    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 02-04-2013, 05:19 PM   #4936
joeymdz's Avatar
Send a message via MSN to joeymdz
Originally Posted by shark2288 View Post
I've notice a lot of the current setups are using 4 hole 55 pistons. Can you just glue 1 hole shut on the 5 hole stock pistons and drill the other 4 to 55 and get the same results?
allot of them are using losi 4 hole pistons or taking blank kyosho pistons and drilling them out
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 02-04-2013, 05:35 PM   #4937
ben73's Avatar
Trader Rating: 40 (100%+)
pick up a set of the avid 4x1.3mm ones they are excellent and super smooth in the shocks
ben73 is offline   Reply With Quote
Old 02-04-2013, 05:44 PM   #4938
silvalis's Avatar
Trader Rating: 29 (100%+)
I was thinkign of trying those.
Has anyone tried the other ones - 1.6/1.1 (or whatever it was)?
Or those MIP valve shocks?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 02-04-2013, 05:57 PM   #4939
Does anyone have the part # for the blanks?
shark2288 is offline   Reply With Quote
Old 02-04-2013, 05:59 PM   #4940
ben73's Avatar
w5303-8
Old 02-04-2013, 06:03 PM   #4941
aloksatoor's Avatar
Trader Rating: 42 (100%+)
I used to do that with durango shocks. Don't feel like doing the same to my kyoshos . I also don't trust my otherwise trusty makita to drill perfect straight holes so I outsource it and buy gheas. If avid was available at the time I would support them since they are local and my LHS also started carrying stuff from them!
BTW a great job by Brandon and the other contributors in making the first post!
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 02-04-2013, 07:16 PM   #4942
joeymdz's Avatar
I copied brandons set up with the ghea pistons and that's a great upgrade.. But pretty spendy for 4 pistons.. Oh well we love our habbit!
Old 02-04-2013, 11:19 PM   #4943
Trader Rating: 55 (100%+)
I decided to purchase the kit as soon as it becomes available again along with the aluminum rear hangers. I was looking at some of the parts from exotek. Are they worth the cost or just bling?
Speedychris22 is offline   Reply With Quote
Old 02-04-2013, 11:35 PM   #4944
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
I bought a RB6 today and I am so stoked! Just started building it and it sure is nice! My first kyosho car. Going to run stock with it
ryanpatrickgore is offline   Reply With Quote
Old 02-04-2013, 11:40 PM   #4945
Just1More's Avatar
Worth it. Front carbon tower is bling depending on who you ask. I have almost all the exotek parts on my 6 and wouldn't go back to stock, no reason to.
Mark Clark
RB6
B44.1
TC6.1
Just1More is offline   Reply With Quote
Old 02-05-2013, 12:37 AM   #4946
gelshocker's Avatar
Hi, any reason to upgrade to alum diff nut? Does it prevent the diff loosening? Thx
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 02-05-2013, 12:44 AM   #4947
Just1More's Avatar
Probably lighter which is less rotating mass.. I'd use the stock nut and run an aluminum pinion gear for a bigger difference, but still probably not noticeable
Mark Clark
RB6
B44.1
TC6.1
Old 02-05-2013, 04:04 AM   #4948
The stock plastic diff nut holder is difficult to remove without destroying it (the little wings on it break off), upgrading to the alum diff nut will prevent that.
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Old 02-05-2013, 06:58 AM   #4949
IS the Exotek Front Bulk Head more prone to break other parts? Also the same question regarding the rear camber plate?
Old 02-05-2013, 07:37 AM   #4950
t8rtot's Avatar
i'm worried about shearing off a stud and having to drill it out, that's why mine wasn't installed. that and the stock one isn't an issue when it comes to durability. its just bling.
i really wish Exotek would roll out the hangers and hubs. that will be a big seller since the Factory parts aren't cheap.
Sfida
t8rtot is offline   Reply With Quote
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Yesterday 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
