    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 02-05-2013, 08:34 AM   #4951
fullsyzz's Avatar
Trader Rating: 102 (100%+)
After breaking my 3rd stock rear camber plate the other day, even with set screws in the empty holes and longer ballstuds with a nut on the bottom, I decided to order the Exotek and see what happens.
fullsyzz is online now   Reply With Quote
Old 02-05-2013, 08:41 AM   #4952
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I put mine on this week.. VERY nice piece. I wouldn't run it without a pair of lunsford ti ball studs though (which I run everywhere). You don't want to risk breaking a weaker stock ball stud off in the alu piece.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-05-2013, 09:01 AM   #4953
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Going to really get into the build tonight, probably going with the kit setup but if anybody had any better starting points, tips, or advice I would greatly appreciate it. I drive trcr and Bremerton, indoor clay med - high traction, wet in the morning dries out and traction comes up in evening.
I picked up some of the longer ball studs an some losi 55's, and ae spur and pads. But that's pretty much it so far.
ryanpatrickgore is offline   Reply With Quote
Old 02-05-2013, 09:14 AM   #4954
joeymdz's Avatar
Send a message via MSN to joeymdz
ya go with Brandon's set up since he's at the same track... LOL
OR you just better than him? (just kidding... haha) He has a pretty solid set up and you can tweak from there
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 02-05-2013, 09:32 AM   #4955
I found this site when i did a search for exotek camber plate review. Looks like it's new....nice little review
http://2wdmod.com/2013/01/09/exotek-...er-plate-love/
sir_thomas is offline   Reply With Quote
Old 02-05-2013, 10:11 AM   #4956
Looking at his setup on petit, unfortunately I don't have the ghea pistons. But I do have gold springs. Maybe ill try Cody kings shock package from the recent wcrc setup, with Brandon's setup.
I also have nice saddles for the wheeler so I will have to run those, probably in stick configuration, has anybody had success running them in the side by side configuration?
Old 02-05-2013, 10:33 AM   #4957
joeymdz's Avatar
PM Brandon and he can point you in the right direction. If using stock 5 hold kyosho pistons I think the fluid was 37.5F/ 30R
Old 02-05-2013, 10:51 AM   #4958
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Just1More View Post
Worth it. Front carbon tower is bling depending on who you ask. I have almost all the exotek parts on my 6 and wouldn't go back to stock, no reason to.
+1 for me all exotek aluminum pieces, except the shock balls and the red diff nut no reason to go back, now if they just make the front suspension hanger in red...
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 02-05-2013, 11:10 AM   #4959
t8rtot's Avatar
Start with the kit setup
Sfida
t8rtot is offline   Reply With Quote
Old 02-05-2013, 11:37 AM   #4960
Super Moderator
Careful with the saddles... They will work fine, but your car will be HEAVY, for sure. With a lo-pro servo, and a 205 gram shorty pack, my RB6 comes in at 1560 grams on the dot, which is a nice medium/medium light car. It is FAR better at 1560 than it was at 1660 with a 305 gram full sized lipo. Matesa finally just made the switch and claims he loves the car much more with his shorty. Might want to ask him if he still holds that opinion after making the switch a couple weeks ago.
- RCSpecialties -
Old 02-05-2013, 12:41 PM   #4961
i thought i would try the saddles, but i already know i will probably go to a shorty.
next paycheck tho
Edit: what shorty packs are you guys running? i would like to get one at a decent price, dont want to spend 100$ if i dont have to, if its a good deal i wil get 2 . thanks
Old 02-05-2013, 12:52 PM   #4962
Was looking at the setup sheets and what does the .5mm and 1mm spacer do under the kickup 25 or 30 degree block? What does the caster block position in or out mean?
HalfManHalfGod is offline   Reply With Quote
Old 02-05-2013, 01:49 PM   #4963
aloksatoor's Avatar
next paycheck tho
Intellect pro 4600 shorty 80C. Best bang for buck. Forget the nanotechs and gens ace, the IR creeps up over the months.
Old 02-05-2013, 02:19 PM   #4964
Super Moderator
next paycheck tho
Yes, the IPs are top shelf packs. If Fantom packs weren't an option, I would run the IPs.
I have two of these and they are worth every penny.
http://www.fantomracing.com/proddeta...?prod=FAN26192
Technically it raises and lowers your front roll center, at the lower control arm position. No spacer for less roll/steering, larger spacer for more roll/steering. See if you can even tell a difference.
Caster block positions refer to running the caster blocks in the outer position for a wider front track, or in the inner position for a more narrow front track.
- RCSpecialties -
Old 02-05-2013, 03:01 PM   #4965
silvalis's Avatar
Trader Rating: 29 (100%+)
what did you hit?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Tommy R
