    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 02-05-2013, 03:02 PM   #4966
fullsyzz's Avatar
Trader Rating: 102 (100%+)
Originally Posted by silvalis View Post
what did you hit?
The ground.
fullsyzz is offline   Reply With Quote
Old 02-05-2013, 03:06 PM   #4967
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by fullsyzz View Post
The ground.
Weird mine might have been the running update in plastic. I went through 3 rear shock towers which those kinds of flips but never a plastic rear camber plate. I since put in the red exo for insurance and it being same weight.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 02-05-2013, 03:39 PM   #4968
Originally Posted by ryanpatrickgore View Post
i thought i would try the saddles, but i already know i will probably go to a shorty.
next paycheck tho
Edit: what shorty packs are you guys running? i would like to get one at a decent price, dont want to spend 100$ if i dont have to, if its a good deal i wil get 2 . thanks
Crc all day 4200/40c I run I have beat the tar out of mine for 6 months now and just as good as day one. I run about 6 packs in practice and 2 quals and a 10 minute main in mod and zero fade.
Gitsum is offline   Reply With Quote
Old 02-05-2013, 05:38 PM   #4969
mdowney's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Cpt.America View Post
Caster block positions refer to running the caster blocks in the outer position for a wider front track, or in the inner position for a more narrow front track.
Aha! You meant the hub carrier when you mentioned track width several pages back. I had forgotten that it has two options for track width now in the RB6. I thought you were talking about the different widths of suspension mounts (which some call the caster block).
OK - now I get it.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 02-05-2013, 06:00 PM   #4970
I've read the first post but i'm still confused about the rear suspension hangers. I'm running rear motor and broke the stock RF hanger and replaced it with the mid motor RF2. Was the original one a RF or RF2 ? The back hanger(RR) doesnt have any markings on it. So by my thinking if the back is a (RR) and im running a RR2 in front I have little or no rear toe in HELP !!!!
Lou Colmo/Tekno EB48.3, SL & SCT410.3/ Tekno R/C,Tekin / Reedy Batteries / Savox /AKA / Futaba 4PKs
Blaze R/C,St.Louis DirtBurners,SMAC Trac
X God is offline   Reply With Quote
Old 02-05-2013, 06:04 PM   #4971
silvalis's Avatar
Trader Rating: 29 (100%+)
The ground.
sideways?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 02-05-2013, 06:21 PM   #4972
Technically it raises and lowers your front roll center, at the lower control arm position. No spacer for less roll/steering, larger spacer for more roll/steering. See if you can even tell a difference.
I tested this on the rb5wc. Thicker shim gives more mid/late corner steering. I didn't like the feeling. I thought the front end took to long to settle in the corner. Car became inconsistent.
On another note I ran the Cody turner setup from petit and it was very good. Better then the Japan setup imo.
Tom87 is offline   Reply With Quote
Old 02-05-2013, 06:54 PM   #4973
RodneyB's Avatar
The kit setup is RF2. Use the one packaged with the mid motor part not the one on the tree with the Tplate as it will break.
For the rear rear hanger use the wide one from the tree with the RF2.
Kyosho America; Peak Racing; Grandview Hobbies; CRCRC
CRCRC club administrator
Kyosho RB6, Kyosho ZX6, Kyosho SC6, Kyosho MP9e TKI
RodneyB is offline   Reply With Quote
Old 02-05-2013, 06:54 PM   #4974
So are the castor blocks are part (111)UM715? I think the manual calls them a hub bush hence my confusion.
HalfManHalfGod is offline   Reply With Quote
Old 02-05-2013, 06:56 PM   #4975
For the rear rear hanger use the narrow one from the tree with the RF2.
The setup sheet calls the rf2 the wide hangers. Is that a mistake? There are a number of spelling errors on the sheet.
Old 02-05-2013, 07:25 PM   #4976
RodneyB's Avatar
Oops sorry I meant wide rear. Will change it.
Old 02-05-2013, 07:31 PM   #4977
E73
E73's Avatar
Purchased my RB6 today from Scott @ TRCR. Getting back into the hobby after 20+ years. See all of you Seattle-area folks there in March!
E73 is offline   Reply With Quote
Old 02-05-2013, 07:34 PM   #4978
No worries. Up until yesterday I thought the rf2 were the narrow hangers.
Old 02-05-2013, 07:45 PM   #4979
Ok so you run RF2 & RR2 for a wide track and RF & RR for a narrow track correct ?
I just put on the aluminum RF & RR and I can see that I have toe in now,
I think i had the RR on when I put the RF2 on, Might explain why I had no traction on a dry track
Old 02-05-2013, 07:47 PM   #4980
That's how I had mine set-up UUGGGGG !!!!
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
