    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 02-12-2013, 08:37 PM   #5146
Has anyone had problems breaking or bending the rear axles?
Bluehills315 is offline   Reply With Quote
Old 02-12-2013, 09:46 PM   #5147
fullsyzz's Avatar
Trader Rating: 102 (100%+)
Yes. Both bent and broken a few.
fullsyzz is offline   Reply With Quote
Old 02-12-2013, 10:05 PM   #5148
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I have yet to see an axle bend or break on any of the dozen or so RB6s iv seen run.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-12-2013, 11:54 PM   #5149
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Originally Posted by CanyonCarverR1 View Post
Flipping the steering rack around changes the Ackerman, taming the steering. Then you can shim the balls forward to go back to the stock setting, if later you want more aggressive steering.
Can anyone confirm this? The reason why I ask is because on my RB5 I ran a metal rack, and the first time I installed it I put the studs facing forward, pushing the links forward a lot. Needless to say the car plowed horribly, until I fixed it. Bringing it back made it turn a ton better.
So when I see Tebo run the 1mm Ackerman, to me he's taming steering, has anyone else found this to be true?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 02-13-2013, 08:25 AM   #5150
t8rtot's Avatar
Trader Rating: 14 (94%+)
+1 i can't imagine what you guys could be running into and bouncing off of to have multiple issues.
i'm not the best driver (consistancy issue) low A, high B mains after taking over a year off and i've only broken two parts and all because boneheaded moves by me.
Sfida
t8rtot is offline   Reply With Quote
Old 02-13-2013, 08:42 AM   #5151
I sent in my RB5 axles in to FastLane Machine to have them make some stonger axles. They now sell a set for $30. I have yet to bend one now.
These are for the SP2. I think thats the same as the WC and I hope the same for the RB6.
http://www.fastlanemachine.net/prodd...FLM6600&cat=35
Arcain41 is offline   Reply With Quote
Old 02-13-2013, 09:00 AM   #5152
MikeXray's Avatar
Trader Rating: 73 (100%+)
Moving the rack rearward in any scenario will reduce the angle of the outside wheel, making the wheels turn less parallel to each other. I haven't found this to necessarily produce the same results, like everything else it can depend on what the car is doing elsewhere in the suspension. I have had times where moving forward tamed down turn in and gained mid corner steering, and also times where rack back produced the best steering balance. I kept switching my B4's position and couldn't find one that was always better, but on that car the rearward one felt "tamer" overall.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-13-2013, 10:49 AM   #5153
Originally Posted by Posvar View Post
And I just sold my mip thorp drivers last month.
You can get yourself a set of Wera tools. German engineered, great proven quality, rarely wears. Great handle that actually fits your hand. We use them at work (manufacturing company).
They are extremely inexpensive for their quality. $3-4 for a 2.0mm hex driver at chadtoolbox(dot)com. I don't understand why RC companies are selling their tools for $10-20+ each.
And yea, never strip a bolt.
QIMB528 is offline   Reply With Quote
Old 02-13-2013, 11:45 AM   #5154
Super Moderator
Maybe engineered in Germany (im not sure how the shape of the handle matters where it's engineered), but for only $3 a pop.. they are manufactured in one place only, and that is China. No way in heck they will stand up to an MIP tool made here in America, with American steel... not by a long shot.
And considering MIP drivers last upwards of 25+ years... id say $14 is a bargain... seriously.
- RCSpecialties -
Old 02-13-2013, 11:54 AM   #5155
aloksatoor's Avatar
Trader Rating: 42 (100%+)
I have Wiha tools for non RC related stuff(they do say made in germany). They are not bad at all, but in no way comparable to MIP. And not the handles, I am talking about the tips. At best they are like dynamite. Wera (also german) is similar in quality to Wiha but a bit fancier looking.
For the axles I myself did not bend one. I ran one race weekend with the MIP diff/swing shafts axles, and its pretty new looking still. No signs of wear, but my Kyoshos also start showing wear after a month of racing (every week).
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 02-13-2013, 12:14 PM   #5156
Super Moderator
Keep the updates coming on your pin and outdrive wear, please! Maybe keep track of how many packs you have run? pretty please
- RCSpecialties -
Old 02-13-2013, 12:34 PM   #5157
aloksatoor's Avatar
Glad to help! I have around 5 packs on mine now. Track was extreme high grip this weekend so much more stress on pins and all btw.
Old 02-13-2013, 01:39 PM   #5158
Super Moderator
That's good to know.. im on a very high grip track as well.
- RCSpecialties -
Old 02-13-2013, 03:48 PM   #5159
not quite sir. they manufactured in czech republic. i own a bunch of wera bit holding handles and ratchets in addition to fixed drivers, they are actually really good. i use them along with my mip and hudy drivers but if i had a choice, mip and hudy for sure.
glenng is offline   Reply With Quote
Old 02-13-2013, 06:49 PM   #5160
MikeXray's Avatar
Just to make sure I'm not crazy here, the manual has you build the front end wide right? I've had people tell me they run narrow "like the manual" but the eccentric needs to be pointing away from the kingpin to be narrow, that moves the whole chub in. Manual has the hole furthest away from the kingpin which widens the track...
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
