    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree15Likes
Old 02-15-2013, 10:19 PM   #5206
Just1More's Avatar
Originally Posted by Dale.0 View Post
Brandon, you may have been asked this before is so I am sorry. I am putting your set up on my car.
I have a couple questions. On the front blockmposition, in or out?
The caster insert hole goes IN, so it makes the front end physically wider. It's the same way the manual shows to install, but use the 0deg insert and the center block at 30deg as shown
On the front axle Hightower(height) spacers you say 1mm top and bottom? Isn't there only a total of 1.5mm top or bottom?
I think he means 1mm bottom and .5mm top
And rear wheel base. It says 2mm in front and rear of the arms? Is it .5mm in front of arm, and 1.5mm behind? Thanks
On the outboard hub side, 2mm in front of the hub and 2mm behind the hub, so centered. On the inboard side on the chassis between the RF/RF2 blocks, it's .5mm in front of the arms, and 1.5mm behind the arms. You would be fine with 1mm in front and behind of the arms also, the .5mm shims are hard to come by
Hope this helped. We run the same setup at the same track on a weekly basis. I only posted in the interest of you getting quick answers
Mark Clark
RB6
B44.1
TC6.1
Just1More is offline   Reply With Quote
Old 02-15-2013, 10:25 PM   #5207
Great thank you!
Dale.0 is offline   Reply With Quote
Old 02-15-2013, 11:29 PM   #5208
B00t13g's Avatar
Looking for a starting point for 17.5 gearing/ timing.
D3.5 with a 12.5 high torque rotor
Orion r10 pro
Orion 4000mah 90c
Avid triad
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 02-15-2013, 11:50 PM   #5209
Troy Mckune's Avatar
Trader Rating: 38 (100%+)
Orion r10 pro
Orion 4000mah 90c
Avid triad
Full timing on D3.5. Gear it 33 or 34/72 or 34/69. Orion R10 Blinky with punch 9.
You can reduce timing on motor or gear a tooth lower depending on punch.
Mckune Design / facebook page / RC America / XRAY / Lunsford Racing
Mckune Design is a custom manufacturer of CNC machined carbon fiber, G10, & composite laminate parts for RC, Aerospace, medical, and high tech industries.
Troy Mckune is offline   Reply With Quote
Old 02-16-2013, 12:16 AM   #5210
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Originally Posted by Just1More View Post
No, the piston doesn't go farther up. When changing between long/medium/short ends the uptravel remains the same, the distance from the end of the shock shaft(while screwed in) to the center of the ball pivot is what changes.. Uptravel/downtravel doesn't change when going between the different shock ends, only A-arm droop. When putting a limiter under the piston, uptravel doesn't change, only downtravel and in turn A-arm droop. Hope this help, i see where you're coming from.
He was talking about swapping shock ends to change droop instead of taking the shock apart to add/remove limiters.
Odd, because I'm running 27mm without a 1mm limiter, I'm curious what he gets by doing this.
But thinking about it, why aren't you getting more uptravel? Sure the 27mm betweeen shock end and bottom of the body is the same, but if I were to push both of them up, the one with the 1mm limiter should be 1mm longer INSIDE of the body shouldn't it?
I did an illustration to show you what I'm visualizing.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 02-16-2013, 02:10 AM   #5211
Just1More's Avatar
I like your drawing, but in that pic the 1mm spacer defeats the purpose of adding it..which is to limit downtravel 1mm. Maybe i need to look at the setup sheet..but he is probably running a different length shock end right? they make 3 different lengths to basically do the same as internal limiters would. So yes, in your illustration assuming you used the same length rod end, the one with the limiter would be 1mm shorter. BUT in your picture you drew it so that it looks like you unscrewed the shock end 1mm to cancel out the internal limiter. I can't see a reason to build the shocks that way.
I run UFO pistons nowadays anyway, the piston actually hits the shock cap just before the shock is fully compressed.
Mark Clark
RB6
B44.1
TC6.1
Old 02-16-2013, 02:12 AM   #5212
Just1More's Avatar
Orion r10 pro
Orion 4000mah 90c
Avid triad
31-32/69 with full timing on my 17.5 Fantom D3.5, which is only around 25-28* anyway. I think this is the motor people are grinding the endplate on to get more timing from (so they can use the full sweep of the guage sticker).
Mark Clark
RB6
B44.1
TC6.1
Old 02-16-2013, 05:58 AM   #5213
cnelson3's Avatar
Trader Rating: 65 (100%+)
I noticed when rebuilding my shocks that the pistons matched the cartridge so well that when the shock was fully extended the piston and the cartridge were actually suctioned together. This caused an inconsistency in the shock action. I added the 1mm spacer to put some physical space in between the piston and the cartridge. Once I did this I noticed a huge change in how my suspension worked and reacted.
There are a few other shock tricks you can do to free up the suspension as well. I was running on a fairly blown out indoor track with a lot of bumps and noticed that both the losi's and ae's were floating over the bumps where I was bouncing off and all around on them. So I started tinkering.
Does anyone wonder why Kyosho does have ti-nitride coated shock shafts? I see they used to have a 54mm shock shaft but it's too long for the rb6.
cnelson3 is offline   Reply With Quote
Old 02-16-2013, 06:01 AM   #5214
cnelson3's Avatar
Btw even with the spacers, I'm running 27.3mm drop in the rear and 20.3mm in the front. It has no problem bottoming the shock out.
Old 02-16-2013, 07:14 AM   #5215
K_King's Avatar
Yeah we both have medium eyelets on so his would he unscrewed to get the 27mm gap.
Confusing isn't it lol
Old 02-16-2013, 07:59 AM   #5216
B00t13g's Avatar
Thanks guys.
Mackenzie Meyercord
Old 02-16-2013, 08:37 AM   #5217
I have found this too and was considering this, but around 0.5mm instead
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 02-16-2013, 08:39 AM   #5218
K_King's Avatar
It would explain why tebo runs 1mm
Old 02-16-2013, 08:51 AM   #5219
cnelson3's Avatar
The other things did was shave down the spacer between the orings. They are 4.8 mm in thickness and I shaved them down to 4.2 mm. I run the clear orings and noticed that they get compressed when u tighten the black cap on the cartridge causing the seals to really press against the shaft. I was running the caps snug tight and they were always backing off, so I trimmed the spacers a little and problem solved. I think I have my shocks as smooth as possible. Any other tips would be great.
I used (4) 1 mm spacers on my short bus with the same results except they do leave a little oil on the spring retainers when I rebuild them. Almost none tho. Better than all the other brands still, by far.
Old 02-16-2013, 08:53 AM   #5220
cnelson3's Avatar
Let me know how it works. I just had 1mm delrin spacers from the tree the regular bore shock pistons came on so I used those.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22968 Today 04:05 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
05PSD
