rcnewb123 is offline   Reply With Quote
Old 02-16-2013, 04:08 PM   #5223
MikeXray's Avatar
Trader Rating: 73 (100%+)
I was referring to the caster insert setting, you can flip it for wide or narrow settings. I believe the parts you listed also change the front track, but from the inside.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-16-2013, 04:19 PM   #5224
MikeXray's Avatar
I had my first race night with the car, I had intended to run back to back with my b4.1 but didn't have that car ready. Overall the car is very very good, the steering balance is great and the car pretty much does what you tell it too. I did have an issue, and I'm not alone, with the "rythm" section and the car not absorbing the bumps well, I added some droop which helped, but my feeling is that I need a slightly different shock package, this sections my B4 actually handles better, so maybe some more pack (2x1.6 vs 5hole in kyo, both with 35wt).
I was able to take off .4ths from my last run, I believe conditions were a little bit better which counted for some of it. I found that running the 521 arms and narrow blocks with the stock hub, I needed the inside hole to match the hole people with the alum hubs were running. This added a good bit of rotation without getting loose. I still need to pick up some .5 hubs. I ran proline rims without issue as well, I used the stock nut with nylon for the front and low profile serrated on the rear.
Old 02-17-2013, 06:05 AM   #5225
Trader Rating: 38 (100%+)
Hey guys, please need your help. Setting the diff? Do you completely collaps then turn it back 1/8, 1/4? etc?. Also, would it be normal to rebuilt my RB6 diff if i have a total of about 16 rounds of hard racing on inside carpet track. thanks.
noworries is offline   Reply With Quote
Old 02-17-2013, 09:22 AM   #5226
That's how I set my diff usually set between 1/8 and 1/4. I only rebuild when it feels gritty and not smooth like it did when I last built one.. 16 races on carpet.... It might be time?
Old 02-17-2013, 11:18 AM   #5227
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
No... bottoming out the screw and then backing it back off some arbitrary amount is how you put a dent in your rings and/or diff balls. You start very very very loose, and then slowly tighten the diff 1/2 turn to 1/4 turn at a time, and do a small break-in between each step.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-17-2013, 04:41 PM   #5228
On patite rc, can anyone see Cody Turners latest set up?
Dale.0 is offline   Reply With Quote
Old 02-17-2013, 05:38 PM   #5229
gelshocker's Avatar
Originally Posted by K_King View Post
It would explain why tebo runs 1mm
But why not add the limiters in the front too?
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 02-17-2013, 05:44 PM   #5230
Nitronut3's Avatar
Send a message via AIM to Nitronut3
Try Tebo's CRCRC setup for this year. He went to 4 hole pistons and the car is a whole lot better. Cody Turner runs that setup now and loves it as well
Nate Jaskot
XRAY, RC America, KO Propo, Hudy, FX Engines, Nitropro, Rc addiction products , TeamSR, SmacTrac
Nitronut3 is offline   Reply With Quote
Old 02-17-2013, 06:02 PM   #5231
MikeXray's Avatar
Assuming he drilled out 4x55 in blank kyosho pistons? I read some using the losi, but it wasn't quite the same diameter?
Old 02-17-2013, 06:07 PM   #5232
gelshocker's Avatar
Ok so I got sidetracked a little. After 5 months 10 days I finally got the 6 on the track
FWIW:
- the chassis underside the gearbox dented
- the stock front hinge pin holder bent (very easily, and so did the spare)
- the stock steering brace did not break
- the rear upper hub plate (ball stud carrier) did not break. I used nut under ball stud and grub screws in empty holes
- front inner ball stud popped out (dang! first time ever)
Compared to rb5:
- the 6 is WAY easier to handle. More stable and flies much better. More planted.
- turns WAY better.
- I feel it lacks rear bite, or maybe because its feels more stable that it 'appears' laidback and lackluster. After checking lap times both were comparable, meaning there is greater envelope to really push this car. I did slightly hold back in fear of breaking the known issues.
- it feels less aggressive, which may or may not be ideal. Feels less 'urgency' in getting round the track.
Japan setup with 0.5 hubs, shorty pack in middle, 1590g. First time I felt like I was driving a car and not fighting it like I had been with the rb5. As a newbie, this car is maybe too easy to drive! It's like it will autocorrect your mistakes both on the floor and in the air. I will definitely keep the rb5 to continue honing some proper 2wd driving skills!
One guy said I was outrunning a 1/8 nitro it was so smooooooth. I was LOLing on the drivers' stand!
Kyosho RT5 | RB6
Old 02-17-2013, 06:18 PM   #5233
Super Moderator
My RB6 is twice as aggressive as my RB5.
- RCSpecialties -
Old 02-17-2013, 06:36 PM   #5234
MikeXray's Avatar
I was also thinking about just moving the battery forward a bit, right now its a shorty in the rear most position.
Old 02-17-2013, 06:40 PM   #5235
gelshocker's Avatar
Or maybe my rb5's setup is erratic like a bull in china shop, aggressive in an otherwise manner! Personally I feel the rb6 more responsive, but within a more predictable, controlled window. I wasn't having to fight the car.
Cpt., I agree with most of what you post on the first page, and the wide/narrow explanation has helped with my rb5 too - thanks. The rb5 is very easy to drive.. slow. To make it fast I've had to push it beyond its comfort zone, which leads to more mistakes. My 2 cents. Cheers!
Kyosho RT5 | RB6
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 Yesterday 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
