    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 02-15-2013, 12:05 AM   #5191
And I don't think it affects Cvd plunge, up travel etc just let's him quickly run less droop if needed without rebuilding the shock
Tom87 is offline   Reply With Quote
Old 02-15-2013, 12:21 AM   #5192
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Right so the droop is the same, but the 1mm limiter allows more plunge thereby giving more traction since the CVD will bind into the outdrive further?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 02-15-2013, 03:32 AM   #5193
eper's Avatar
Trader Rating: 14 (100%+)
Alls the limiter does is make it so you can get less droop in the shock. It has nothing to do with plunge. You can only thread the shock ends on so far so putting the limiter in there changes the shaft length. Droop changes your traction the way the car jumps and how it tranfers weight
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 02-15-2013, 06:08 AM   #5194
offroad dude's Avatar
Trader Rating: 25 (100%+)
With the Avid top shaft can you run the complete associated slipper setup?
offroad dude is offline   Reply With Quote
Old 02-15-2013, 07:13 AM   #5195
MikeXray's Avatar
Trader Rating: 73 (100%+)
I had found a post on the thread where someone said they could run the vts with the avid top shaft, I want to try that as well, I have it on my B4.1 and there is a lot more room for fine adjustments than the single setup, but I don't like the idea of having to use avid special spurs..
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-15-2013, 07:20 AM   #5196
K_King's Avatar
Right but I can get the same length without using a limiter with the same shock end.
So the droop is the same but the length of the shaft is 1mm longer the way he runs it. So full compression the piston goes further up and and the plunge increased also. I just don't know why he would do this.
Old 02-15-2013, 08:21 AM   #5197
Nitronut3's Avatar
Send a message via AIM to Nitronut3
Yes you can, i tried one for awhile when my LHS sold out of the triad's but had the top shafts. Its nice but i just recently put on the triad, and the triad is better than the VTS. the VTS uses way bigger pads which takes away some of the advantages of the new slipper setup. i felt my car had more forward bite with the triad over the VTS, even tho they felt the same tightness
Nate Jaskot
XRAY, RC America, KO Propo, Hudy, FX Engines, Nitropro, Rc addiction products , TeamSR, SmacTrac
Nitronut3 is offline   Reply With Quote
Old 02-15-2013, 08:25 AM   #5198
Thanks that was what I was looking for. My hobby shop is out also and I need something to use ASAP!
Old 02-15-2013, 03:13 PM   #5199
Trader Rating: 48 (100%+)
What battery config are u guys using
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 02-15-2013, 04:03 PM   #5200
Trader Rating: 46 (100%+)
Does anyone know the i.d. and o.d. Of the diff rings I'm trying to see if they will fit in a different car
josh short is offline   Reply With Quote
Old 02-15-2013, 04:49 PM   #5201
Ostach24's Avatar
Trader Rating: 85 (100%+)
thinking of selling a rb6 with partsit's brand new but built. has aluminum steering rack and crank, carbon fiber battery straps with spare arms knuckles towers arms an so on. In the pics i have it has all blue aluminum but it will not have them when you receive. the blue will will either be stock or brown and no body is included. pm me for pics price is 450 obo.
Ostach24 is offline   Reply With Quote
Old 02-15-2013, 05:22 PM   #5202
asc6000's Avatar
Trader Rating: 15 (100%+)
If he has to take the end off and the shaft out to take the limiter off thats not quickly to me.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 02-15-2013, 05:37 PM   #5203
asc6000's Avatar
You have me confused (ain't hard) but there is something that is clear to me. If the "bottom of the shock to the center of the shock end" is the same the plunge does not change. The overall droop and travel the same but with the piston in a different position inside the body. Your question as to why he would do that is definitely something to think about. I seem to recall something from decades ago about that, maybe that book is still around.
Ayrton Senna
Old 02-15-2013, 05:38 PM   #5204
Just1More's Avatar
No, the piston doesn't go farther up. When changing between long/medium/short ends the uptravel remains the same, the distance from the end of the shock shaft(while screwed in) to the center of the ball pivot is what changes.. Uptravel/downtravel doesn't change when going between the different shock ends, only A-arm droop. When putting a limiter under the piston, uptravel doesn't change, only downtravel and in turn A-arm droop. Hope this help, i see where you're coming from.
He was talking about swapping shock ends to change droop instead of taking the shock apart to add/remove limiters.
Mark Clark
RB6
B44.1
TC6.1
Just1More is offline   Reply With Quote
Old 02-15-2013, 09:55 PM   #5205
Brandon, you may have been asked this before is so I am sorry. I am putting your set up on my car. I have a couple questions. On the front blockmposition, in or out? On the front axle Hightower spacer you say 1mm top and bottom? Isn't there only a total of 1.5mm top or bottom? And rear wheel base. It says 2mm in front and rear of the arms? Is it .5mm in front of arm, and 1.5mm behind? Thanks
Dale.0 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
