    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 02-03-2013, 04:34 PM   #4921
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
I bought the rb6 used. I wasn't aware of the caster inserts and front bulk adjustment. The car had a total of 34 deg (30+4) and narrow rear (RF). The car pushed. I went rf2 rear and 25 deg caster (25+0). Better, but could still use some more steering. So I decided to do 29 deg (25+4) and OH WOW did this car wake up. I had A LOT of steering. It was a HUGE different to where my rear was spinning out where before it never did! I think this car loves 29 deg of caster!
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 02-03-2013, 06:58 PM   #4922
Just1More's Avatar
30+0 drives much different than 25+4. It's only 1* of caster change, but several degrees of kickup change between the two.. try 30+0 for a lot more off power steering. Remember ball stud washers, springs(Pink and Gold are my choice by far), and ride height adjustments make a huge difference, and should be fine tuned at the track
Mark Clark
RB6
B44.1
TC6.1
Just1More is offline   Reply With Quote
Old 02-03-2013, 07:35 PM   #4923
gelshocker's Avatar
Guys what are the pros and cons of using an alum front hinge pin holder, like those from GHEA and STRC? Thanks,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 02-03-2013, 07:50 PM   #4924
Just1More's Avatar
Answer from previous page:
Originally Posted by pli View Post
The GHEA aluminium version weighs 10g (stock plastic version is 5g), but main difference is that it will not flex and deform like the plastic one does. When deformed the angles of the hinge pins change, which will not only change your setup but also cause the shock ball ends to eventually break off since the suspension arms doesn't travel with the proper angle to the shocks. It also causes UM720 to be bent out of shape very easily.
Mark Clark
RB6
B44.1
TC6.1
Old 02-03-2013, 07:52 PM   #4925
gelshocker's Avatar
Thanks, and Cons, other than price and the +5g?
Kyosho RT5 | RB6
Old 02-03-2013, 08:37 PM   #4926
Just1More's Avatar
Idk, not many people have ran em.. I don't think it's necessary. The 720b stronger front brace is very tough, so don't buy the GHEA pivot block to save the 720 front part from bending. Another con would be a greater possibility of breaking front A arms due to reducing flex overall in a hard impact. If you buy one, run it a while then let us know how it performs plz.
Mark Clark
RB6
B44.1
TC6.1
Old 02-04-2013, 12:23 PM   #4927
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by Cpt.America View Post
There is also a ton of information on post #1.
You know, ever since you did that this thread has been pretty quiet. I guess people are starting to find the information on their own. Nice work!
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-04-2013, 12:25 PM   #4928
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
^^^^^yeah, what he said.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 02-04-2013, 12:50 PM   #4929
Do you guys change out the balls in your diff each time you rebuild the diff, or do you just flip the rings, clean everything and re-assemble? I'm not yet familiar with the longevity of the stock diff balls ...
ChadBlanton is offline   Reply With Quote
Old 02-04-2013, 12:54 PM   #4930
joeymdz's Avatar
Send a message via MSN to joeymdz
I would usually flip the rings but this last time i just cleaned, re-greased, and its still butter smooth!!!! very impressed with Kyosho other than the plastic suspension holders!!! lol
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 02-04-2013, 12:59 PM   #4931
Ya, me too!
Old 02-04-2013, 01:31 PM   #4932
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
You guys are all very very welcome... I'm just glad to help!
TY
Both... There are 2 kinds of rebuilds I do with my kyosho diffs
1.) about once a month I break them down, clean everything completely, flip and/or sand the rings, regrease, and rebuild.
2.) As soon as I start to feel some grittyness (flat spots on balls or dmg to rings), I buy new diff balls, new thrust balls, and new rings. I then rebuild with the new parts and im good to go. I think I do this 3 times a year, give or take. The rings can be flipped, and sanded flat again. But I usually don't sand a side more than once. So that is a grand total of 4 builds per set of rings, two per side.
Also... new out drives are needed when they start to notch up too much.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-04-2013, 02:35 PM   #4933
Also... new out drives are needed when they start to notch up too much.[/QUOTE]
That's why I was thinking about freshening up the diff - I'm about to need new outdrives. I figure I'll have it taken apart, might as well...
It's crazy that the diff outlasts the outdrives
Old 02-04-2013, 02:55 PM   #4934
Super Moderator
Also the pins in the swingshafts.. .they both wear like crazy. I am waiting to hear if there is any noticable durability benefits of the entire MIP system that just came out (full CVDs and Diff for the ultimas)
- RCSpecialties -
Old 02-04-2013, 04:17 PM   #4935
I've notice a lot of the current setups are using 4 hole 55 pistons. Can you just glue 1 hole shut on the 5 hole stock pistons and drill the other 4 to 55 and get the same results?
shark2288 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22956 Today 04:13 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
