    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 02-08-2013, 06:45 AM   #5071
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by Cpt.America View Post
His setup sheet says hes running block position OUT, but pictures show he was running IN... hhmm.
Originally Posted by mdowney View Post
I'll ask Derek to clarify. I'm guessing he probably created the setup sheet after studying Jared's car. Unless JP did it...
Maybe that setting talks about the hole positioning for the caster block insert.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-08-2013, 08:01 AM   #5072
joeymdz's Avatar
Send a message via MSN to joeymdz
Originally Posted by ChadBlanton View Post
I'm running the Avid slipper and I really like it - except it seems I've got it tightened down almost to the end of the spring (if that makes since) - in other words the spring is almost fully collapsed. It's 17.5 blinky mode, and it almost needs to be even tighter ... is the spring worn out already?
Anyone else experience this yet?
hey Chad if your racing on Saturday come see Troy or myself. We are running triads and can help.
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 02-08-2013, 08:03 AM   #5073
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I had the same confusion when I first read the editable setup sheet. Are they talking about the position of the block? or the position of the hole? The sheet says "block position"... which certainly doesn't mean the hole (at least I wouldn't think so)... which is why I annotated such on my setup sheet
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-08-2013, 10:02 AM   #5074
thanks - but I can usually only make Wednesday nights ... pretty sure its just a kinda weak spring, but I will double check when I tear into my car later
ChadBlanton is offline   Reply With Quote
Old 02-08-2013, 01:42 PM   #5075
killa B's Avatar
Hey ups just brought my exotec steering cranks and arm on the paper it comes with it shows installing the arm with the word exotec toward the front since there is no arrow for my dumb a$$ does that mean thats the way it goes to be like stock. I think yes just want to be sure before i start on it thanks
killa B is offline   Reply With Quote
Old 02-08-2013, 01:46 PM   #5076
joeymdz's Avatar
here ya go
Old 02-08-2013, 03:48 PM   #5077
killa B's Avatar
Gratitude
Old 02-08-2013, 07:51 PM   #5078
Default GHEA Pistons
Okay, I got my hands on some 1.3mm x 4 hole GHEA black delrin pistons. They came with no directions. My question would be which way do the pistons go on the shock shaft. My guess is that the tapered side would be facing away from the threaded end. But when I guess, I usually get it 180 degrees wrong.
Turbo
Turbo911 is offline   Reply With Quote
Old 02-08-2013, 08:13 PM   #5079
Suspended
Either way dude..difference between compression and rebound.
ErnestHelmsley is offline   Reply With Quote
Old 02-08-2013, 08:25 PM   #5080
steam's Avatar
Turbo
Taper down I would think would make the most since, creating better pack for bigger jumps
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 02-08-2013, 09:46 PM   #5081
joeymdz's Avatar
Turbo
Tapered side down
Old 02-08-2013, 11:05 PM   #5082
lbckevin's Avatar
Trader Rating: 91 (99%+)
I run them taper side down.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 02-09-2013, 12:44 AM   #5083
When you say tapered side down, I am assuming with the vehicle assembled the taper facing down towards the ground.
Turbo
Old 02-09-2013, 01:18 AM   #5084
steam's Avatar
Turbo
yes,
Maybe this will help
http://www.liverc.com/news/new_produ...shock_pistons/
Old 02-09-2013, 08:06 AM   #5085
Originally Posted by steam View Post
Thanks for info. What I am looking for is the science behind this theory, ie fluid dynamics. I enjoy learning the "what" but I really enjoy learning the "how".
Turbo
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
bonzo915
